您现在的位置: 365建站网 > 365文章 > asp.net 导出 gridview 数据 excel 全部 当前页 选择行 选中行 所选行 复选框
文章来源:365jz.com     点击数:1233    更新时间:2009-09-14 10:43   参与评论
按下保存按钮,可以选择保存当前行,当前页和全部记录
  1. #region 保存
  2.
  3. /// <summary>
  4. /// 保存
  5. /// </summary>
  6. protected void btnBC_Click(object sender, EventArgs e)
  7. {
  8.     string save_cblJL = "";
  9.     for (int i = 0; i < this.cblJL.Items.Count; i++)
  10.     {
  11.         if (this.cblJL.Items[i].Selected == true)
  12.         {
  13.             save_cblJL += this.cblJL.Items[i].Value + ",";
  14.         }
  15.     }
  16.
  17.     string[] save_Excel = save_cblJL.Split(',');
  18.
  19.     for (int j = 0; j < save_Excel.Length - 1;j++ )
  20.     {
  21.         if (save_Excel[j].Equals("全部记录"))
  22.         {
  23.             toExcelClk(gvwjdccx, 3);
  24.         }
  25.         else if (save_Excel[j].Equals("当前页"))
  26.         {
  27.             toExcelClk(gvwjdccx, 2);
  28.         }
  29.         else if (save_Excel[j].Equals("当前记录"))
  30.         {
  31.             toExcelClk(gvwjdccx, 1);
  32.         }
  33.     }
  34. }
  35. #endregion 保存
  1. #region 导出为Excel
  2.
  3. /// <summary>
  4. /// 导出为Excel
  5. /// </summary>
  6. /// <param name="control">控件ID</param>
  7. public override void VerifyRenderingInServerForm(Control control)
  8. {
  9.     // Confirms that an HtmlForm control is rendered for
  10. }
  11.
  12. /// <summary>
  13. /// 导出为Excel
  14. /// </summary>
  15. /// <param name="ctl">控件ID</param>
  16. /// <param name="FileName">文件名</param>
  17. private void ToExcel(Control ctl, string FileName)
  18. {
  19.     HttpContext.Current.Response.Charset = "UTF-8";
  20.     HttpContext.Current.Response.ContentEncoding = System.Text.Encoding.UTF8;
  21.     HttpContext.Current.Response.ContentType = "application/ms-excel";
  22.     HttpContext.Current.Response.AppendHeader("Content-Disposition""attachment;filename=" + "" + FileName);
  23.     ctl.Page.EnableViewState = false;
  24.     System.IO.StringWriter tw = new System.IO.StringWriter();
  25.     HtmlTextWriter hw = new HtmlTextWriter(tw);
  26.     ctl.RenderControl(hw);
  27.     HttpContext.Current.Response.Write(tw.ToString());
  28.     HttpContext.Current.Response.End();
  29. }
  30.
  31. /// <summary>
  32. /// 导出为Excel
  33. /// </summary>
  34. /// <param name="ckbSelect">选择的复选框,1为导出当前选择行,2为导出当前页,3为导出所有记录</param>
  35. private void toExcelClk(GridView gvw, int ckbSelect)
  36. {
  37.     if (ckbSelect == 3)
  38.     {
  39.         gvw.AllowPaging = false;//关闭分页以导出所有记录
  40.         gvw.AllowSorting = false;
  41.         gvw.DataSource = dt;//绑定到数组
  42.         gvw.DataBind();
  43.     }
  44.
  45.     else if (ckbSelect == 1)
  46.     {
  47.         gvw.AllowPaging = false;
  48.         gvw.AllowSorting = false;
  49.         int i = -1;
  50.         foreach (GridViewRow gvwRow in this.gvw.Rows)
  51.         {
  52.             i++;
  53.             if (((CheckBox)gvwRow.FindControl("ckbSelect")).Checked)
  54.             {
  55.                 gvw.Rows[i].Visible = true;
  56.             }
  57.             else
  58.             {
  59.                 gvw.Rows[i].Visible = false;
  60.             }
  61.         }
  62.     }
  63.     gvw.Columns[17].Visible = false;//隐藏选择列,不导出选择列
  64.     ToExcel(gvw, "jdccx.xls");
  65.     gvw.AllowPaging = true;
  66.     gvw.AllowSorting = true;
  67.     gvw.Columns[17].Visible = true;//恢复选择列为可见
  68.     gvw.DataSource = dt;//绑定到数组
  69.     gvw.DataBind();
  70. }
  71.
  72. #endregion 导出为Excel
发表评论 (1233人查看0条评论)
