您现在的位置: 365建站网 > 365文章 > MS Ajax 调用 WebService 示例
文章来源:365jz.com     点击数:307    更新时间:2009-09-14 10:45   参与评论
1. WebServices.aspx
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="WebServices.aspx.cs" Inherits="WebServicesTest" %>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>AjaxWebServiceTest</title>
    <form id="form1" runat="server">
        <asp:ScriptManager ID="ScriptManager1" runat="server">
            <Services>
                <asp:ServiceReference Path="../WebService/AjaxService.asmx" />
            </Services>
        </asp:ScriptManager>
        <asp:UpdateProgress ID="UpdateProgress1" runat="server">
            <ProgressTemplate>
                <img src="../Images/loading.gif" />
                Loading
            </ProgressTemplate>
        </asp:UpdateProgress>
        <div>
            <input id="inputName" type="text" size="20" runat="server" />
            <input id="btnTest" type="button" value="调 用" onclick="return btnTest_Click()" />
        </div>
    </form>
<script type="text/javascript" language="JavaScript">
function $(s){return document.getElementById(s);}
function btnTest_Click()
    var requestSimpleService = AjaxService.AjaxServiceTest(
    $('<%=inputName.ClientID %>').value,   //params
    OnRequestComplete    //Complete event
    return false;
function OnRequestComplete(result)
    alert(result);
2. AjaxService.asmx
<%@ WebService
    Language="C#"
    CodeBehind="~/App_Code/WebService/AjaxService.cs"
    Class="AjaxService" %>
3. AjaxService.cs
using System;
using System.Web.Services;
using System.Web.Script.Services;//***必须
[ScriptService]
public class AjaxService : WebService
    public AjaxService()
    [WebMethod]
    public string AjaxServiceTest(string s)
        Framework.AppException.LogFile(s);
        return "Hello " + s;
发表评论 (307人查看0条评论)
