您现在的位置: 365建站网 > 365文章 > JS无限级树形菜单
JS无限级树形菜单
文章来源:365jz.com     点击数:6576    更新时间:2009-09-15 10:01   参与评论
<title>无限级可刷新Js树型菜单</title>
<meta name="robots" content="无限级可刷新Js树型菜单" />
<meta name="description" content="无限级可刷新Js树型菜单" />
function Node(id, pid, name, url, title, target, icon, iconOpen, open) {
this.id = id;
this.pid = pid;
this.name = name;
this.url = url;
this.title = title;
this.target = target;
this.icon = icon;
this.iconOpen = iconOpen;
this._io = open || false;
this._is = false;
this._ls = false;
this._hc = false;
this._ai = 0;
this._p;
// Tree object
function dTree(objName) {
this.config = {
target: null,
folderLinks: true,
useSelection: true,
useCookies: true,
useLines: true,
useIcons: true,
useStatusText: false,
closeSameLevel: false,
inOrder: false
this.icon = {
root: 'http://www.qpsh.com/icon/wx/base.gif',
folder: 'http://www.qpsh.com/icon/wx/folder.gif',
folderOpen: 'http://www.qpsh.com/icon/wx/folderopen.gif',
node: 'http://www.qpsh.com/icon/wx/page.gif',
empty: 'http://www.qpsh.com/icon/wx/empty.gif',
line: 'http://www.qpsh.com/icon/wx/line.gif',
join: 'http://www.qpsh.com/icon/wx/join.gif',
joinBottom: 'http://www.qpsh.com/icon/wx/joinbottom.gif',
plus: 'http://www.qpsh.com/icon/wx/plus.gif',
plusBottom: 'http://www.qpsh.com/icon/wx/plusbottom.gif',
minus: 'http://www.qpsh.com/icon/wx/minus.gif',
minusBottom: 'http://www.qpsh.com/icon/wx/minusbottom.gif',
nlPlus: 'http://www.qpsh.com/icon/wx/nolines_plus.gif',
nlMinus: 'http://www.qpsh.com/icon/wx/nolines_minus.gif'
this.obj = objName;
this.aNodes = [];
this.aIndent = [];
this.root = new Node(-1);
this.selectedNode = null;
this.selectedFound = false;
this.completed = false;
// Adds a new node to the node array
dTree.prototype.add = function(id, pid, name, url, title, target, icon, iconOpen, open) {
this.aNodes[this.aNodes.length] = new Node(id, pid, name, url, title, target, icon, iconOpen, open);
// Open/close all nodes
dTree.prototype.openAll = function() {
this.oAll(true);
dTree.prototype.closeAll = function() {
this.oAll(false);
// Outputs the tree to the page
dTree.prototype.toString = function() {
var str = '<div class="dtree">\n';
if (document.getElementById) {
if (this.config.useCookies) this.selectedNode = this.getSelected();
str += this.addNode(this.root);
} else str += 'Browser not supported.';
str += '</div>';
if (!this.selectedFound) this.selectedNode = null;
this.completed = true;
return str;
// Creates the tree structure
dTree.prototype.addNode = function(pNode) {
var str = '';
var n=0;
if (this.config.inOrder) n = pNode._ai;
for (n; n<this.aNodes.length; n++) {
if (this.aNodes[n].pid == pNode.id) {
var cn = this.aNodes[n];
cn._p = pNode;
cn._ai = n;
this.setCS(cn);
if (!cn.target && this.config.target) cn.target = this.config.target;
if (cn._hc && !cn._io && this.config.useCookies) cn._io = this.isOpen(cn.id);
if (!this.config.folderLinks && cn._hc) cn.url = null;
if (this.config.useSelection && cn.id == this.selectedNode && !this.selectedFound) {
cn._is = true;
this.selectedNode = n;
this.selectedFound = true;
str += this.node(cn, n);
if (cn._ls) break;
return str;
// Creates the node icon, url and text
dTree.prototype.node = function(node, nodeId) {
var str = '<div class="dTreeNode">' + this.indent(node, nodeId);
if (this.config.useIcons) {
if (!node.icon) node.icon = (this.root.id == node.pid) ? this.icon.root : ((node._hc) ? this.icon.folder : this.icon.node);
if (!node.iconOpen) node.iconOpen = (node._hc) ? this.icon.folderOpen : this.icon.node;
if (this.root.id == node.pid) {
node.icon = this.icon.root;
node.iconOpen = this.icon.root;
str += '<img id="i' + this.obj + nodeId + '" src="' + ((node._io) ? node.iconOpen : node.icon) + '" alt="" />';
if (node.url) {
str += '<a id="s' + this.obj + nodeId + '" class="' + ((this.config.useSelection) ? ((node._is ? 'nodeSel' : 'node')) : 'node') + '" href="' + node.url + '"';
if (node.title) str += ' title="' + node.title + '"';
if (node.target) str += ' target="' + node.target + '"';
if (this.config.useStatusText) str += ' onmouseover="window.status=\'' + node.name + '\';return true;" onmouseout="window.status=\'\';return true;" ';
if (this.config.useSelection && ((node._hc && this.config.folderLinks) || !node._hc))
str += ' onclick="javascript: ' + this.obj + '.s(' + nodeId + ');"';
str += '>';
else if ((!this.config.folderLinks || !node.url) && node._hc && node.pid != this.root.id)
str += '<a href="javascript: ' + this.obj + '.o(' + nodeId + ');" class="node">';
str += node.name;
if (node.url || ((!this.config.folderLinks || !node.url) && node._hc)) str += '</a>';
str += '</div>';
if (node._hc) {
str += '<div id="d' + this.obj + nodeId + '" class="clip" style="display:' + ((this.root.id == node.pid || node._io) ? 'block' : 'none') + ';">';
str += this.addNode(node);
str += '</div>';
this.aIndent.pop();
return str;
// Adds the empty and line icons
dTree.prototype.indent = function(node, nodeId) {
var str = '';
if (this.root.id != node.pid) {
for (var n=0; n<this.aIndent.length; n++)
str += '<img src="' + ( (this.aIndent[n] == 1 && this.config.useLines) ? this.icon.line : this.icon.empty ) + '" alt="" />';
(node._ls) ? this.aIndent.push(0) : this.aIndent.push(1);
if (node._hc) {
str += '<a href="javascript: ' + this.obj + '.o(' + nodeId + ');"><img id="j' + this.obj + nodeId + '" src="';
if (!this.config.useLines) str += (node._io) ? this.icon.nlMinus : this.icon.nlPlus;
else str += ( (node._io) ? ((node._ls && this.config.useLines) ? this.icon.minusBottom : this.icon.minus) : ((node._ls && this.config.useLines) ? this.icon.plusBottom : this.icon.plus ) );
str += '" alt="" /></a>';
} else str += '<img src="' + ( (this.config.useLines) ? ((node._ls) ? this.icon.joinBottom : this.icon.join ) : this.icon.empty) + '" alt="" />';
return str;
// Checks if a node has any children and if it is the last sibling
dTree.prototype.setCS = function(node) {
var lastId;
for (var n=0; n<this.aNodes.length; n++) {
if (this.aNodes[n].pid == node.id) node._hc = true;
if (this.aNodes[n].pid == node.pid) lastId = this.aNodes[n].id;
if (lastId==node.id) node._ls = true;
// Returns the selected node
dTree.prototype.getSelected = function() {
var sn = this.getCookie('cs' + this.obj);
return (sn) ? sn : null;
// Highlights the selected node
dTree.prototype.s = function(id) {
if (!this.config.useSelection) return;
var cn = this.aNodes[id];
if (cn._hc && !this.config.folderLinks) return;
if (this.selectedNode != id) {
if (this.selectedNode || this.selectedNode==0) {
eOld = document.getElementById("s" + this.obj + this.selectedNode);
eOld.className = "node";
eNew = document.getElementById("s" + this.obj + id);
eNew.className = "nodeSel";
this.selectedNode = id;
if (this.config.useCookies) this.setCookie('cs' + this.obj, cn.id);
// Toggle Open or close
dTree.prototype.o = function(id) {
this.nodeStatus(!cn._io, id, cn._ls);
cn._io = !cn._io;
if (this.config.closeSameLevel) this.closeLevel(cn);
if (this.config.useCookies) this.updateCookie();
// Open or close all nodes
dTree.prototype.oAll = function(status) {
if (this.aNodes[n]._hc && this.aNodes[n].pid != this.root.id) {
this.nodeStatus(status, n, this.aNodes[n]._ls)
this.aNodes[n]._io = status;
// Opens the tree to a specific node
dTree.prototype.openTo = function(nId, bSelect, bFirst) {
if (!bFirst) {
if (this.aNodes[n].id == nId) {
nId=n;
break;
var cn=this.aNodes[nId];
if (cn.pid==this.root.id || !cn._p) return;
cn._io = true;
cn._is = bSelect;
if (this.completed && cn._hc) this.nodeStatus(true, cn._ai, cn._ls);
if (this.completed && bSelect) this.s(cn._ai);
else if (bSelect) this._sn=cn._ai;
this.openTo(cn._p._ai, false, true);
// Closes all nodes on the same level as certain node
dTree.prototype.closeLevel = function(node) {
if (this.aNodes[n].pid == node.pid && this.aNodes[n].id != node.id && this.aNodes[n]._hc) {
this.nodeStatus(false, n, this.aNodes[n]._ls);
this.aNodes[n]._io = false;
this.closeAllChildren(this.aNodes[n]);
// Closes all children of a node
dTree.prototype.closeAllChildren = function(node) {
if (this.aNodes[n].pid == node.id && this.aNodes[n]._hc) {
if (this.aNodes[n]._io) this.nodeStatus(false, n, this.aNodes[n]._ls);
// Change the status of a node(open or closed)
dTree.prototype.nodeStatus = function(status, id, bottom) {
eDiv= document.getElementById('d' + this.obj + id);
eJoin= document.getElementById('j' + this.obj + id);
eIcon= document.getElementById('i' + this.obj + id);
eIcon.src = (status) ? this.aNodes[id].iconOpen : this.aNodes[id].icon;
eJoin.src = (this.config.useLines)?
((status)?((bottom)?this.icon.minusBottom:this.icon.minus):((bottom)?this.icon.plusBottom:this.icon.plus)):
((status)?this.icon.nlMinus:this.icon.nlPlus);
eDiv.style.display = (status) ? 'block': 'none';
// [Cookie] Clears a cookie
dTree.prototype.clearCookie = function() {
var now = new Date();
var yesterday = new Date(now.getTime() - 1000 * 60 * 60 * 24);
this.setCookie('co'+this.obj, 'cookieValue', yesterday);
this.setCookie('cs'+this.obj, 'cookieValue', yesterday);
// [Cookie] Sets value in a cookie
dTree.prototype.setCookie = function(cookieName, cookieValue, expires, path, domain, secure) {
document.cookie =
escape(cookieName) + '=' + escape(cookieValue)
+ (expires ? '; expires=' + expires.toGMTString() : '')
+ (path ? '; path=' + path : '')
+ (domain ? '; domain=' + domain : '')
+ (secure ? '; secure' : '');
// [Cookie] Gets a value from a cookie
dTree.prototype.getCookie = function(cookieName) {
var cookieValue = '';
var posName = document.cookie.indexOf(escape(cookieName) + '=');
if (posName != -1) {
var posValue = posName + (escape(cookieName) + '=').length;
var endPos = document.cookie.indexOf(';', posValue);
if (endPos != -1) cookieValue = unescape(document.cookie.substring(posValue, endPos));
else cookieValue = unescape(document.cookie.substring(posValue));
return (cookieValue);
// [Cookie] Returns ids of open nodes as a string
dTree.prototype.updateCookie = function() {
var str = '';
if (this.aNodes[n]._io && this.aNodes[n].pid != this.root.id) {
if (str) str += '.';
str += this.aNodes[n].id;
this.setCookie('co' + this.obj, str);
// [Cookie] Checks if a node id is in a cookie
dTree.prototype.isOpen = function(id) {
var aOpen = this.getCookie('co' + this.obj).split('.');
for (var n=0; n<aOpen.length; n++)
if (aOpen[n] == id) return true;
return false;
// If Push and pop is not implemented by the browser
if (!Array.prototype.push) {
Array.prototype.push = function array_push() {
for(var i=0;i<arguments.length;i++)
this[this.length]=arguments[i];
return this.length;
if (!Array.prototype.pop) {
Array.prototype.pop = function array_pop() {
lastElement = this[this.length-1];
this.length = Math.max(this.length-1,0);
return lastElement;
<style>
.dtree {
font-family: Verdana, Geneva, Arial, Helvetica, sans-serif;
font-size: 11px;
color: #666;
white-space: nowrap;
.dtree img {
border: 0px;
vertical-align: middle;
.dtree a {
color: #333;
text-decoration: none;
.dtree a.node, .dtree a.nodeSel {
padding: 1px 2px 1px 2px;
.dtree a.node:hover, .dtree a.nodeSel:hover {
color: #333;
text-decoration: underline;
.dtree a.nodeSel {
background-color: #c0d2ec;
.dtree .clip {
overflow: hidden;
</style>
<h1>无限级可刷新Js树型菜单</h1>
<h2>Example</h2>
<div class="dtree">
<p><a href="javascript: d.openAll();">展开所有</a> | <a href="javascript: d.closeAll();">收起所有</a></p>
d = new dTree('d');
d.add(0,-1,'My example tree');
d.add(1,0,'Node 1','http://js.bhcode.net');
d.add(2,0,'Node 2','http://js.bhcode.net');
d.add(3,1,'Node 1.1','http://js.bhcode.net');
d.add(4,0,'Node 3','http://js.bhcode.net');
d.add(5,3,'Node 1.1.1','http://js.bhcode.net');
d.add(6,5,'Node 1.1.1.1','http://js.bhcode.net');
d.add(7,0,'Node 4','http://js.bhcode.net');
d.add(8,1,'Node 1.2','http://js.bhcode.net');
d.add(9,0,'My Pictures','http://js.bhcode.net','Pictures I\'ve taken over the years','','','http://www.qpsh.com/icon/wx/imgfolder.gif');
d.add(10,9,'The trip to Iceland','http://js.bhcode.net','Pictures of Gullfoss and Geysir');
d.add(11,9,'Mom\'s birthday','http://js.bhcode.net');
d.add(12,0,'Recycle Bin','http://js.bhcode.net','','','http://www.qpsh.com/icon/wx/trash.gif');
document.write(d);
</div>
发表评论 (6576人查看0条评论)
