您现在的位置: 365建站网 > 365文章 > jQuery queue & dequeue
文章来源:365jz.com     点击数:552    更新时间:2009-09-15 10:02   参与评论
These methods tend to come in pairs when you’re working within the animation queue.
When you use the animate and showhideslideUp, etc effect methods, you’re adding a job on to the fx queue.
By default, using queue and passing a function, will add to the fx queue. So we’re creating our own bespoke animation
step:
As I said though, these methods come in pairs, so anything you add using queue, you need to dequeue to allow the process to continue. In the code above, if I chained more animations on, until I call $(this).dequeue(), the subsequent animations wouldn’t run:
发表评论 (552人查看0条评论)
