126邮箱的pop3收信是收费服务,而且还不能收到垃圾邮件夹中的邮件,所以写了下面的小程序来收信。初学者,大家多多指教。
在写下面的代码过程中最吐血的事情是:在完成度到达 90% 的时候,不小心把源文件删除了。 由于是在linux下写的,在权衡了找回文件和重写之间,我还是选择了后者……555。
不多说了,粘代码:
Code
<?php
* 收取126邮箱中的信件
* @filename 126_curl.php
* @touch date Tue 28 Apr 2009 20:49:12 AM CST
* @package Get_Ganji_test_mails
* @author zhangyufeng
* @version 1.0.0
* @copyright (c) 2009, zhangyufeng@staff.ganji.com
error_reporting(0);
$user = '****';
$pass = '*****';
$mail_addr = '****@126.com';
$save_file = 'result.126.com.' . strtotime('now');
//{{{ 格式化邮件内容
function read_126_mail($mail_contents)
try{
$xml = new SimpleXMLElement($mail_contents);
$mail_all = array();
$mail_detail = array();
foreach($xml->array->object as $item)
$arrays = (array)$item->string[0];
$mail_detail['id'] = array_pop($arrays);
$arrays = (array)$item->string[1];
$mail_detail['to'] = array_pop($arrays);
$arrays = (array)$item->int[0];
$mail_detail['fid'] = array_pop($arrays);
$mail_detail['from'] = array_pop($arrays);
$arrays = (array)$item->string[3];
$mail_detail['subject'] = array_pop($arrays);
$arrays = (array)$item->date[0];
$mail_detail['sentDate'] = array_pop($arrays);
$arrays = (array)$item->date[1];
$mail_detail['receivedDate'] = array_pop($arrays);
array_push($mail_all, $mail_detail);
return $mail_all;
}catch(Exception $e)
print_r($e->getMessage());
exit();
开始登录 ganjizyf@126.com
$url = 'http://reg.163.com/login.jsp?type=1&product=mail126&url=http://entry.mail.126.com/cgi/ntesdoor?hid%3D10010102%26lightweight%3D1%26language%3D0%26style%3D-1';
$ch = curl_init($url);
$cookie = tempnam('.', 'cookie');
$referer_login = 'http://mail.126.com';
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HEADER, true);
curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 120);
curl_setopt($ch, CURLOPT_POST, true);
curl_setopt($ch, CURLOPT_REFERER, $referer_login);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
$fields_post = array(
'domain' => '126.com' ,
'language' => 0 ,
'bCookie' => '' ,
'username' => $mail_addr ,
'savelogin' => '',
'user' => $user ,
'remUser' => '',
'secure' => '',
'password' => $pass
$headers_login = array(
'User-Agent' => 'Mozilla/5.0 (Windows; U; Windows NT 5.1; zh-CN; rv:1.9) Gecko/2008052906 Firefox/3.0',
'Referer' => 'http://www.126.com'
$fields_string = '';
foreach($fields_post as $key => $value)
$fields_string .= $key . '=' . $value . '&';
$fields_string = rtrim($fields_string , '&');
curl_setopt($ch, CURLOPT_COOKIESESSION, true);
curl_setopt($ch, CURLOPT_COOKIEJAR, $cookie);
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers_login);
curl_setopt($ch, CURLOPT_POST, count($fields));
curl_setopt($ch, CURLOPT_POSTFIELDS, $fields_string);
$result_login = curl_exec($ch);
curl_close($ch);
开始第一次跳转
//取得跳转地址
preg_match('/http:\/\/passport.126.com.*loginyoudao=0/', $result_login, $url_c_1);
$ch = curl_init($url_c_1[0]);
$referer_check_1 = $url;
curl_setopt($ch, CURLOPT_REFERER, $referer_check_1);
curl_setopt($ch, CURLOPT_COOKIEFILE, $cookie);
$result_check_1 = curl_exec($ch);
curl_close($ch);
//var_dump($result_check_1);
开始第二次跳转
//取得跳转地址
preg_match('/http:\/\/entry.mail.126.com.*ganjizyf@126.com/', $result_check_1, $url_c_2);
$ch = curl_init($url_c_2[0]);
$headers_check_2 = array(
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers_check_2);
$referer_check_2 = $url_c_1[0];
curl_setopt($ch, CURLOPT_REFERER, $referer_check_2);
$result_check_2 = curl_exec($ch);
curl_close($ch);
//取得sid
preg_match('/sid=[^\"].*/', $result_check_2, $location);
$sid = substr($location[0], 4, -1);
开始第三次跳转
//取得跳转地址
preg_match('/http:.*/', $result_check_2, $url_c_3);
$ch = curl_init($url_c_3[0]);
$referer_check_3 = $url_c_2[0];
curl_setopt($ch, CURLOPT_REFERER, $referer_check_3);
$result_check_3 = curl_exec($ch);
curl_close($ch);
开始收取邮件
//取得收信地址
$url = "http://tg1b12.mail.126.com/a/s?sid=${sid}&func=mbox:listMessages";
$headers_get_mail = array(
'Host' => 'tg1b12.mail.126.com',
'Acccept' => 'text/javascript',
'Referer' => 'http://tg1b12.mail.126.com/a/j/dm3/index.jsp?sid=' . $sid
$fields_string = '<?xml version="1.0"?><object><int name="fid">1</int><string name="order">date</string><boolean name="desc">true</boolean><int name="start">0</int><int name="limit">20</int></object>';
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_HEADER, false);
$referer_get = 'http://tg1b12.mail.126.com/a/j/dm3/index.jsp?sid='. $sid;
curl_setopt($ch, CURLOPT_REFERER, $referer_get);
$result_mails_list = curl_exec($ch);
curl_close($ch);
$array_mails = read_126_mail($result_mails_list);
if(is_array($array_mails))
foreach($array_mails as $key => $value)
/* 获取邮件全部HTML代码(显示时可以直接使用)
//开始得到ssid
$url = "http://tg1b12.mail.126.com/jy3/read/read.jsp?offset=0&mid={$array_mails[$key]['id']}&sid=${sid}&fid={$array_mails[$key]['fid']}";
$array_mails[$key]['url_1'] = $url;
curl_setopt($ch, CURLOPT_POST, false);
$referer_get = 'http://tg1b12.mail.126.com/jy3/mbox/list.jsp?sid=${sid}&fid=1';
$result_ssid_string = curl_exec($ch);
curl_close($ch);
preg_match('/ssid=(.*%3d)&mid/', $result_ssid_string, $ssids);
$ssid = $ssids[1];
//开始得到邮件正文(HTML)
$url = "http://tg1b12.mail.126.com/jy3/read/viewMailHTML.jsp?ssid=${ssid}&mid={$array_mails[$key]['id']}&partId=0&isSearch=&filterScripts=true&filterStylesheets=false&filterObjects=true&filterFrames=true";
$array_mails[$key]['url_2'] = $url;
$referer_get = "http://tg1b12.mail.126.com/jy3/read/read.jsp?offset=0&mid={$array_mails[$key]['id']}&sid=${sid}&fid=1";
$result_mail_content = curl_exec($ch);
curl_close($ch);
//获得邮件原文
$url = "http://tg1b12.mail.126.com/jy3/read/readdata.jsp?sid=${sid}&mid={$array_mails[$key]['id']}&mode=text&part=0";
curl_close($ch);
$array_mails[$key]['contents'] = $result_mail_content;
if($array_mails[$key]['fid'] == '5')
$array_mails[$key]['type'] = '垃圾邮件';
else
$array_mails[$key]['type'] = '正常邮件';
// var_dump($array_mails[$key]);
else
print_r('error!');
exit();
file_put_contents($save_file, json_encode($array_mails));
unlink($cookie);
最后,想问一下哪位大大知道收取Msn类邮件的方法,不胜感激!
