JQuery制作简单选择时间控件
文章来源:365jz.com 点击数:
1262 更新时间:2009-09-16 11:35
参与评论
最近在项目中用到的,可以快速的选择小时和分钟
代码如下
html页面:
<html xmlns="http://www.w3.org/1999/xhtml" >
<title></title>
<script language="javascript" type="text/javascript" src="/js/jsquery.js"></script>
<script language="javascript" type="text/javascript" src="/js/jstime.js"></script>
<style>
.timepicker{
border: 1px solid #000000;
color: #000000;
padding: 2px;
margin: 0;
background: #EAEFFD;
position: absolute;
text-align: center;
width:140px;
.timepicker tr, .timepicker table td {
font-size: 12px;
vertical-align: middle;
text-align: center;
}</style>
<form id="form1" runat="server">
<input id="txtTime" readonly="readonly" size="5" type="text" />
$('#txtTime').timepicker("1");</script>
</form>
然后是jstime文件:
Jstime
//(function($) {
/* Timepicker plugin
* Use timeboard to pick up any time.
$.fn.timepicker = function(inputname) {
if (!this.length) return this;
var debug = false,
_input = this,
_timepicker = null,
_timepickerPosition = null,
_timepickerShowing = false,
_mainClass = 'timepicker',
_inputClass = 'timepicker-input',
_mainWrap = 'time-picker-wrap'+inputname,
_ddlhour='ddlhour'+inputname,
_ddlminute='ddlminute'+inputname,
_btnClear='btnClear'+inputname
var _select="";
_select+="<tr><td>小时:<select id=\""+_ddlhour+"\">";
for(var i=0;i<24;i++)
_select+="<option value='"+padLeft(i.toString())+"'>"+i.toString()+"</option>";
_select+="</select></td></tr>";
_select+="<tr><td>分钟:<select id=\""+_ddlminute+"\">";
for(var i=0;i<60;i++)
var _clearinput="<tr><td><input type=\"button\" class=\"input_btn\" id=\""+_btnClear+"\" value=\"清空\"/></td></tr>"
var _html = '<div id="' + _mainWrap + '" class="' + _mainClass+ '" style="display:none;"><table><tbody>'+_select+_clearinput+'</tbody></table></div>';
this.focus(showTimepicker).click(showTimepicker).keydown(doKeyDown);
$(document.body).mousedown(checkExternalClick); //鼠标移开后
function initialTimepicker() {
_input.after(_html);
_input.addClass(_inputClass);
_timepicker = $('#' + _mainWrap);
$("#"+_ddlhour).change(getTime);
$("#"+_ddlminute).change(getTime);
$("#"+_btnClear).click(doClear);
if(_input.val()!="")
$("#"+_ddlhour+" option[value='"+_input.val().split(':')[0]+"']").attr("selected","true");
$("#"+_ddlminute+" option[value='"+_input.val().split(':')[1]+"']").attr("selected","true");
getTime();
function showTimepicker() {
if (_timepicker == null) initialTimepicker();
if (!_timepickerShowing) {
getTime();
setPosition(this);
_timepicker.fadeIn("fast");
_timepickerShowing = true;
return;
function hideTimepicker() {
if (_timepickerShowing) {
_timepicker.fadeOut("fast");
_timepickerShowing = false;
return;
// Set position of timepicker(设定弹出div的位置)
function setPosition(input) {
var _inputPosition = $(input).offset();
_timepickerPosition = [_inputPosition.left, _inputPosition.top + input.offsetHeight];
if ($.browser.opera) { // correction for Opera when scrolled
_timepickerPosition[0] -= document.documentElement.scrollLeft;
_timepickerPosition[1] -= document.documentElement.scrollTop;
_timepicker.css({ 'left': _timepickerPosition[0] + 'px',
'top': _timepickerPosition[1] + 'px' });
function doKeyDown(e) {
var handled = true;
switch (e.keyCode) {
// Tab key
case 9: getTime();
hideTimepicker();
break;
// ESC key
case 27: hideTimepicker();
break;
} else {
handled = false;
if (handled) {
e.preventDefault();
e.stopPropagation();
function doClear() {
// Clear time in the ``_input``
_input.val("");
hideTimepicker();
return;
function getTime() {
// 赋值
var time = padLeft($("#"+_ddlhour).val()) + ':' + padLeft($("#"+_ddlminute).val());
_input.val(time);
return time;
function checkExternalClick(e) {
if (!_timepickerShowing) return;
var target = $(e.target);
if ((target.parents('#' + _mainWrap).length == 0) &&
!target.hasClass(_inputClass) &&
!target.hasClass(_mainClass))
hideTimepicker();
function padLeft(val) {
if (val.toString().length >= 2) return String(val);
return padLeft("0" + val);
//})(jQuery);
