您现在的位置: 365建站网 > 365文章 > sql db link string
sql db link string
文章来源:365jz.com     点击数:471    更新时间:2009-09-16 11:51   参与评论
  •  SQL Server
    •  ODBC
      •  Standard Security:
        "Driver={SQL Server};Server=Aron1;Database=pubs;Uid=sa;Pwd=asdasd;"
      •  Trusted connection:
        "Driver={SQL Server};Server=Aron1;Database=pubs;Trusted_Connection=yes;"
      •  Prompt for username and password:
        oConn.Properties("Prompt") = adPromptAlways
        oConn.Open "Driver={SQL Server};Server=Aron1;DataBase=pubs;"
    •  OLE DB, OleDbConnection (.NET)
        "Provider=sqloledb;Data Source=Aron1;Initial Catalog=pubs;User Id=sa;Password=asdasd;"
      •  Trusted Connection:
        "Provider=sqloledb;Data Source=Aron1;Initial Catalog=pubs;Integrated Security=SSPI;"
        (use serverName\instanceName as Data Source to use an specifik SQLServer instance, only SQLServer2000)
        oConn.Provider = "sqloledb"
        oConn.Open "Data Source=Aron1;Initial Catalog=pubs;"
      •  Connect via an IP address:
        "Provider=sqloledb;Data Source=190.190.200.100,1433;Network Library=DBMSSOCN;Initial Catalog=pubs;User ID=sa;Password=asdasd;"
        (DBMSSOCN=TCP/IP instead of Named Pipes, at the end of the Data Source is the port to use (1433 is the default))
    •  SqlConnection (.NET)
        "Data Source=Aron1;Initial Catalog=pubs;User Id=sa;Password=asdasd;"
           - or -
        "Server=Aron1;Database=pubs;User ID=sa;Password=asdasd;Trusted_Connection=False"
           (both connection strings produces the same result)
        "Data Source=Aron1;Initial Catalog=pubs;Integrated Security=SSPI;"
           - or -
        "Server=Aron1;Database=pubs;Trusted_Connection=True;"
        "Data Source=190.190.200.100,1433;Network Library=DBMSSOCN;Initial Catalog=pubs;User ID=sa;Password=asdasd;"
      •  Declare the SqlConnection:
        C#:
        using System.Data.SqlClient;
        SqlConnection oSQLConn = new SqlConnection();
        oSQLConn.ConnectionString="my connection string";
        oSQLConn.Open();
        VB.NET:
        Imports System.Data.SqlClient
        Dim oSQLConn As SqlConnection = New SqlConnection()
        oSQLConn.Open()
    •  Data Shape
      •  MS Data Shape
        "Provider=MSDataShape;Data Provider=SQLOLEDB;Data Source=Aron1;Initial Catalog=pubs;User ID=sa;Password=asdasd;"
        Want to learn data shaping? Check out 4GuyfFromRolla's great article about Data Shaping >>
    •  Read more
      •  How to define which network protocol to use
        • Example:
          Name Network library
          dbnmpntw Win32 Named Pipes
          dbmssocn Win32 Winsock TCP/IP
          dbmsspxn Win32 SPX/IPX
          dbmsvinn Win32 Banyan Vines
          dbmsrpcn Win32 Multi-Protocol (Windows RPC)
          Important note!
          When connecting through the SQLOLEDB provider use the syntax Network Library=dbmssocn
          and when connecting through MSDASQL provider use the syntax Network=dbmssocn
      •  All SqlConnection connection string properties
        • This table shows all connection string properties for the ADO.NET SqlConnection object. Most of the properties are also used in ADO. All properties and descriptions is from msdn.
          Name Default Description
          Application Name   The name of the application, or '.Net SqlClient Data Provider' if no application name is provided.
          AttachDBFilename
          -or-
          extended properties
          -or-
          Initial File Name
            The name of the primary file, including the full path name, of an attachable database. The database name must be specified with the keyword 'database'.
          Connect Timeout
          -or-
          Connection Timeout
          15 The length of time (in seconds) to wait for a connection to the server before terminating the attempt and generating an error.
          Connection Lifetime 0 When a connection is returned to the pool, its creation time is compared with the current time, and the connection is destroyed if that time span (in seconds) exceeds the value specified by connection lifetime. Useful in clustered configurations to force load balancing between a running server and a server just brought on-line.
          Connection Reset 'true' Determines whether the database connection is reset when being removed from the pool. Setting to 'false' avoids making an additional server round-trip when obtaining a connection, but the programmer must be aware that the connection state is not being reset.
          Current Language   The SQL Server Language record name.
          Data Source
          -or-
          Server
          -or-
          Address
          -or-
          Addr
          -or-
          Network Address
            The name or network address of the instance of SQL Server to which to connect.
          Enlist 'true' When true, the pooler automatically enlists the connection in the creation thread's current transaction context.
          Initial Catalog
          -or-
          Database
            The name of the database.
          Integrated Security
          -or-
          Trusted_Connection
          'false' Whether the connection is to be a secure connection or not. Recognized values are 'true', 'false', and 'sspi', which is equivalent to 'true'.
          Max Pool Size 100 The maximum number of connections allowed in the pool.
          Min Pool Size 0 The minimum number of connections allowed in the pool.
          Network Library
          -or-
          Net
          'dbmssocn' The network library used to establish a connection to an instance of SQL Server. Supported values include dbnmpntw (Named Pipes), dbmsrpcn (Multiprotocol), dbmsadsn (Apple Talk), dbmsgnet (VIA), dbmsipcn (Shared Memory) and dbmsspxn (IPX/SPX), and dbmssocn (TCP/IP).
          The corresponding network DLL must be installed on the system to which you connect. If you do not specify a network and you use a local server (for example, "." or "(local)"), shared memory is used.
          Packet Size 8192 Size in bytes of the network packets used to communicate with an instance of SQL Server.
          Password
          -or-
          Pwd
            The password for the SQL Server account logging on.
          Persist Security Info 'false' When set to 'false', security-sensitive information, such as the password, is not returned as part of the connection if the connection is open or has ever been in an open state. Resetting the connection string resets all connection string values including the password.
          Pooling 'true' When true, the SQLConnection object is drawn from the appropriate pool, or if necessary, is created and added to the appropriate pool.
          User ID   The SQL Server login account.
          Workstation ID the local computer name The name of the workstation connecting to SQL Server.
          Note
          Use ; to separate each property.
          If a name occurs more than once, the value from the last one in the connection string will be used.
          If you are building your connection string in your app using values from user input fields, make sure the user can't change the connection string by inserting an additional property with another value within the user value.
  •  SQL Server 2005
    •  SQL Native Client ODBC Driver
      •  Standard security:
        "Driver={SQL Native Client};Server=Aron1;Database=pubs;UID=sa;PWD=asdasd;"
        "Driver={SQL Native Client};Server=Aron1;Database=pubs;Trusted_Connection=yes;"
        Equivalents
        Integrated Security=SSPI equals Trusted_Connection=yes
        oConn.Open "Driver={SQL Native Client};Server=Aron1;DataBase=pubs;"
      •  Enabling MARS (multiple active result sets):
        "Driver={SQL Native Client};Server=Aron1;Database=pubs;Trusted_Connection=yes;MARS_Connection=yes"
        Equivalents
        MultipleActiveResultSets=true equals MARS_Connection=yes
        Using MARS with SQL Native Client, by Chris Lee >>
      •  Encrypt data sent over network:
        "Driver={SQL Native Client};Server=Aron1;Database=pubs;Trusted_Connection=yes;Encrypt=yes"
      •  Attach a database file on connect to a local SQL Server Express instance:
        "Driver={SQL Native Client};Server=.\SQLExpress;AttachDbFilename=c:\asd\qwe\mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;"
           - or -
        "Driver={SQL Native Client};Server=.\SQLExpress;AttachDbFilename=|DataDirectory|mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;"
           (use |DataDirectory| when your database file resides in the data directory)
        Why is the "Database" parameter needed? Answer: If the database was previously attached, SQL Server does not reattach it (it uses the attached database as the default for the connection).
        Download the SQL Native Client here >> (the package contains booth the ODBC driver and the OLE DB provider)
        Using SQL Server 2005 Express? Don't miss the server name syntax: SERVERNAME\SQLEXPRESS (Substitute "SERVERNAME" with the name of the computer)
    •  SQL Native Client OLE DB Provider
        "Provider=SQLNCLI;Server=Aron1;Database=pubs;UID=sa;PWD=asdasd;"
        "Provider=SQLNCLI;Server=Aron1;Database=pubs;Trusted_Connection=yes;"
        Equivalents
        oConn.Open "Provider=SQLNCLI;Server=Aron1;DataBase=pubs;"
        "Provider=SQLNCLI;Server=Aron1;Database=pubs;Trusted_Connection=yes;MarsConn=yes"
        Equivalents
        MarsConn=yes equals MultipleActiveResultSets=true equals MARS_Connection=yes
        "Provider=SQLNCLI;Server=Aron1;Database=pubs;Trusted_Connection=yes;Encrypt=yes"
        "Provider=SQLNCLI;Server=.\SQLExpress;AttachDbFilename=c:\asd\qwe\mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;"
           - or -
        "Provider=SQLNCLI;Server=.\SQLExpress;AttachDbFilename=|DataDirectory|mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;"
           - or -
           - or -
        (use serverName\instanceName as Data Source to use an specifik SQLServer instance)
        "Server=Aron1;Database=pubs;Trusted_Connection=True;MultipleActiveResultSets=true"
        Note! Use ADO.NET 2.0 for MARS functionality. MARS is not supported in ADO.NET 1.0 nor ADO.NET 1.1
        Streamline your Data Connections by Moving to MARS, by Laurence Moroney, DevX.com >>
        "Server=.\SQLExpress;AttachDbFilename=c:\asd\qwe\mydbfile.mdf;Database=dbname;Database=dbname;Trusted_Connection=Yes;"
           - or -
        "Server=.\SQLExpress;AttachDbFilename=|DataDirectory|mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;"
      •  Using "User Instance" on a local SQL Server Express instance:
        "Data Source=.\SQLExpress;integrated security=true;attachdbfilename=|DataDirectory|\mydb.mdf;user instance=true;"
        The "User Instance" functionality creates a new SQL Server instance on the fly during connect. This works only on a local SQL Server 2005 instance and only when connecting using windows authentication over local named pipes. The purpose is to be able to create a full rights SQL Server instance to a user with limited administrative rights on the computer. To enable the functionality: sp_configure 'user instances enabled','1' (0 to disable)
    •  Context Connection - connecting to "self" from within your CLR stored prodedure/function
      •  C#:
        using(SqlConnection connection = new SqlConnection("context connection=true"))
            connection.Open();
            // Use the connection
      •  Visual Basic:
        Using connection as new SqlConnection("context connection=true")
            connection.Open()
            ' Use the connection
        End Using
        The context connection lets you execute Transact-SQL statements in the same context (connection) that your code was invoked in the first place.
    •  Read more
      •  When to use SQL Native Client?
        •  .Net applications
          Do not use the SQL Native Client. Use the .NET Framework Data Provider for SQL Server (SqlConnection).
        •  COM applications, all other then .Net applications
          Use the SQL Native Client if you are accessing an SQL Server 2005 and need the new features of SQL Server 2005 such as MARS, encryption, XML data type etc. Continue use your current provider (OLE DB / ODBC through the MDAC package) if you are not connecting to an SQL Server 2005 (that's quite obvious eh..) or if you are connecting to an SQL Server 2005 but are not using any of the new SQL Server 2005 features.
          For more details on the differences between MDAC and SQL Native Client, read this msdn article >>
  •  Access
    •  ODBC
        "Driver={Microsoft Access Driver (*.mdb)};Dbq=C:\mydatabase.mdb;Uid=Admin;Pwd=;"
      •  Workgroup:
        "Driver={Microsoft Access Driver (*.mdb)};Dbq=C:\mydatabase.mdb;SystemDB=C:\mydatabase.mdw;"
      •  Exclusive:
        "Driver={Microsoft Access Driver (*.mdb)};Dbq=C:\mydatabase.mdb;Exclusive=1;Uid=admin;Pwd="
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=\somepath\mydb.mdb;User Id=admin;Password=;"
      •  Workgroup (system database):
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=\somepath\mydb.mdb;Jet OLEDB:System Database=system.mdw;"
      •  With password:
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=\somepath\mydb.mdb;Jet OLEDB:Database Password=MyDbPassword;"
  •  Oracle
    •  ODBC
      •  New version:
        "Driver={Microsoft ODBC for Oracle};Server=OracleServer.world;Uid=Username;Pwd=asdasd;"
      •  Old version:
        "Driver={Microsoft ODBC Driver for Oracle};ConnectString=OracleServer.world;Uid=myUsername;Pwd=myPassword;"
        "Provider=msdaora;Data Source=MyOracleDB;User Id=UserName;Password=asdasd;"
        This one's from Microsoft, the following are from Oracle
        "Provider=OraOLEDB.Oracle;Data Source=MyOracleDB;User Id=Username;Password=asdasd;"
        "Provider=OraOLEDB.Oracle;Data Source=MyOracleDB;OSAuthent=1;"
    •  OracleConnection (.NET)
      •  Standard:
        "Data Source=MyOracleDB;Integrated Security=yes;"
        This one works only with Oracle 8i release 3 or later
      •  Specifying username and password:
        "Data Source=MyOracleDB;User Id=username;Password=passwd;Integrated Security=no;"
      •  Declare the OracleConnection:
        C#:
        using System.Data.OracleClient;
        OracleConnection oOracleConn = new OracleConnection();
        oOracleConn.ConnectionString = "my connection string";
        oOracleConn.Open();
        VB.NET:
        Imports System.Data.OracleClient
        Dim oOracleConn As OracleConnection = New OracleConnection()
        oOracleConn.Open()
        Missing the System.Data.OracleClient namespace? Download .NET Managed Provider for Oracle >>
        Great article! "Features of Oracle Data Provider for .NET" by Rama Mohan G. at C# Corner
    •  Core Labs OraDirect (.NET)
      •  Standard:
        "User ID=scott; Password=tiger; Host=ora; Pooling=true; Min Pool Size=0;Max Pool Size=100; Connection Lifetime=0"
        Read more at Core Lab and the product page.
    •  Data Shape
      •  MS Data Shape:
        "Provider=MSDataShape.1;Persist Security Info=False;Data Provider=MSDAORA;Data Source=orac;user id=username;password=mypw"
  •  MySQL
    •  MyODBC
      •  MyODBC 2.50 Local database:
        "Driver={mySQL};Server=localhost;Option=16834;Database=mydatabase;"
      •  MyODBC 2.50 Remote database:
        "Driver={mySQL};Server=data.domain.com;Port=3306;Option=131072;Stmt=;Database=my-database;Uid=username;Pwd=password;"
      •  MyODBC 3.51 Local database:
        "DRIVER={MySQL ODBC 3.51 Driver};SERVER=localhost;DATABASE=myDatabase;USER=myUsername;PASSWORD=myPassword;OPTION=3;"
      •  MyODBC 3.51 Remote database:
        "DRIVER={MySQL ODBC 3.51 Driver};SERVER=data.domain.com;PORT=3306;DATABASE=myDatabase; USER=myUsername;PASSWORD=myPassword;OPTION=3;"
      •  Standard:
        "Provider=MySQLProv;Data Source=mydb;User Id=UserName;Password=asdasd;"
    •  Connector/Net 1.0 (.NET)
      •  Standard:
        "Server=Server;Database=Test;Uid=UserName;Pwd=asdasd;"
        Download the driver at MySQL Developer Zone.
      •  Specifying port:
        "Server=Server;Port=1234;Database=Test;Uid=UserName;Pwd=asdasd;"
        Default port is 3306. Enter value -1 to use a named pipe connection.
      •  Declare the MySqlClient connection:
        C#:
        using MySql.Data.MySqlClient;
        MySqlConnection oMySqlConn = new MySqlConnection();
        oMySqlConn.ConnectionString = "Server=Server;Database=Test;Uid=UserName;Pwd=asdasd;";
        oMySqlConn.Open();
        VB.NET:
        Imports MySql.Data.MySqlClient
        Dim oMySqlConn As MySqlConnection = New MySqlConnection()
        oMySqlConn.Open()
    •  MySqlConnection (.NET)
      •  eInfoDesigns.dbProvider:
        "Data Source=server;Database=mydb;User ID=username;Password=pwd;Command Logging=false"
        This one is used with eInfoDesigns dbProvider, an add-on to .NET
      •  Declare the MySqlConnection:
        C#:
        using eInfoDesigns.dbProvider.MySqlClient;
        oMySqlConn.ConnectionString = "my connection string";
        oMySqlConn.Open();
        VB.NET:
        Imports eInfoDesigns.dbProvider.MySqlClient
        oMySqlConn.Open()
    •  SevenObjects MySqlClient (.NET)
      •  Standard:
        "Host=server; UserName=myusername; Password=mypassword;Database=mydb;"
        This is a freeware ADO.Net data provider from SevenObjects
    •  Core Labs MySQLDirect (.NET)
      •  Standard:
        "User ID=root; Password=pwd; Host=localhost; Port=3306; Database=test;Direct=true; Protocol=TCP; Compress=false; Pooling=true; Min Pool Size=0;Max Pool Size=100; Connection Lifetime=0"
  •  Interbase
    •  ODBC, Easysoft
      •  Local computer:
        "Driver={Easysoft IB6 ODBC};Server=localhost;Database=localhost:C:\mydatabase.gdb;Uid=username;Pwd=password"
      •  Remote Computer:
        "Driver={Easysoft IB6 ODBC};Server=ComputerName;Database=ComputerName:C:\mydatabase.gdb;Uid=username;Pwd=password"
        Read more about this driver: Easysoft ODBC-Interbase driver >>
    •  ODBC, Intersolv
      •  Local computer:
        "Driver={INTERSOLV InterBase ODBC Driver (*.gdb)};Server=localhost;Database=localhost:C:\mydatabase.gdb;Uid=username;Pwd=password"
      •  Remote Computer:
        "Driver={INTERSOLV InterBase ODBC Driver (*.gdb)};Server=ComputerName;Database=ComputerName:C:\mydatabase.gdb;Uid=username;Pwd=password"
        This driver are provided by DataDirect Technologies >> (formerly Intersolv)
    •  OLE DB, SIBPROvider
      •  Standard:
        "provider=sibprovider;location=localhost:;data source=c:\databases\gdbs\mygdb.gdb;user id=SYSDBA;password=masterkey"
      •  Specifying character set:
        "provider=sibprovider;location=localhost:;data source=c:\databases\gdbs\mygdb.gdb;user id=SYSDBA;password=masterkey;character set=ISO8859_1"
      •  Specifying role:
        "provider=sibprovider;location=localhost:;data source=c:\databases\gdbs\mygdb.gdb;user id=SYSDBA;password=masterkey;role=DIGITADORES"
        Read more about SIBPROvider >>
      Read more about connecting to Interbase in this Borland Developer Network article http://community.borland.com/article/0,1410,27152,00.html
  •  IBM DB2
    •  OLE DB, OleDbConnection (.NET) from ms
      •  TCP/IP:
        "Provider=DB2OLEDB;Network Transport Library=TCPIP;Network Address=XXX.XXX.XXX.XXX;Initial Catalog=MyCtlg;Package Collection=MyPkgCol;Default Schema=Schema;User ID=MyUser;Password=MyPW"
      •  APPC:
        "Provider=DB2OLEDB;APPC Local LU Alias=MyAlias;APPC Remote LU Alias=MyRemote;Initial Catalog=MyCtlg;Package Collection=MyPkgCol;Default Schema=Schema;User ID=MyUser;Password=MyPW"
    •  IBM's OLE DB Provider (shipped with IBM DB2 UDB v7 or above)
      •  TCP/IP:
        Provider=IBMDADB2;Database=sample;HOSTNAME=db2host;PROTOCOL=TCPIP;PORT=50000;uid=myUserName;pwd=myPwd;
    •  ODBC
      •  Standard:
        "driver={IBM DB2 ODBC DRIVER};Database=myDbName;hostname=myServerName;port=myPortNum;protocol=TCPIP; uid=myUserName; pwd=myPwd"
  •  Sybase
    •  ODBC
      •  Standard Sybase System 12 (or 12.5) Enterprise Open Client:
        "Driver={SYBASE ASE ODBC Driver};Srvr=Aron1;Uid=username;Pwd=password"
      •  Standard Sybase System 11:
        "Driver={SYBASE SYSTEM 11};Srvr=Aron1;Uid=username;Pwd=password;Database=mydb"
        For more information check out the Adaptive Server Enterprise Document Sets
      •  Intersolv 3.10:
        "Driver={INTERSOLV 3.10 32-BIT Sybase};Srvr=Aron1;Uid=username;Pwd=password;"
      •  Sybase SQL Anywhere (former Watcom SQL ODBC driver):
        "ODBC; Driver=Sybase SQL Anywhere 5.0; DefaultDir=c:\dbfolder\;Dbf=c:\mydatabase.db;Uid=username;Pwd=password;Dsn="""""
        Note! The two double quota following the DSN parameter at the end are escaped quotas (VB syntax), you may have to change this to your language specific escape syntax. The empty DSN parameter is indeed critical as not including it will result in error 7778.
        Read more in the Sybase SQL Anywhere User Guide (see part 3, chapter 13) >>
    •  OLE DB
      •  Adaptive Server Anywhere (ASA):
        "Provider=ASAProv;Data source=myASA"
        Read more in the ASA User Guide (part 1, chapter 2) >>
      •  Adaptive Server Enterprise (ASE) with Data Source .IDS file:
        "Provider=Sybase ASE OLE DB Provider; Data source=myASE"
        Note that you must create a Data Source .IDS file using the Sybase Data Administrator. These .IDS files resemble ODBC DSNs.
      •  Adaptive Server Enterprise (ASE):
        "Provider=Sybase.ASEOLEDBProvider;Srvr=myASEserver,5000;Catalog=myDBname;User Id=username;Password=password"
           - some reports on problem using the above one, try the following as an alternative -
        "Provider=Sybase.ASEOLEDBProvider;Server Name=myASEserver,5000;Initial Catalog=myDBname;User Id=username;Password=password"
        This one works only from Open Client 12.5 where the server port number feature works,?allowing fully qualified connection strings to be used without defining?any .IDS Data Source files.
    •  AseConnection (.NET)
      •  Standard:
        "Data Source='myASEserver';Port=5000;Database='myDBname';UID='username';PWD='password';"
      •  Declare the AseConnection:
        C#:
        using Sybase.Data.AseClient;
        AseConnection oCon = new AseConnection();
        oCon.ConnectionString="my connection string";
        oCon.Open();
        VB.NET:
        Imports System.Data.AseClient
        Dim oCon As AseConnection = New AseConnection()
        oCon.Open()
        Read more! Adaptive Server Enterprise ADO.NET Data Provider Documentation >>
  •  Informix
    •  ODBC
      •  Informix 3.30:
        "Dsn='';Driver={INFORMIX 3.30 32 BIT};Host=hostname;Server=myserver;Service=service-name;Protocol=olsoctcp;Database=mydb;UID=username;PWD=myPwd
      •  Informix-CLI 2.5:
        "Driver={Informix-CLI 2.5 (32 Bit)};Server=myserver;Database=mydb;Uid=username;Pwd=myPwd"
    •  OLE DB
      •  IBM Informix OLE DB Provider:
        "Provider=Ifxoledbc.2;password=myPw;User ID=myUser;Data Source=dbName@serverName;Persist Security Info=true"
  •  Ingres
    •  ODBC
      • DSN-less
        "Provider=MSDASQL.1;DRIVER=Ingres;SRVR=xxxxx;DB=xxxxx;Persist Security Info=False;uid=xxxx;pwd=xxxxx;SELECTLOOPS=N;Extended Properties="""SERVER=xxxxx;DATABASE=xxxxx;SERVERTYPE=INGRES""
  •  Mimer SQL
    •  ODBC
        "Driver={MIMER};Database=mydb;Uid=myuser;Pwd=mypw;"
        "Driver={MIMER};Database=mydb;"
  •  Lightbase
    •  Standard
      •  Standard:
        "user=USERLOGIN;password=PASSWORD;UDB=USERBASE;server=SERVERNAME"
  •  PostgreSQL
    •  Core Labs PostgreSQLDirect (.NET)
      •  Standard:
        "User ID=root; Password=pwd; Host=localhost; Port=5432; Database=testdb;Pooling=true; Min Pool Size=0; Max Pool Size=100; Connection Lifetime=0"
    •  PostgreSQL driver
      •  Standard:
        "DRIVER={PostgreSQL};SERVER=ipaddress;port=5432;DATABASE=dbname;UID=username;PWD=password;"
    •  Npgsql by pgFoundry (.NET)
      •  SSL activated:
        "Server=127.0.0.1;Port=5432;Userid=myuserid;password=mypw;Protocol=3;SSL=true;Pooling=true;MinPoolSize=3;MaxPoolSize=20;Encoding=UNICODE;Timeout=20;SslMode=Require"
         Without SSL:
        "Server=127.0.0.1;Port=5432;Userid=myuserid;password=mypw;Protocol=3;SSL=false;Pooling=true;MinPoolSize=1;MaxPoolSize=20;Encoding=UNICODE;Timeout=15;SslMode=Disable"
        Read more in the Npgsql: User's Manual and on the pgFoundry website.
  •  Paradox
    •  ODBC
      •  5.X:
        Driver={Microsoft Paradox Driver (*.db )};DriverID=538;Fil=Paradox 5.X;DefaultDir=c:\pathToDb\;Dbq=c:\pathToDb\;CollatingSequence=ASCII"
      •  7.X:
        "Provider=MSDASQL.1;Persist Security Info=False;Mode=Read;Extended Properties='DSN=Paradox;DBQ=C:\myDb;DefaultDir=C:\myDb;DriverId=538;FIL=Paradox 7.X;MaxBufferSize=2048;PageTimeout=600;';Initial Catalog=C:\myDb"
    •  OleDbConnection (.NET)
      •  Standard
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\myDb;Extended Properties=Paradox 5.x;"
        MS kb-article: How to use Paradox data with Access and Jet >>
  •  DSN
    •  ODBC
      •  DSN:
        "DSN=myDsn;Uid=username;Pwd=;"
      •  File DSN:
        "FILEDSN=c:\myData.dsn;Uid=username;Pwd=;"
  •  Firebird
    •  ODBC - IBPhoenix Open Source
      •  Standard:
        "DRIVER=Firebird/InterBase(r) driver;UID=SYSDBA;PWD=masterkey;DBNAME=D:\FIREBIRD\examples\TEST.FDB"
        IBPhoenix ODBC; More info, download etc >>
    •  .NET - Firebird .Net Data Provider
      •  Standard:
        "User=SYSDBA;Password=masterkey;Database=SampleDatabase.fdb;DataSource=localhost;Port=3050;Dialect=3;Charset=NONE;Role=;Connection lifetime=15;Pooling=true;MinPoolSize=0;MaxPoolSize=50;Packet Size=8192;ServerType=0"
        Firebird ADO.NET project >>
        Firebird ADO.NET downloads >>
  •  Excel
    •  ODBC
      •  Standard:
        "Driver={Microsoft Excel Driver (*.xls)};DriverId=790;Dbq=C:\MyExcel.xls;DefaultDir=c:\mypath;"
        TIP! SQL syntax: "SELECT * FROM [sheet1$]" - i.e. worksheet name followed by a "$" and wrapped in "[" "]" brackets.
    •  OLE DB
      •  Standard:
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\MyExcel.xls;Extended Properties=""Excel 8.0;HDR=Yes;IMEX=1"""
        "HDR=Yes;" indicates that the first row contains columnnames, not data
        "IMEX=1;" tells the driver to always read "intermixed" data columns as text
  •  Text
    •  ODBC
      •  Standard:
        "Driver={Microsoft Text Driver (*.txt; *.csv)};Dbq=c:\txtFilesFolder\;Extensions=asc,csv,tab,txt;"
    •  OLE DB
      •  Standard:
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\txtFilesFolder\;Extended Properties=""text;HDR=Yes;FMT=Delimited"""
  •  DBF / FoxPro
    •  ODBC
      •  standard:
        "Driver={Microsoft dBASE Driver (*.dbf)};DriverID=277;Dbq=c:\mydbpath;"
      •  standard:
        "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\folder;Extended Properties=dBASE IV;User ID=Admin;Password="
  •  AS/400 (iSeries)
      •  IBM Client Access OLE DB provider:
        "PROVIDER=IBMDA400; DATA SOURCE=MY_SYSTEM_NAME;USER ID=myUserName;PASSWORD=myPwd"
        Where MY_SYSTEM_NAME is the name given to the system connection in OperationsNavigator
        "PROVIDER=IBMDA400; DATA SOURCE=MY_SYSTEM_NAME;USER ID=myUserName;PASSWORD=myPwd;DEFAULT COLLECTION=MY_LIBRARY;"
        Where MY_SYSTEM_NAME is the name given to the System Connection, and MY_LIBRARY is the name given to the library in iSeries Navigator.
    •  ODBC
      •  IBM Client Access ODBC driver:
        "Driver={Client Access ODBC Driver (32-bit)};System=my_system_name;Uid=myUserName;Pwd=myPwd"
  •  Exchange
    •  OLE DB
      •  Exchange OLE DB provider:
        "ExOLEDB.DataSource"
        Specify store in the connection open command like this: conn.open "http://servername/mypublicstore"
        Check out this article at msdn >> and this one at Addison-Wesley >>
  •  Visual FoxPro
      •  Database container (.DBC):
        "Provider=vfpoledb.1;Data Source=C:\MyDbFolder\MyDbContainer.dbc;Collating Sequence=machine"
      •  Free table directory:
        "Provider=vfpoledb.1;Data Source=C:\MyDataDirectory\;Collating Sequence=general"
      •  Force the provider to use an ODBC DSN:
        ""Provider=vfpoledb.1;DSN=MyDSN""
        Read more (Microsoft msdn) >>
    •  ODBC
        "Driver={Microsoft Visual FoxPro Driver};SourceType=DBC;SourceDB=c:\myvfpdb.dbc;Exclusive=No;NULL=NO;Collate=Machine;BACKGROUNDFETCH=NO;DELETED=NO"
      •  Free Table directory:
        "Driver={Microsoft Visual FoxPro Driver};SourceType=DBF;SourceDB=c:\myvfpdbfolder;Exclusive=No;Collate=Machine;NULL=NO;DELETED=NO;BACKGROUNDFETCH=NO"
        "Collate=Machine" is the default setting, for other settings check the list of supported collating sequences >>
      Microsoft Visual Foxpro site: http://msdn.microsoft.com/vfoxpro
  •  Pervasive
    •  ODBC
      •  Standard:
        "Driver={Pervasive ODBC Client Interface};ServerName=srvname;dbq=@dbname"
        Pervasive ODBC info >>
    •  OLE DB
      •  Standard:
        "Provider=PervasiveOLEDB;Data Source=C:\path"
        Pervasive OLE DB info >>
  •  UDL
    •  UDL
      •  UDL:
        "File Name=c:\myDataLink.udl;"
  • 如对本文有疑问,请提交到交流论坛,广大热心网友会为你解答!! 点击进入论坛
    发表评论 (471人查看0条评论)
