您现在的位置: 365建站网 > 365文章 > jQuery Plugin 开发
jQuery Plugin 开发
文章来源:365jz.com     点击数:298    更新时间:2009-09-18 10:14   参与评论
1.Guideline:http://docs.jquery.com/Plugins/Authoring
2.Example:http://www.learningjquery.com/2007/10/a-plugin-development-pattern
3.重点:
a)inside plugin function , "this" is jQuery Object, not DOM element
b)should implement each method.
   code example:
  this.each(function(){
    //xxx
    this; // "this" is DOM element.
c) using alias "$"
code example :
(function($){
 //you can use $(selector) at here now
})(jQuery);
see my example for resizeImageByScale:
 1 /**
 2 * --------------------------------------------------------------------
 3 * jQuery-Plugin "resizeImage"
 4 * Version: 1.0, 20/07/2009
 5 * by Daniel <nevernet@msn.com>
 6 *
 7 * --------------------------------------------------------------------
 8 * @example jQuery("#imagesId").resizeImageByScale({ "maxWidth": 410, "maxHeight": 248 });
 9 * @desc resize all images size
10 *
11 * --------------------------------------------------------------------
12 */
13 (function($) {
14     $.fn.resizeImageByScale = function(options) {
15         var defaults = { "maxWidth"100"maxHeight"100 };
16
17         $.extend(defaults, options);
18
19         return this.each(function() {
20             var obj = $(this);
21             var t = new Image();
22             $(t).load(function() {
23                 var t1 = this//DOM element
24                 var toheight = defaults.maxHeight;
25                 var towidth = defaults.maxWidth;
26
27                 var aWidth = Math.round((t1.width / towidth) * 10000);
28                 var aHeight = Math.round((t1.height / toheight) * 10000);
29
30                 if (aWidth < aHeight) {
31                     toheight = defaults.maxHeight;
32                     towidth = Math.round(t1.width * defaults.maxHeight / t1.height);
33                 }
34                 else {
35                     towidth = defaults.maxWidth;
36                     toheight = Math.round(t1.height * defaults.maxWidth / t1.width);
37                 }
38
39                 obj.css({ "width": towidth, "height": toheight });
40             }).attr("src", obj.attr("src"));
41         });
42     }
43 })(jQuery);
发表评论 (298人查看0条评论)
