您现在的位置: 365建站网 > 365文章 > asp.页面,IIS
asp.页面,IIS
文章来源:365jz.com     点击数:135    更新时间:2009-09-19 10:34   参与评论
1.//弹出对话框.点击转向指定页面
Response.Write(&quot; <script>window.alert('该会员没有提交申请,请重新提交!')
</script>&quot;);
Response.Write(&quot; <script>window.location
='http://www.51aspx.com/bizpulic/upmeb.aspx' </script>&quot;);
2.//弹出对话框
Response.Write(&quot; <script language='javascript'>alert('产品添加成功!')
</script >&quot;);
3.//删除文件
string filename =&quot;20059595157517.jpg&quot;;
pub.util.DeleteFile(HttpContext.Current.Server.MapPath(&quot;../file/&quot;)
+filename);
4.//绑定下拉列表框datalist
System.Data.DataView dv=conn.Exec_ex(&quot;select -1 as code,'请选择经营模式'
as content from dealin union select code,content from dealin&quot;);
this.dealincode.DataSource=dv;
this.dealincode.DataTextField=&quot;content&quot;;
this.dealincode.DataValueField=&quot;code&quot;;
this.dealincode.DataBind();
this.dealincode.Items.FindByValue(dv[0][&quot;dealincode&quot;].ToString
()).Selected=true;
5.//时间去秒显示
<%# System.DateTime.Parse(DataBinder.Eval
(Container.DataItem,&quot;begtime&quot;).ToString()).ToShortDateString()%>
6.//标题带链接
<%# &quot; <a class=\&quot;12c\&quot; target=\&quot;_blank\&quot;
href=\&quot;http://www.51aspx/CV/_&quot;+DataBinder.Eval
(Container.DataItem,&quot;procode&quot;)+&quot;.html\&quot;>&quot;+
DataBinder.Eval(Container.DataItem,&quot;proname&quot;)+&quot; </a>&quot;%>
7.//修改转向
<%# &quot; <A href=\&quot;editpushpro.aspx?id=&quot;+DataBinder.Eval
(Container.DataItem,&quot;code&quot;)+&quot;\&quot;>&quot;+&quot;修改
&quot;+&quot; </A>&quot;%>
8.//弹出确定按钮
<%# &quot; <A id=\&quot;btnDelete\&quot; onclick=\&quot;return confirm('你是否
确定删除这条记录吗?');\&quot; href=\&quot;pushproduct.aspx?
dl=&quot;+DataBinder.Eval(Container.DataItem,&quot;code&quot;)
+&quot;\&quot;>&quot;+&quot;删除&quot;+&quot; </A>&quot;%>
9.//输出数据格式化 "{0:F2}" 是格式 F2表示小数点后剩两位
<%# DataBinder.Eval(Container, &quot;DataItem.PriceMoney&quot;,&quot;{0:F2}
&quot;) %>
10.//提取动态网页内容
Uri uri = new Uri(&quot;http://www.51aspx.com/&quot;);
  WebRequest req = WebRequest.Create(uri);
  WebResponse resp = req.GetResponse();
  Stream str = resp.GetResponseStream();
  StreamReader sr = new StreamReader(str,System.Text.Encoding.Default);
  string t = sr.ReadToEnd();
  this.Response.Write(t.ToString());
11.//获取" . "后面的字符
i.ToString().Trim().Substring(i.ToString().Trim().LastIndexOf(&quot;.&quot;)
+1).ToLower().Trim()
12. 打开新的窗口并传送参数:
  传送参数:
response.write(&quot;<script>window.open(’*.aspx?
id=&quot;+this.DropDownList1.SelectIndex+&quot;&amp;id1=&quot;+...+&quot;’)<
/script>&quot;)
接收参数:
string a = Request.QueryString(&quot;id&quot;);
string b = Request.QueryString(&quot;id1&quot;);
12.为按钮添加对话框
Button1.Attributes.Add(&quot;onclick&quot;,&quot;return confirm(’确认?’)
&quot;);
button.attributes.add(&quot;onclick&quot;,&quot;if(confirm(’are you sure...?
’)){return true;}else{return false;}&quot;)
13.删除表格选定记录
int intEmpID = (int)MyDataGrid.DataKeys[e.Item.ItemIndex];
string deleteCmd = &quot;Delete from Employee where emp_id = &quot; +
intEmpID.ToString()
14.删除表格记录警告
private void DataGrid_ItemCreated(Object sender,DataGridItemEventArgs e)
  switch(e.Item.ItemType)
  case ListItemType.Item :
  case ListItemType.AlternatingItem :
  case ListItemType.EditItem:
  TableCell myTableCell;
  myTableCell = e.Item.Cells[14];
  LinkButton myDeleteButton ;
  myDeleteButton = (LinkButton)myTableCell.Controls[0];
  myDeleteButton.Attributes.Add(&quot;onclick&quot;,&quot;return confirm(’
您是否确定要删除这条信息’);&quot;);
  break;
  default:
  break;
15.点击表格行链接另一页
private void grdCustomer_ItemDataBound(object sender,
System.Web.UI.WebControls.DataGridItemEventArgs e)
  //点击表格打开
  if (e.Item.ItemType == ListItemType.Item || e.Item.ItemType ==
ListItemType.AlternatingItem)
  e.Item.Attributes.Add(&quot;onclick&quot;,&quot;window.open(’
Default.aspx?id=&quot; + e.Item.Cells[0].Text + &quot;’);&quot;);
双击表格连接到另一页
  在itemDataBind事件中
if(e.Item.ItemType == ListItemType.Item || e.Item.ItemType ==
  string orderItemID =e.item.cells[1].Text;
  e.item.Attributes.Add(&quot;ondblclick&quot;,
&quot;location.href=’../ShippedGrid.aspx?id=&quot; + orderItemID + &quot;’
&quot;);
双击表格打开新一页
  e.item.Attributes.Add(&quot;ondblclick&quot;, &quot;open
(’../ShippedGrid.aspx?id=&quot; + orderItemID + &quot;’)&quot;);
16.表格超连接列传递参数
<asp:HyperLinkColumn Target=&quot;_blank&quot; headertext=&quot;ID号&quot;
DataTextField=&quot;id&quot; NavigateUrl=&quot;aaa.aspx?id=’
  <%# DataBinder.Eval(Container.DataItem, &quot;数据字段1&quot;)%>’ &amp;
name=’<%# DataBinder.Eval(Container.DataItem, &quot;数据字段2&quot;)%>’ /
17.表格点击改变颜色
if (e.Item.ItemType == ListItemType.Item ||e.Item.ItemType ==
(&quot;onclick&quot;,&quot;this.style.backgroundColor=’#99cc00’;
    this.style.color=’buttontext’;this.style.cursor=’default’;&quot;);
写在DataGrid的_ItemDataBound里
(&quot;onmouseover&quot;,&quot;this.style.backgroundColor=’#99cc00’;
e.Item.Attributes.Add(&quot;onmouseout&quot;,&quot;this.style.backgroundColor=
’’;this.style.color=’’;&quot;);
18.关于日期格式
  日期格式设定
DataFormatString="{0:yyyy-MM-dd}"
  我觉得应该在itembound事件中
e.items.cell["你的列"].text=DateTime.Parse(e.items.cell["你的
列"].text.ToString("yyyy-MM-dd"))
19.获取错误信息并到指定页面
不要使用Response.Redirect,而应该使用Server.Transfer
  e.g
// in global.asax
protected void Application_Error(Object sender, EventArgs e) {
if (Server.GetLastError() is HttpUnhandledException)
Server.Transfer(&quot;MyErrorPage.aspx&quot;);
//其余的非HttpUnhandledException异常交给ASP.NET自己处理就okay了 :)
  Redirect会导致post-back的产生从而丢失了错误信息,所以页面导向应该直接在服
务器端执行,这样就可以在错误处理页面得到出错信息并进行相应的处理
20.清空Cookie
Cookie.Expires=[DateTime];
Response.Cookies(&quot;UserName&quot;).Expires = 0
21.自定义异常处理
//自定义异常处理类
using System;
using System.Diagnostics;
namespace MyAppException
  /// <summary>
  /// 从系统异常类ApplicationException继承的应用程序异常处理类。
  /// 自动将异常内容记录到Windows NT/2000的应用程序日志
  /// </summary>
  public class AppException:System.ApplicationException
  public AppException()
  if (ApplicationConfiguration.EventLogEnabled)LogEvent(&quot;出现一个未知错误。&quot;);
  public AppException(string message)
  LogEvent(message);
  public AppException(string message,Exception innerException)
  LogEvent(message);
  if (innerException != null)
  LogEvent(innerException.Message);
  //日志记录类
  using System;
  using System.Configuration;
  using System.IO;
  using System.Text;
  using System.Threading;
  namespace MyEventLog
  /// <summary>
  /// 事件日志记录类,提供事件日志记录支持
  /// <remarks>
  /// 定义了4个日志记录方法 (error, warning, info, trace)
  /// </remarks>
  /// </summary>
  public class ApplicationLog
  /// <summary>
  /// 将错误信息记录到Win2000/NT事件日志中
  /// <param name=&quot;message&quot;>需要记录的文本信息</param>
  /// </summary>
  public static void WriteError(String message)
  WriteLog(TraceLevel.Error, message);
  /// <summary>
  /// 将警告信息记录到Win2000/NT事件日志中
  /// </summary>
  public static void WriteWarning(String message)
  WriteLog(TraceLevel.Warning, message);
  /// <summary>
  /// 将提示信息记录到Win2000/NT事件日志中
  /// </summary>
  public static void WriteInfo(String message)
  WriteLog(TraceLevel.Info, message);
  /// <summary>
  /// 将跟踪信息记录到Win2000/NT事件日志中
  /// </summary>
  public static void WriteTrace(String message)
  WriteLog(TraceLevel.Verbose, message);
  /// <summary>
  /// 格式化记录到事件日志的文本信息格式
  /// <param name=&quot;ex&quot;>需要格式化的异常对象</param>
  /// <param name=&quot;catchInfo&quot;>异常信息标题字符串.</param>
  /// <retvalue>
  /// <para>格式后的异常信息字符串,包括异常内容和跟踪堆栈.</para>
  /// </retvalue>
  /// </summary>
  public static String FormatException(Exception ex, String catchInfo)
  StringBuilder strBuilder = new StringBuilder();
  if (catchInfo != String.Empty)
  strBuilder.Append(catchInfo).Append(&quot;\r\n&quot;);
  strBuilder.Append(ex.Message).Append(&quot;\r\n&quot;).Append(ex.StackTrace);
  return strBuilder.ToString();
  /// <summary>
  /// 实际事件日志写入方法
  /// <param name=&quot;level&quot;>要记录信息的级别(error,warning,info,trace).</param>
  /// <param name=&quot;messageText&quot;>要记录的文本.</param>
  /// </summary>
  private static void WriteLog(TraceLevel level, String messageText)
  try
  EventLogEntryType LogEntryType;
  switch (level)
  case TraceLevel.Error:
  LogEntryType = EventLogEntryType.Error;
  break;
  case TraceLevel.Warning:
  LogEntryType = EventLogEntryType.Warning;
  break;
  case TraceLevel.Info:
  LogEntryType = EventLogEntryType.Information;
  break;
  case TraceLevel.Verbose:
  LogEntryType = EventLogEntryType.SuccessAudit;
  break;
  default:
  break;
  EventLog eventLog = new EventLog(&quot;Application&quot;, ApplicationConfiguration.EventLogMachineName, ApplicationConfiguration.EventLogSourceName );
  //写入事件日志
  eventLog.WriteEntry(messageText, LogEntryType);
  catch {} //忽略任何异常
  } //class ApplicationLog
22.Panel 横向滚动,纵向自动扩展
<asp:panel style=&quot;overflow-x:scroll;overflow-y:auto;&quot;></asp:panel>
23.回车转换成Tab
(1)
<script language=&quot;javascript&quot; for=&quot;document&quot; event=&quot;onkeydown&quot;>
  if(event.keyCode==13 &amp;&amp; event.srcElement.type!=’button’ &amp;&amp; event.srcElement.type!=’submit’ &amp;&amp;     event.srcElement.type!=’reset’ &amp;&amp; event.srcElement.type!=’’&amp;&amp; event.srcElement.type!=’textarea’);
  event.keyCode=9;
(2)  //当在有keydown事件的控件上敲回车时,变为tab
public void Tab(System.Web .UI.WebControls .WebControl webcontrol)
webcontrol.Attributes .Add (&quot;onkeydown&quot;, &quot;if(event.keyCode==13) event.keyCode=9&quot;);
24.DataGrid超级连接列
DataNavigateUrlField=&quot;字段名&quot; DataNavigateUrlFormatString=&quot;http://xx/inc/delete.aspx?ID={0}&quot;
25.DataGrid行随鼠标变色
private void DGzf_ItemDataBound(object sender, System.Web.UI.WebControls.DataGridItemEventArgs e)
  if (e.Item.ItemType!=ListItemType.Header)
  e.Item.Attributes.Add( &quot;onmouseout&quot;,&quot;this.style.backgroundColor=\&quot;&quot;+e.Item.Style[&quot;BACKGROUND-COLOR&quot;]+&quot;\&quot;&quot;);
  e.Item.Attributes.Add( &quot;onmouseover&quot;,&quot;this.style.backgroundColor=\&quot;&quot;+ &quot;#EFF3F7&quot;+&quot;\&quot;&quot;);
26.模板列
<ASP:TEMPLATECOLUMN visible=&quot;False&quot; sortexpression=&quot;demo&quot;
headertext=&quot;ID&quot;>
<ITEMTEMPLATE>
<ASP LABEL text=’<%# DataBinder.Eval(Container.DataItem,
&quot;ArticleID&quot;)%>’ runat=&quot;server&quot; width=&quot;80%&quot;
id=&quot;lblColumn&quot; />
</ITEMTEMPLATE>
</ASP:TEMPLATECOLUMN>
<ASP:TEMPLATECOLUMN headertext=&quot;选中&quot;>
<HEADERSTYLE wrap=&quot;False&quot; horiz></HEADERSTYLE>
<ITEMTEMPLATE>
<ASP:CHECKBOX id=&quot;chkExport&quot; runat=&quot;server&quot; />
</ITEMTEMPLATE>
<EDITITEMTEMPLATE>
<ASP:CHECKBOX id=&quot;chkExportON&quot; runat=&quot;server&quot;
enabled=&quot;true&quot; />
</EDITITEMTEMPLATE>
后台代码
protected void CheckAll_CheckedChanged(object sender, System.EventArgs e)
  //改变列的选定,实现全选或全不选。
  CheckBox chkExport ;
  if( CheckAll.Checked)
  foreach(DataGridItem oDataGridItem in MyDataGrid.Items)
  chkExport = (CheckBox)oDataGridItem.FindControl(&quot;chkExport&quot;);
  chkExport.Checked = true;
  else
  chkExport.Checked = false;
>>step1
【工具】->【外部工具】->按【添加】输入:
1)标题:Web Server Port:8080
2)命令:C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\WebDev.WebServer.EXE
3)参数:/port:8080 /path:$(ProjectDir)
4)【使用输出窗口】选上
>>>step2
点击step1后在【工具】菜单上出现的“Web Server Port:8080”选项,激活自定义Web Server服务器,激活后窗口右下角会出现一个“asp.net development server”图标。
>>>step3
在网站上右击选择【属性页】->【启动选项】->【使用自定义服务器】,在基URL输入 http://localhost:8080/
>>>step4
记得要把该网站或项目的IIS上的运行端口也要改成8080:IIS--找到你的项目网站,并且右击--将端口改成8080
发表评论 (135人查看0条评论)
