您现在的位置: 365建站网 > 365文章 > [转载]SqlConnection,SqlCommand,SqldataReader的用法总结:
文章来源:365jz.com     点击数:2399    更新时间:2009-09-19 10:36   参与评论
http://www.cnblogs.com/winner/archive/2008/01/09/1032651.html
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Data.SqlClient;
public partial class _Default : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
//-------------------SqlConnection,SqlCommand,SqldataReader的用法-------------------//
//下面的4种形式等价,如果你的数据库是Windows连接方法,直接把连接字符串改成"server=.;database=northwind;integrated security=true;"
//如果你的数据库是某个实例名,直接把"server=."改成"server=你的计算机名实例名"就可以了
        SqlConnection con
= new SqlConnection();
        con.ConnectionString
= "server=.;database=northwind;uid=sa;pwd=;";  //双引号中的最后一个分号可以去掉
        con.Open();
        SqlCommand cmd
= con.CreateCommand();
        cmd.CommandText
= "select * from customers";
        SqlDataReader sdr
= cmd.ExecuteReader();
this.GridView1.DataSource = sdr;
this.GridView1.DataBind();
        sdr.Close();
        con.Close();
//SqlConnection con = new SqlConnection();
//con.ConnectionString = "server=.;database=northwind;uid=sa;pwd=;";   //双引号中的最后一个分号可以去掉
//con.Open();
//SqlCommand cmd = new SqlCommand("select * from customers");
//cmd.Connection = con;
//SqlDataReader sdr = cmd.ExecuteReader();
//this.GridView1.DataSource = sdr;
//this.GridView1.DataBind();
//sdr.Close();
//con.Close();
////我最经常用这一种,同时连接对象是整个程序的公共对象,所以我一般会把数据库连接封装到一个类中,这样就可以在程序的任何地方随时调用
        //SqlConnection con = new SqlConnection("server=.;database=northwind;uid=sa;pwd=;"); //双引号中的最后一个分号可以去掉
//con.Open();
//SqlCommand cmd = new SqlCommand("select * from customers", con);
//sdr.Close();
//con.Close();
//con.Open();
//SqlCommand cmd = new SqlCommand();
//cmd.CommandText = "select * from customers";
//cmd.CommandType = CommandType.Text;  //这条语句是多余的,因为默认就是Text
//sdr.Close();
//con.Close();
发表评论 (2399人查看0条评论)
