您现在的位置: 365建站网 > 365文章 > 一个ajax.Net库的使用例子--下拉框联动
文章来源:365jz.com     点击数:743    更新时间:2009-09-20 09:02   参与评论
Default.aspx.cs
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
namespace AjaxText
public partial class _Default : System.Web.UI.Page
public ArrayList DataSource = new ArrayList();
protected void Page_Load(object sender, EventArgs e)
            Ajax.Utility.RegisterTypeForAjax(
typeof(_Default));
/// <summary>
/// 初始化数据源
/// </summary>
        public void initDataSource()
            DataSource.Add(
new address("湖南""长沙"));
            DataSource.Add(
new address("湖南""衡阳"));
            DataSource.Add(
new address("湖南""郴州"));
            DataSource.Add(
new address("湖南""岳阳"));
            DataSource.Add(
new address("广东""广州"));
            DataSource.Add(
new address("广东""清远"));
            DataSource.Add(
new address("广东""汕头"));
            DataSource.Add(
new address("湖北""武汉"));
            DataSource.Add(
new address("湖北""十堰"));
            DataSource.Add(
new address("湖北""仙桃"));
            DataSource.Add(
new address("湖北""天门"));
/// <summary>
/// 获取第一个下拉框的数据。
/// </summary>
/// <returns></returns>
        [Ajax.AjaxMethod]
public string GetFirstSelectData()
            initDataSource();
            ArrayList arr
= new ArrayList();
foreach (address add in DataSource)
if (!arr.Contains(add.strProvince))
                    arr.Add(add.strProvince);
string result = "";
foreach (string str in arr)
                result
+= str + ";";
if (result.Length > 0)
                result
= result.Substring(0, result.Length - 1);
return result;
/// <summary>
/// 根据省份获取城市。
/// </summary>
/// <param name="province"></param>
        [Ajax.AjaxMethod]
public string GetCitys(string province)
            initDataSource();
string result = "";
if (province != null && province != string.Empty)
if (add.strProvince == province)
                        result
+= add.strCity + ";";
                result
return result;
//地址对象实体类
        public class address
public string strProvince;
public string strCity;
public address(string province,string city)
                strProvince
= province;
                strCity
= city;
Default.aspx页面的html代码
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Default.aspx.cs" Inherits="AjaxText._Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<title>无标题页</title>
<script language="javascript" type="text/javascript">
//初始化第一个下拉框,从服务端读取数据。
    //其实这里应该直接在服务端绑定数据,此处为了演示ajax特地也使用ajax技术绑定数据。
    function initSelect1()
var Data=_Default.GetFirstSelectData().value
var strData=new String(Data);
var select1=document.getElementById("aa");
          select1.options.length
= 0
var arr=strData.split(";");
for(var i=0;i<arr.length;i++)
var varItem = new Option(arr[i],arr[i]);
             select1.options.add(varItem);
//第一个下拉框更改选择时,ajax调用服务端方法更新第二个下拉框数据。
    function selectchanged()
var Data=_Default.GetCitys(select1.value).value;
var select2=document.getElementById("bb");
          select2.options.length
= 0
             select2.options.add(varItem);
<body onload="initSelect1()">
<form id="form1" runat="server">
<div>
<select id="aa" onchange="selectchanged()">
<option>unbounded</option>
</select>
<br /><br />
<select id="bb">
</select>
</div>
</form>
使用ajax.net时应该注意的问题:
1.在pageload事件中
Ajax.Utility.RegisterTypeForAjax(typeof(_Default));
这句必须是typeof(命名空间.类名),而不能是this.GetType()等。javascript中调用的时候直接用这里的类名。
2.调用服务端方法后加.value
如_Default.GetCitys(select1.value).value
发表评论 (743人查看0条评论)
