您现在的位置: 365建站网 > 365文章 > 反编译 解密 google tool bar 的PageRank
文章来源:365jz.com     点击数:462    更新时间:2009-09-22 09:38   参与评论
   google的PageRank,虽然各大网站都能查询,但是,具体是从google 哪个数据源来的?幸运的是,google tool bar
上有pagerank的值。Sniffer 会告诉你,大概是从:
GET /search?client=navclient-auto&iqrn=-WM&orig=0BATi&ie=UTF-8&oe=UTF-8&features=Rank:WH:&q=info:http%3a%2f%2fwww.sina.com.cn%2f&googleip=O;74.125.153.147;297&ch=772063278971 HTTP/1.1
User-Agent: Mozilla/4.0 (compatible; GoogleToolbar 6.2.1910.1554; Windows XP 5.1; MSIE 8.0.6001.18702)
Host: toolbarqueries.google.com
Connection: Keep-Alive
Cache-Control: no-cache
toolbarqueries.google.com  这个主机进行查询的。
看上去好像换一下 q 变量就可以请求了。但是,发现不可以。我翻遍了很多论坛,几乎都是转载,而且都不能运行代码。
后来,在一个国外论坛里面找到了一段代码。但是也用不了。找了多段代码,都用不了,但是我发现核心算法都差不多。
经过我修修改改。下面这段终于可以了:
<?php
Written and contributed by
Alex Stapleton,
Andy Doctorow,
Tarakan,
Bill Zeller,
Vijay "Cyberax" Bhatter
traB
This code is released into the public domain
define('GOOGLE_MAGIC', 0xE6359A60);
//unsigned shift right
function zeroFill($a, $b
$z = hexdec(80000000);
if ($z & $a
$a = ($a>>1);
$a &= (~$z);
$a |= 0x40000000
$a = ($a>>($b-1));
else
$a = ($a>>$b);
return $a
function mix($a,$b,$c) {
$a -= $b$a -= $c$a ^= (zeroFill($c,13));
$b -= $c$b -= $a$b ^= ($a<<8);
$c -= $a$c -= $b$c ^= (zeroFill($b,13));
$a -= $b$a -= $c$a ^= (zeroFill($c,12));
$b -= $c$b -= $a$b ^= ($a<<16);
$c -= $a$c -= $b$c ^= (zeroFill($b,5));
$a -= $b$a -= $c$a ^= (zeroFill($c,3));
$b -= $c$b -= $a$b ^= ($a<<10);
$c -= $a$c -= $b$c ^= (zeroFill($b,15));
return array($a,$b,$c);
function GoogleCH($url, $length=null, $init=GOOGLE_MAGIC) {
if(is_null($length)) {
$length = sizeof($url);
$a = $b = 0x9E3779B9
$c = $init
$k = 0
$len = $length
while($len >= 12) {
$a += ($url[$k+0+($url[$k+1]<<8+($url[$k+2]<<16+($url[$k+3]<<24));
$b += ($url[$k+4+($url[$k+5]<<8+($url[$k+6]<<16+($url[$k+7]<<24));
$c += ($url[$k+8+($url[$k+9]<<8+($url[$k+10]<<16)+($url[$k+11]<<24));
$mix = mix($a,$b,$c);
$a = $mix[0]; $b = $mix[1]; $c = $mix[2];
$k += 12;
$len -= 12
$c += $length
switch($len)              /* all the case statements fall through */
case 11: $c+=($url[$k+10]<<24);
case 10: $c+=($url[$k+9]<<16);
case 9 : $c+=($url[$k+8]<<8);
/* the first byte of c is reserved for the length */
case 8 : $b+=($url[$k+7]<<24);
case 7 : $b+=($url[$k+6]<<16);
case 6 : $b+=($url[$k+5]<<8);
case 5 : $b+=($url[$k+4]);
case 4 : $a+=($url[$k+3]<<24);
case 3 : $a+=($url[$k+2]<<16);
case 2 : $a+=($url[$k+1]<<8);
case 1 : $a+=($url[$k+0]);
/* case 0: nothing left to add */
/*-------------------------------------------- report the result */
return $mix[2];
//converts a string into an array of integers containing the numeric value of the char
function strord($string) {
for($i=0;$i<strlen($string);$i++) {
$result[$i= ord($string{$i});
return $result
// converts an array of 32 bit integers into an array with 8 bit values. Equivalent to (BYTE *)arr32
function c32to8bit($arr32) {
for($i=0;$i<count($arr32);$i++) {
for ($bitOrder=$i*4;$bitOrder<=$i*4+3;$bitOrder++) {
$arr8[$bitOrder]=$arr32[$i]&255
$arr32[$i]=zeroFill($arr32[$i], 8);
return $arr8
// http://www.example.com/ - Checksum: 6540747202
function getCheckSum($url, $isnewversion = false)
$url = 'info:' . $url;
$ch = GoogleCH(strord($url));
//Checksum < 2.0.114
    if ($isnewversion) {
$ch = ((($ch/7<< 2| (((int)fmod($ch,13))&7));
$prbuf = array();
$prbuf[0= $ch
for($i = 1$i < 20$i++) {
$prbuf[$i= $prbuf[$i-1]-9
$ch = GoogleCH(c32to8bit($prbuf), 80);
$ch = sprintf("6%u", $ch);
return $ch;
function getPageRank($url, $isnewversion = false)
$ch = getCheckSum($url, $isnewversion);
$url = 'info:' . urlencode($url);
$q = "http://toolbarqueries.google.com/search?client=navclient-auto&features=Rank:WH:&q=$url&ch=$ch";
return file_get_contents($q);
echo getPageRank($_GET['q']);
调用就一句话。解密的算法是通过反汇编得到的。不知道,博客园有没有知道google 执行了什么加密算法计算
ch。我看了以后,是不知所云。
Tag标签: PageRank,反编译,解密
作者资料:
暮夏
我的主页  个人资料
我的闪存  与我联系
发表评论 (462人查看0条评论)
