您现在的位置: 365建站网 > 365文章 > Flex过滤器
Flex过滤器
文章来源:365jz.com     点击数:388    更新时间:2009-09-24 22:32   参与评论
DEMO:
http://hi.baidu.com/candypopoo1986/blog/item/afa0932846c52a91023bf6ef.html
mxml:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml" creationComplete="ini()" layout="absolute" height="299" width="328" backgroundColor="#FFFFFF">
<mx:Script>
   <![CDATA[
    import mx.controls.List;
    import mx.collections.ArrayCollection;
    import mx.controls.Alert;
    [Bindable]
    public var Arr:ArrayCollection = new ArrayCollection([{name:"popoo",age:23,sal:30000},{name:"haha",age:12,sal:4000},{name:"bobo",age:10,sal:2322},{name:"hoho",age:3,sal:20202}]);
    public function ini():void{
     Arr.filterFunction = filter;
     Arr.refresh();
    public function filter(value:Object):Object
     var str:String = select.selectedItem.name;
     if(Number(value[str]>int(t1.text))){
      return true;
     return false;
</mx:Script>
<mx:DataGrid dataProvider="{Arr}" fontSize="12" x="10" y="10">
   <mx:columns>
    <mx:DataGridColumn headerText="姓名" dataField="name"/>
    <mx:DataGridColumn headerText="年龄" dataField="age"/>
    <mx:DataGridColumn headerText="工资" dataField="sal" />
   </mx:columns>
</mx:DataGrid>
<mx:TextInput id="t1" x="126" y="192" />
<mx:Button x="10" y="240" fontSize="12" label="查询" click="ini()"/>
<mx:ComboBox id="select" x="10" y="192" width="66" fontSize="12">
<mx:Object label="年龄" name="age" />
<mx:Object label="工资" name="sal" />
</mx:ComboBox>
<mx:Label x="94" y="194" text="大于" fontSize="12"/>
</mx:Application>
这种机制在于重新删选了dataProvider中的ArrayCollection 数据,设置数据绑定后,重写filterFunction 方法,就会根据过滤内容进行重新展示
发表评论 (388人查看0条评论)
