您现在的位置: 365建站网 > 365文章 > [orginal]Combolist visual design & and implementation (
文章来源:365jz.com     点击数:378    更新时间:2009-10-04 11:11   参与评论
Physical structure:
An easy to see that the combolist consist of three(body,head,list)main parts these parts are combine to complete the physical structure of the combolist control , in this article I will try to explain  an easy way how to create  combolist control  From Scratch , not nice look one only but also with straight main operations ,methods and properties .
 pic1
as you see above the pic1 contain the three parts are
1-body :the plot where the selected item is placed
2-head: the plot that we can control the hiding and show the element list.
3-list: the plot that contain all combolist elements(items)
logical structure of combolist :
we discuss the logical structure  from  three aspects(css,js,and html)
the css to control the style ( make nice  or the dress it up )
the css style is tracing the pic1  three parts.
/*div tag*/
.ComboList
    width
:200px;
    height
:400px;
    margin-left
:0px;
    margin-top
:0px;
    font-family
: 宋体;
    font-size
:12px;
    color
:black;
    cursor
:default;
/*span*/
.ComboList .headPar
    width
:17px;
    height
:21px;
    margin-left
:182px;
    position
:absolute;
    background-image
:url('images/combolist.png');
    background-repeat
:no-repeat;
/*input tag*/
.ComboList .bodyPart
    border-top
: 1px #3D7BAD solid;
    border-bottom
: 1px #B7D9ED solid;
    border-left
:1px #A4C9E3 solid;
    border-right
:1px #A4C9E3 solid;
    height
:17px;
    position
:absolute;
    width
:181px;
    font-family
: 宋体;
    font-size
:12px;
    color
:black;
/*ul*/
.ComboList .ListPart
    margin-top
:21px;
    margin-left
:0px;
    height
:auto;
    overflow
:auto;
    position
:absolute;
    width
:183px;
    border
    border-top
:1px transparent solid;
    list-style-type
:none;
    display
:none;
/*li*/
.ListPart .ComboListItem
   display
:block;
   width
:inherit;
   height
:21px;
   padding
: 1px 0px 0px 3px;
/*when mouse move */
.ComboListItem:hover
 background-image
:url('images/BGline.png');
 background-repeat
:repeat-x;
Java script aspects:
for js point of view we just consider the operation,methods and properties that the combolist have to contain, for example the selected index ,
selected item , add new item,remove item ,and high level operations like sorting of item.
//style nice looking when mouse move,ou,up/
function changeState( element ,height ,statNumber)
//statNumber the number of state we want to show currently
      // elemnt is imageBackground for span
     /// 0: normal status,1 mouseMove status,2 mousepress status, 3 fucuse,4 disable ,5 no
     var top=height*statNumber;
// alert('100% -'+left+'px');
     document.getElementById(element).style.backgroundPosition='100% -'+top+'px';
function chageBorderColorWhenMouseMove(element)
     document.getElementById(element).style.borderBottom
='1px #3D7BAD  solid';
     document.getElementById(element).style.borderRight
     document.getElementById(element).style.borderLeft
function chageBorderColorWhenMouseOut(element)
='1px #B7D9ED solid';
function ShowComboList(element)
    document.getElementById(element).style.display
='block';
function HideComboList(element)
='none';
//----------------------selection and add new items
var ComboListItemIndex=-1;
var ComboListSelectedindex=-1;
var ComboListselectedItem="";
function ComboListAddNewListItem(ComboxListId)
       ComboListItemIndex
=ComboListItemIndex+1;
var NewItemString="<li id=ComboListItem"+ComboListItemIndex+" class=ComboListItem onclick=ComboListSelectedIndex(this);ComboListSelectedItem(this);>item"+ComboListItemIndex+"</li>";
var listBoxOldElemtns=document.getElementById(ComboxListId).innerHTML;
var newListboxItem=listBoxOldElemtns+NewItemString;
=newListboxItem;
// return the  selected index of the combo list
 function ComboListSelectedIndex(elThis)
var name=elThis.id;
// get the index.
       ComboListSelectedindex=name.charAt((name.length)-1);
return ComboListSelectedindex;
function ComboListSelectedItem(elThis)
var Item=elThis.innerHTML;
'InputBody').value=Item;
       HideComboList(
'ListPart');
return Item;
function ComboListGetItem(index)
var re="";
if(index>-1 && index<=ComboListItemIndex)
var name="ComboListItem"+index;
       re
=document.getElementById(name).innerHTML;
else
     alert(
'Out Of Rang Index');
return re;
// SET VALUE IN SPECIFIC INDEX POSITION
 function ComboListSetItem(index,value)
=value;
else
     alert(
// FUNCTION LENGTH;
//-1 for empty.
   function ComboListLength()
return  ComboListItemIndex;
sorting element of combolist :
whatever you used mean the sorting algorithm ,insertion sort,quicksort ,heapsort ,just invoke the combolist sort method like code below ,
here i used the array  bufferCombolist ,js provide sorting  function for array
function ComboListSort()
      ComboListBuffer.sort();
for(var x=0;x<=ComboListLength();x++)
      ComboListSetItem(x,ComboListBuffer[x]);
html aspect :
from html point of view we just think the combolist as below:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<meta content="text/html; charset=utf-8" http-equiv="Content-Type" />
<title>Untitled 1</title>
<link rel="stylesheet" type="text/css" href="combolist.css"/>
<script language="javascript" type="text/javascript" src="combolist.js"></script>
<div class="ComboList">
<span id="HeaderSpan" class="headPar" onmousemove="changeState('HeaderSpan',21,1);chageBorderColorWhenMouseMove('InputBody');"  onmouseout="changeState('HeaderSpan',21,0);chageBorderColorWhenMouseOut('InputBody')"  onmousedown="changeState('HeaderSpan',21,2);ShowComboList('ListPart');"  onmouseup="changeState('HeaderSpan',21,1);"></span>
<input id="InputBody" class="bodyPart" value=""/>
<ul id="ListPart" class="ListPart">
</ul>
</div>
<href="#" onclick="ComboListAddNewListItem('ListPart');">add New Item </a>&nbsp;
<href="#" onclick="ComboListGetItem('2');">get(i) </a>
&nbsp;
<href="#" onclick="ComboListSetItem('2','AMMAR');">set(i,value)</a>
Tag标签: css,js,web,combolist
发表评论 (378人查看0条评论)
