asp.net Ctrl+回车提交
文章来源:365jz.com 点击数:
513 更新时间:2009-10-07 10:47
参与评论
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Submit.aspx.cs" Inherits="test_Submit" %>
<head runat="server">
<title>asp.net Ctrl+回车提交</title>
//这种提交在asp.net下不会执行后台代码
function submitForm(formName) {
if(window.event.ctrlKey&&window.event.keyCode==13) {
document.getElementById(formName).submit();
//相当于按了一下提交按钮,所以此法在asp.net可行
function clickButton() {
document.getElementById("btnOk").click();
<form id="form1" runat="server" name="form1">
<div>
<asp:TextBox ID="txtContent" runat="server" TextMode="MultiLine" onkeydown="submitForm(this.form.name);"></asp:TextBox>
<br />
<asp:TextBox ID="txtBody" runat="server" TextMode="MultiLine" onkeydown="clickButton();"></asp:TextBox>
<br />
<asp:Button ID="btnOk" runat="server" Text="提交" onclick="btnOk_Click" />
</div>
</form>
using System;
using System.Collections;
using System.Configuration;
using System.Data;
using System.Linq;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.HtmlControls;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Xml.Linq;
public partial class test_Submit : System.Web.UI.Page
protected void btnOk_Click(object sender, EventArgs e)
Page.ClientScript.RegisterClientScriptBlock(this.GetType(), "alert", "<script>alert('提交成功!')</script>", false);
