您现在的位置: 365建站网 > 365文章 > JSP实现HTTP隧道
JSP实现HTTP隧道
文章来源:365jz.com     点击数:305    更新时间:2009-10-14 10:51   参与评论
共有两个java类和一个servlet(在同一个java包JavaSerializable中):
java:StudentList   StudentListTunnetApp(客户端)
servlet:StudentListTunnetServlet(服务器端)
StudentList(java类)定义一个类,StudentListTunnetApp(java类)运行在客户端,实例化一个StudentList对象并将其写到与StudentListTunnetServlet连接的HTTP中,然后发送请求到服务器端StudentListTunnetServlet(servlet)读取先前写入连接的StudentList对象
1.StudentList.java:
 * @author lucifer
package JavaSerializable;
import java.util.*;
import java.io.*;
public class StudentList implements Serializable{
     Vector list = new Vector(6);
     public StudentList(){}
     public void addStudent(String name){
          if(name != null)
               list.addElement(name);
     public void listStudent(){
          for(int i = 0;i < list.size();i++){
               System.out.println("Student" + i + ":" + (String)list.elementAt( i ));
2.StudentListTunnetApp.java:
 * @author lucifer
import java.io.*;
import java.net.*;
public class StudentListTunnetApp {
     public StudentListTunnetApp(){}
     public void buildStudentList(StudentList list){
          list.addStudent("Bob Robinson");
          list.addStudent("Steve Robinson");
          list.addStudent("Rob Stevinson");
          list.addStudent("Tod Thomson");
          list.addStudent("Jack Jones");
          list.addStudent("Micheal Jackson");
     public void writeStudentList(URLConnection connection,StudentList list){
          try{
               //ignore caching
               connection.setUseCaches(false);
                  connection.setRequestProperty("CONTENT_TYPE","application/octet-stream");
                  //使得发送和接收能使用用一个连接
                  connection.setDoInput(true);
                  connection.setDoOutput(true);
               ObjectOutputStream os = new ObjectOutputStream(connection.getOutputStream());
               System.err.println("Writing an object.");
               os.writeObject( list );
               os.flush();
               os.close();
          catch(IOException e){
               System.err.println(e.getMessage());
     public StudentList readStudentList(URLConnection connection){
          StudentList list = null;
          try{
               ObjectInputStream is = new ObjectInputStream(connection.getInputStream());
               System.err.println("Waiting for response.");
               list = (StudentList)is.readObject();
               is.close();
          catch(ClassNotFoundException e){
          return list;
     public void invoke(){
          try{
               URL url = new URL("http://localhost:8084/LearnServlet/StudentListTunnetServlet");
               StudentList list = new StudentList();
               buildStudentList(list);
               list.listStudent();
               System.err.println("Opening an connection.");
               URLConnection connection = url.openConnection();
               writeStudentList(connection,list);
               StudentList inlist = readStudentList(connection);
               if(inlist != null){
                    inlist.listStudent();
               else{
                    System.err.println("readObject failed.");
               System.out.println("press enter to quit.");
               System.in.read();
          catch(MalformedURLException e){
          catch(Exception e){
     public static void main(String[] args){
          StudentListTunnetApp studentlist = new StudentListTunnetApp();
          studentlist.invoke();
3.StudentListTunnetServlet.java(servlet):
 * @author lucifer
import java.io.*;
import javax.servlet.*;
import javax.servlet.http.*;
public class StudentListTunnetServlet extends HttpServlet {
    protected void processRequest(HttpServletRequest request, HttpServletResponse response)
    throws ServletException, IOException {
        response.setContentType("text/html;charset=UTF-8");
        PrintWriter out = response.getWriter();
        try {
            /* TODO output your page here
            out.println("<html>");
            out.println("<head>");
            out.println("<title>Servlet StudentListTunnetServlet</title>");
            out.println("</head>");
            out.println("<body>");
            out.println("<h1>Servlet StudentListTunnetServlet at " + request.getContextPath () + "</h1>");
            out.println("</body>");
            out.println("</html>");
        } finally {
            out.close();
    @Override
    //用的是这个方法
    public void service (HttpServletRequest request,HttpServletResponse response)throws ServletException,IOException{
         try{
              ObjectInputStream ois = new ObjectInputStream(request.getInputStream());
              StudentList list = (StudentList)ois.readObject();
              response.setContentType("application/octet-stream");
              ObjectOutputStream oos = new ObjectOutputStream(response.getOutputStream());
              oos.writeObject(list);
              oos.flush();
              oos.close();
    @Override
    public void init(ServletConfig config)throws ServletException{
         super.init(config);
    @Override
    protected void doGet(HttpServletRequest request, HttpServletResponse response)
        processRequest(request, response);
    @Override
    protected void doPost(HttpServletRequest request, HttpServletResponse response)
    @Override
    public String getServletInfo() {
        return "Short description";
发表评论 (305人查看0条评论)
