最近一直在忙dotnetnuke,没有时间来学点jQuery的东西,我真的是jQuery的超级fans,所以今天还是学点jQuery的东西并和大家分享一下。
以前我翻译过一个如何写jQuery插件的经典文章,这里再给出来一个相当好的,理论加例子的文章。
In case you want to share your plugin with others it can be a good idea to stick to the conventions of plugin authoring. Pick a suitable name like “myPlugin” and name your file jquery.myPlugin.js. Next thing is to define a function body.
Wrapping everything inside an anonymous function and passing jQuery into it makes sure it doesn’t conflict with other libraries that uses ‘$’ as a shorthand (Don’t worry too much about this for now).
I’m going to call the first plugin “tabify”. The objective is to add some tabs to the following content.
Inside your plugin add the following:
An object passed through the plugin will now return a function. I also created a reference “obj” to the object currently inside the function. Add the following inside your “this.each” statement:
Clicking #someContent should result in a red background. You could pass any object into the plugin. $(‘#someContent h2’) will set a red background to any “h2” within #someContent that is clicked.
Here’s the code for jquery.tabify with included comments. I’m hoping you’re fairly familiar with JavaScript / jQuery and its basic syntax.
You will also need some CSS to actually make your <ul> look like tabs.
Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
