您现在的位置: 365建站网 > 365文章 > 网页中加入视频文件
网页中加入视频文件
文章来源:365jz.com     点击数:375    更新时间:2009-10-27 09:54   参与评论
1.avi格式代码片断如下:
<object id="video" width="400" height="200" border="0" classid="clsid:CFCDAA03-8BE4-11cf-B84B-0020AFBBCCFA">
<param name="ShowDisplay" value="0">
<param name="ShowControls" value="1">
<param name="AutoStart" value="1">
<param name="AutoRewind" value="0">
<param name="PlayCount" value="0">
<param name="Appearance value="0 value=""">
<param name="BorderStyle value="0 value=""">
<param name="MovieWindowHeight" value="240">
<param name="MovieWindowWidth" value="320">
<param name="FileName" value="/Mbar.avi">
<embed width="400" height="200" border="0" showdisplay="0" showcontrols="1" autostart="1" autorewind="0" playcount="0" moviewindowheight="240" moviewindowwidth="320" filename="/Mbar.avi" src="Mbar.avi">
</embed>
</object>
2.mpg格式代码片断如下:
<object classid="clsid:05589FA1-C356-11CE-BF01-00AA0055595A" id="ActiveMovie1" width="239" height="250">
<param name="Appearance" value="0">
<param name="AutoStart" value="-1">
<param name="AllowChangeDisplayMode" value="-1">
<param name="AllowHideDisplay" value="0">
<param name="AllowHideControls" value="-1">
<param name="AutoRewind" value="-1">
<param name="Balance" value="0">
<param name="CurrentPosition" value="0">
<param name="DisplayBackColor" value="0">
<param name="DisplayForeColor" value="16777215">
<param name="DisplayMode" value="0">
<param name="Enabled" value="-1">
<param name="EnableContextMenu" value="-1">
<param name="EnablePositionControls" value="-1">
<param name="EnableSelectionControls" value="0">
<param name="EnableTracker" value="-1">
<param name="Filename" value="/mpeg/halali.mpg" valuetype="ref">
<param name="FullScreenMode" value="0">
<param name="MovieWindowSize" value="0">
<param name="PlayCount" value="1">
<param name="Rate" value="1">
<param name="SelectionStart" value="-1">
<param name="SelectionEnd" value="-1">
<param name="ShowControls" value="-1">
<param name="ShowDisplay" value="-1">
<param name="ShowPositionControls" value="0">
<param name="ShowTracker" value="-1">
<param name="Volume" value="-480">
</object>
3.smi格式代码片断如下:
<OBJECT id=RVOCX classid=clsid:CFCDAA03-8BE4-11cf-B84B-0020AFBBCCFA width=240 height=180>
<param name="_ExtentX" value="6350">
<param name="_ExtentY" value="4763">
<param name="AUTOSTART" value="-1">
<param name="SHUFFLE" value="0">
<param name="PREFETCH" value="0">
<param name="NOLABELS" value="-1">
<param name="SRC" value="rm.rm">
<param name="CONTROLS" value="ImageWindow">
<param name="CONSOLE" value="console1">
<param name="LOOP" value="0">
<param name="NUMLOOP" value="0">
<param name="CENTER" value="0">
<param name="MAINTAINASPECT" value="0">
<param name="BACKGROUNDCOLOR" value="#000000"><embed src="real.smi" type="audio/x-pn-realaudio-plugin" console="Console1" controls="ImageWindow" height="180" width="240" autostart="true"></OBJECT>
4.rm格式代码片断如下:
<OBJECT ID=video1 CLASSID="clsid:CFCDAA03-8BE4-11cf-B84B-0020AFBBCCFA" HEIGHT=288 WIDTH=352>
<param name="_ExtentX" value="9313">
<param name="_ExtentY" value="7620">
<param name="AUTOSTART" value="0">
<param name="NOLABELS" value="0">
<param name="SRC" value="rtsp://203.*.*.35/vod/dawan-a.rm">
<param name="CONSOLE" value="Clip1">
<param name="BACKGROUNDCOLOR" value="#000000"><embed SRC type="audio/x-pn-realaudio-plugin" CONSOLE="Clip1" CONTROLS="ImageWindow" HEIGHT="288" WIDTH="352" AUTOSTART="false">
</OBJECT>
5.wmv格式代码片断如下:
<object id="NSPlay" width=200 height=180 classid="CLSID:22d6f312-b0f6-11d0-94ab-0080c74c7e95" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=6,4,5,715" standby="Loading Microsoft Windows Media Player components..." type="application/x-oleobject" align="right" hspace="5">
<param name="AutoRewind" value=1>
<param name="FileName" value="http://192.168.1.71/verypower/shichang.wmv">
<param name="ShowAudioControls" value="1">
<param name="ShowTracker" value="0">
<param name="ShowStatusBar" value="0">
<param name="ShowGotoBar" value="0">
<param name="ShowCaptioning" value="0">
<param name="AutoStart" value=1>
<param name="Volume" value="-2500">
<param name="AnimationAtStart" value="0">
<param name="TransparentAtStart" value="0">
<param name="AllowChangeDisplaySize" value="0">
<param name="AllowScan" value="0">
<param name="EnableContextMenu" value="0">
<param name="ClickToPlay" value="0">
</object>
6.wma格式 放在 里面。下面是部分解释:
<object classid="clsid:22D6F312-B0F6-11D0-94AB-0080C74C7E95" id="MediaPlayer1" >
<param name="Filename" value="/blog/1.Wma"> <!--你文件的位置-->
<param name="PlayCount" value="1"><!--控制重复次数: “x”为几重复播放几次; x=0,无限循环。-->
<param name="AutoStart" value="0"><!--控制播放方式: x=1,打开网页自动播放; x=0,按播放键播放。-->
<param name="ClickToPlay" value="1"><!--控制播放开关: x=1,可鼠标点击控制播放或暂停状态; x=0,禁用此功能。-->
<param name="DisplaySize" value="0"><!--控制播放画面: x=0,原始大小; x=1,一半大小; x=2,2倍大小。-->
<param name="EnableFullScreen Controls" value="1"><!--控制切换全屏: x=1,允许切换为全屏; x=0,禁用此功能。-->
<param name="ShowAudio Controls" value="1"><!--控制音量: x=1,允许调节音量; x=0,禁止音量调节。-->
<param name="EnableContext Menu" value="1"><!--控制快捷菜单: x=1,允许使用右键菜单; x=0,禁用右键菜单。-->
<param name="ShowDisplay" value="1"><!--控制版权信息: x=1,显示电影及作者信息;x=0,不显示相关信息-->
</object>
7.Windows Media Player 系列(不同面板样式)综合型:
<object classid=clsid:22D6F312-B0F6-11D0-94AB-0080C74C7E95 codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=6,1,5,217"id=MediaPlayer type=application/x-oleobject width=210 height=340 standby="Loading Microsoft Windows Media Player components..." VIEWASTEXT align=MIDDLE>
<param name=AudioStream value=-1>
<param name=AutoSize value=0>
<param name=AutoStart value=1>
<param name=AnimationAtStart value=0>
<param name=AllowScan value=-1>
<param name=AllowChangeDisplaySize value=0>
<param name=AutoRewind value=0>
<param name=Balance value=0>
<param name=BaseURL value="">
<param name=BufferingTime value=5>
<param name=CaptioningID value="">
<param name=ClickToPlay value=0>
<param name=CursorType value=32512>
<param name=CurrentPosition value=-1>
<param name=CurrentMarker value=0>
<param name=DefaultFrame value=1>
<param name=DisplayBackColor value=0>
<param name=DisplayForeColor value=16777215>
<param name=DisplayMode value=0>
<param name=DisplaySize value=0>
<param name=Enabled value=-1>
<param name=EnableContextMenu value=-1>
<param name=EnablePositionControls value=0>
<param name=EnableFullScreenControls value=0>
<param name=EnableTracker value=1>
<param name=Filename value="http://flash.jninfo.net/swf/y1271.swf">
<param name=InvokeURLs value=-1>
<param name=Language value=-1>
<param name=Mute value=0>
<param name=PlayCount value=1>
<param name=PreviewMode value=0>
<param name=Rate value=1>
<param name=SAMILang value="">
<param name=SAMIStyle value="">
<param name=SAMIFileName value="">
<param name=SelectionStart value=0>
<param name=SelectionEnd value=true>
<param name=SendOpenStateChangeEvents value=-1>
<param name=SendWarningEvents value=-1>
<param name=SendErrorEvents value=-1>
<param name=SendKeyboardEvents value=0>
<param name=SendMouseClickEvents value=0>
<param name=SendMouseMoveEvents value=0>
<param name=SendPlayStateChangeEvents value=-1>
<param name=ShowCaptioning value=0>
<param name=ShowControls value=1>
<param name=ShowAudioControls value=1>
<param name=ShowDisplay value=1>
<param name=ShowGotoBar value=1>
<param name=ShowPositionControls value=1>
<param name=ShowStatusBar value=1>
<param name=ShowTracker value=1>
<param name=TransparentAtStart value=0>
<param name=VideoBorderWidth value=0>
<param name=VideoBorderColor value=0>
<param name=VideoBorder3D value=0>
<param name=Volume value=-1070>
<param name=WindowlessVideo value=1>
</object>
8 FLASH系列
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="266" height="240">
<param name="movie" value="http://user.net163.com/zjqz/mtv/fskl.swf">
<param name="quality" value="high">
<embed src="http://flash.jninfo.net/swf/y1271.swf" quality="high" pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash" width="266" height="240"></embed></object>
简易型:
<EMBED src=http://vod.alibaba.com/50/06/71/71/50067171_56.asf style="HEIGHT: 45px; WIDTH: 190px" type=audio/mpeg AUTOSTART="1" loop="0">
</EMBED>
标签型:
<embed width=240 height=140 transparentatstart=true animationatstart=false autostart=true autosize=false volume=100 displaysize=0 showdisplay=true showstatusbar=true showcontrols=true showaudiocontrols=true showtracker=true showpositioncontrols=true balance=true src="http://vod.alibaba.com/50/06/71/71/50067171_56.asf">
</embed>
引用内容:媒体播放器的外观界面
在网页中,你可以通过相关属性来控制媒体播放器的哪些部分出现,哪些部分不出现。
媒体播放器包括如下元素:
Video Display Panel:视频显示面板;
Video Border:视频边框;
Closed Captioning Display Panel;字幕显示面板;
Track Bar;搜索栏;
Control Bar with Audio and Position Controls:带有声音和位置控制的控制栏;
Go To Bar:转到栏;
Display Panel:显示面板;
Status Bar:状态栏;
下面的属性用来决定显示哪一个元素:
ShowControls 属性:是否显示控制栏(包括播放控件及可选的声音和位置控件);
ShowAudioControls 属性:是否在控制栏显示声音控件(静音按钮和音量滑块);
ShowPositionControls 属性:是否在控制栏显示位置控件(包括向后跳进、快退、快进、向前跳进、预览播放列表中的每个剪辑);
ShowTracker 属性:是否显示搜索栏;
ShowDisplay 属性:是否显示显示面板(用来提供节目与剪辑的信息);
ShowCaptioning 属性:是否显示字幕显示面板;
ShowGotoBar 属性:是否显示转到栏;
ShowStatusBar 属性:是否显示状态栏;
□播放列表
媒体播放器提供下面的方法来访问播放列表中的剪辑:
Next 方法,跳到节目(播放列表)中的下一个剪辑;
Previous 方法,跳回到节目中的上一个剪辑;
媒体播放器的一个特性是能够预览节目中的每一个剪辑,使用如下属性:
PreviewMode 属性,决定媒体播放器当前是否处于预览模式;
CanPreview 属性,决定媒体播放器能否处于预览模式;
在windows 媒体元文件中,可以为每一个剪辑指定预览时间——PREVIEWDURATION,如果没有指定,那么默认的预览时间是10秒钟。
你也可以用Windows 媒体元文件来添加 watermarks 与 banners,元文件也支持插入广告时的无间隙流切换。
□节目信息
使用 GetMediaInfoString 方法可以返回相关剪辑或节目的如下信息:
文件名:File name
标题:Title
描述:Description
作者:Author
版权:Copyright
级别:Rating
URLs:logo icon、watermark、banner的地址
剪辑信息可以放在媒体文件中,也可以放在Windows 媒体元文件中,或者两者都放。如果在元文件中指定了剪辑信息,那么用 GetMediaInfoString 方法返回的就是元文件中的信息,而不会返回剪辑中包含的信息。
在元文件中,附加信息可以放置在每一个剪辑或节目的 PARAM标签中。你可以为每个剪辑添加任意多个 PARAM 标签,用来存储自定义的信息或链接到相关站点。在 PARAM 标签中的信息可以通过 GetMediaParameter 方法来访问。
下面的属性返回有关大小和时间的信息:
ImageSourceHeight、ImageSourceWidth:返回图像窗口的显示尺寸;
Duration 属性,返回剪辑的长度(秒), 要检测这个属性是否包含有效的数值,请检查IsDurationValid 属性。(对于广播的视频,其长度是不可预知的)。
□字幕
你可以用 .smi 文件来为你的节目添加字幕。媒体播放器支持下面的属性来处理字幕:
SAMIFileName 属性,指定 .smi 文件的名字;
SAMILang 属性,指定字幕的语言(如果没有指定则使用第一种语言);
SAMIStyle 属性,指定字幕的文字大小和样式;
ShowCaptioning 属性,决定是否显示字幕显示面板;
□脚本命令
伴随音频、视频流,你可以在流媒体文件中加入脚本命令。脚本命令是多媒体流中与特定时间同步的多对Unicode串。第一个串标识待发命令的类型,第二个串指定要执行的命令。
当流播放到与脚本相关的时间时,控件会向网页发送一个 ScriptCommand事件,然后由事件处理进程来响应这个事件。脚本命令字符串会作为脚本命令事件的参数传递给事件处理器。
媒体播放器会自动处理下面类型的内嵌脚本命令:
1)URL型命令:当媒体播放器控件收到一个URL型的命令时,指定的URL会被装载到用户的默认浏览器。如果媒体播放器嵌在一个分帧的HTML文件中,URL页可以装载到由脚本命令指定的帧内。如果脚本命令没有指定一个帧,将由 DefaultFrame 属性决定将 URL 页装入哪一帧。
你可以通过设置 InvokeURLs 属性来决定是否自动处理 URL 型的脚本命令。如果这个属性的值为 false ,媒体播放器控件将忽视 URL型命令。但是脚本命令事件仍会触发,这就允许你有选择地处理 URL 型命令。
URL 型命令指定的是 URL 的相对地址。基地址是由 BaseURL属性指定的。媒体播放器控件传送的脚本命令事件的命令参数是链接好的地址。
2)FILENAME型命令:当媒体播放器控件收到一个FILENAME型的命令时,它将 FileName属性设置为脚本命令提供的文件,之后媒体播放器会打开这个文件开始播放。 媒体播放器控件总是自动处理 FILENAME 型命令,不象 URL 型命令,它们不能被禁止。
3)TEXT型命令:当媒体播放器控件收到一个 TEXT型的命令时,它会将命令的内容显示在控件的字幕窗口。内容可以是纯文本的,也可以是 HTML。
4)EVENT型命令:当媒体播放器控件收到一个 EVENT型的命令时,它会在媒体元文件中搜索 EVENT 元素的 NAME 属性。如果 NAME 属性与脚本命令中的第二个字符串匹配,媒体播放器控件就执行包含在 EVENT 元素中的条目。
5)OPENEVENT型命令:当媒体播放器控件收到一个 OPENEVENT型的命令时,它会在媒体元文件中检查 EVENT 元素,并打开匹配的标题,但不播放,直到收到来自 EVENT型命令的同名真实事件。
□捕捉键盘和鼠标事件
EnableContextMenu 与 ClickToPlay 属性为用户提供了在图像窗口进行操作的方法。
如果 EnableContextMenu 属性为 true ,在图像窗口右击鼠标可以打开关联菜单,如果将ClickToPlay 属性设为 true ,用户可以单击图像窗口进行播放与暂停的切换。
要接收鼠标移动和单击事件,请将 SendMouseMoveEvents 和 SendMouseClickEvents 属性设为 true 。鼠标事件有:
MouseDown,当用户按下鼠标时产生;
MouseUp,当用户释放鼠标时产生;
MouseMove,当用户移动鼠标时产生;
Click,当用户在媒体播放器上单击鼠标按钮时产生;
DbClick,当用户在媒体播放器上双击鼠标按钮时产生;
要接收键盘事件,请将 SendKeyboardEvents 属性设为 true 。键盘事件有:
KeyDown,当用户按下一个键时产生;
KeyUp,当用户释放一个键时产生;
KeyPress,当用户按下并释放一个键时产生;
□监测流状态与网络链接
流状态属性包括:
PlayState:播放状态;
OpenState:打开状态;
Bandwidth:带宽;
支持的事件有:
OpenStateChange:打开状态改变(仅当SendOpenStateChangeEvents属性为true时触发)
PlayStateChange:播放状态改变(仅当SendPlayStateChangeEvents属性为true时触发)
EndOfStream:流结束时触发;
NewStream:打开新流时触发;
网络接收属性包括:
ReceptionQuality:接收质量;
ReceivedPackets:已经收到的包;
LostPackets:丢失的包;
监测缓冲的属性有:
BufferingTime:缓冲时间;
BufferingCount:缓冲次数;
BufferingProgress:缓冲进程;
Buffering:缓冲事件;
□错误处理
媒体播放器提供了内建的错误处理功能——在对话框或状态栏显示错误信息。 另外,你可以自己添加错误处理程序。如果 SendErrorEvents 属性设置为 true,将不会显示错误框,而是发送错误事件;如果 SendErrorEvents 属性设置为 false,将显示错误框,而是发送错误事件。
媒体播放器支持下面的错误处理事件:
Error 事件,指有危险性错误发生;
Warning 事件,指发生了非危险性的错误;
当你的应用程序接收到一个错误事件,你可以检测下面的属性来确定具体的错误信息:
HasError:检测目前的媒体播放器是否有错误;
ErrorCode:提供与该类型错误相关的代码值;
ErrorDescription:提供错误的描述信息;
ErrorCorrection:指定媒体播放器对该类型的错误进行校正;
发表评论 (375人查看0条评论)
