您现在的位置: 365建站网 > 365文章 > myeclipse运行错误,大家帮我看一下啊
文章来源:365jz.com     点击数:936    更新时间:2009-11-13 23:25   参与评论
昨天是有用的,没错误,今天虽然是可以运行的,但是出现了下面的东西,貌似tomcat出问题了
 2009-11-13 18:36:38 org.apache.catalina.core.AprLifecycleListener init
信息: Loaded APR based Apache Tomcat Native library 1.1.10.
信息: APR capabilities: IPv6 [false], sendfile [true], accept filters [false], random [true].
2009-11-13 18:36:38 org.apache.coyote.http11.Http11AprProtocol init
严重: Error initializing endpoint
java.lang.Exception: Socket bind failed: [730048] ?????????×???(Э?é/???????/???)????í??
 at org.apache.tomcat.util.net.AprEndpoint.init(AprEndpoint.java:612)
 at org.apache.coyote.http11.Http11AprProtocol.init(Http11AprProtocol.java:107)
 at org.apache.catalina.connector.Connector.initialize(Connector.java:1058)
 at org.apache.catalina.core.StandardService.initialize(StandardService.java:677)
 at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:795)
 at org.apache.catalina.startup.Catalina.load(Catalina.java:530)
 at org.apache.catalina.startup.Catalina.load(Catalina.java:550)
 at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
 at java.lang.reflect.Method.invoke(Method.java:597)
 at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:260)
 at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:412)
2009-11-13 18:36:38 org.apache.catalina.startup.Catalina load
严重: Catalina.start
LifecycleException:  Protocol handler initialization failed: java.lang.Exception: Socket bind failed: [730048] ?????????×???(Э?é/???????/???)????í??
 at org.apache.catalina.connector.Connector.initialize(Connector.java:1060)
信息: Initialization processed in 819 ms
2009-11-13 18:36:38 org.apache.catalina.core.StandardService start
信息: Starting service Catalina
2009-11-13 18:36:38 org.apache.catalina.core.StandardEngine start
信息: Starting Servlet Engine: Apache Tomcat/6.0.16
2009-11-13 18:36:38 org.apache.catalina.core.StandardContext addApplicationListener
信息: The listener "listeners.ContextListener" is already configured for this context. The duplicate definition has been ignored.
信息: The listener "listeners.SessionListener" is already configured for this context. The duplicate definition has been ignored.
2009-11-13 18:36:39 org.apache.catalina.core.ApplicationContext log
信息: ContextListener: contextInitialized()
信息: SessionListener: contextInitialized()
2009-11-13 18:36:39 com.sun.faces.config.ConfigureListener$WebXmlProcessor scanForFacesServlet
警告: Unable to process deployment descriptor for context 'null'
2009-11-13 18:36:39 com.sun.faces.config.ConfigureListener contextInitialized
信息: Initializing Sun's JavaServer Faces implementation (1.2_04-b07-FCS) for context ''
2009-11-13 18:36:40 org.apache.coyote.http11.Http11AprProtocol start
严重: Error starting endpoint
 at org.apache.tomcat.util.net.AprEndpoint.start(AprEndpoint.java:717)
 at org.apache.coyote.http11.Http11AprProtocol.start(Http11AprProtocol.java:137)
 at org.apache.catalina.connector.Connector.start(Connector.java:1131)
 at org.apache.catalina.core.StandardService.start(StandardService.java:531)
 at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
 at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
 at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
 at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
2009-11-13 18:36:40 org.apache.catalina.startup.Catalina start
严重: Catalina.start:
LifecycleException:  service.getName(): "Catalina";  Protocol handler start failed: java.lang.Exception: Socket bind failed: [730048] ?????????×???(Э?é/???????/???)????í??
 at org.apache.catalina.connector.Connector.start(Connector.java:1138)
信息: Server startup in 1561 ms
2009-11-13 18:36:40 org.apache.catalina.core.StandardServer await
严重: StandardServer.await: create[8005]:
java.net.BindException: Address already in use: JVM_Bind
 at java.net.PlainSocketImpl.socketBind(Native Method)
 at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:359)
 at java.net.ServerSocket.bind(ServerSocket.java:319)
 at java.net.ServerSocket.<init>(ServerSocket.java:185)
 at org.apache.catalina.core.StandardServer.await(StandardServer.java:373)
 at org.apache.catalina.startup.Catalina.await(Catalina.java:642)
 at org.apache.catalina.startup.Catalina.start(Catalina.java:602)
发表评论 (936人查看0条评论)
