您现在的位置: 365建站网 > 365文章 > select the appropriate stylesheet according to the users scr
文章来源:365jz.com     点击数:193    更新时间:2009-11-13 23:25   参与评论
 <script type="text/javascript" src="select_css.js"> </script>
// select_css.js
  // select the appropriate stylesheet according to the user's screen resolution
  document.write("<link rel='stylesheet' type='text/css' href='");
  if (window.screen.height <= 600) {
    //resolution is 800x600 or less
    document.write("small.css'>");
  } else {
    document.write("large.css'>");
发表评论 (193人查看0条评论)
