您现在的位置: 365建站网 > 365文章 > asp.net中实现Gridview的多行拖放, 以及跨控件拖放
文章来源:365jz.com     点击数:356    更新时间:2009-11-13 23:25   参与评论
学习JQuery时,发现JQuery只能做单行拖放, 于是花时间做了一个多行拖放的例子, 以备以后使用。
<head runat="server">
    <title></title>
 <script type="text/javascript" src="jquery-1.3.2.js"></script>
 <script type="text/javascript" src="jquery-ui-1.7.2.custom.js"></script>
  //dragg and drop sample program
  //authored by gujinsong@trans-cosmos
  //2009-11-11
  //temporary var that stored selected rows
  var SelectedRows = [];
  //forbid all select
  document.onselectstart = function() { return false; }
  //fires when dragg object go out the source table
  $(document).mouseup(function() {
   $(".float").hide();
   $(".float")[0].innerHTML = "";
   IsDragging = false;
  ).mousemove(function(e) {
   if (IsDragging == true) {
    $(".float").css("top", e.clientY + 2);
    $(".float").css("left", e.clientX + 2);
    $(".float").show();
  // flag that indicates whether is during dragging
  var IsDragging = false;
  //using  jquery give mouse event to each rows
  $(document).ready(function() {
   $(".stripe tr").mousedown(
      function(e) {
       if (this.innerHTML.substring(0, 3) == "<TH") return false;
       if (!e) var e = window.event;
       if (!e.ctrlKey) {
        unselectAll();
       if ($(this).context.className == "over") {
        $(this).removeClass("over");
        unselect();
       else {
        $(this).addClass("over");
        SelectedRows.push($(this));
        //set style
        $(".float").css("top", e.clientY + 5);
        $(".float").css("left", e.clientX + 5);
        $(".float").css("zIndex", 1);
        $(".float").css("position", "absolute");
        $(".float").width($(this).width());
        $(".float").height($(this).height() * SelectedRows.length);
        for (var i = 0; i < SelectedRows.length; i++) {
         $(".float").append(SelectedRows[i].clone());
        $(".float").wrapInner("<table></table>");
      if (this.innerHTML.substring(0, 3) == "<TH") {
       $(".float").fadeOut("normal");
       IsDragging = false;
     if ($(this).context.className != "over" && IsDragging == 1) {
      DraggStop($(this));
    }).mousemove(function(e) {
     if (e.button == 1) {
      IsDragging = true;
      $(".float").fadeIn("normal"); //show();
  // function that re-sort rows
  function DraggStop(item) {
   $(".stripe tr").each(function() {
    if (this.className == "over") {
     $(this).insertBefore(item);
  //clear all selected rows
  function unselectAll() {
   for (var i = SelectedRows.length-1; i > -1; i--)
    SelectedRows[i].removeClass("over");
    SelectedRows.pop(i);
  //un-select current row
  function unselect() {
    if (SelectedRows[i].context.className != "over") {
  //acceptable control's mouse event
  function Dropable(e) {
    var txt = document.getElementById("TextBox1")
    txt.value = "";
     txt.value = txt.value + this.innerHTML + "\r\n";
 <style type="text/css">
  th
   background: #0066FF;
   color: #FFFFFF;
   line-height: 20px;
   height: 30px;
  td
   padding: 6px 11px;
   border-bottom: 1px solid #95bce2;
   vertical-align: top;
   text-align: center;
  td *
   padding: 6px 11px;
  tr.alt td
   background: #ecf6fc; /*这行将给所有的tr加上背景色*/
  tr.over td
   background: #bcd4ec; /*这个将是鼠标高亮行的背景色*/
 </style>
<div class="float">
</div>
 <form id="form1" runat="server">
 <asp:GridView ID="selectable"  runat="server" class="stripe">
 </asp:GridView>
 <asp:TextBox ID="TextBox1" runat="server" onmouseover="Dropable();"
  Height="210px" TextMode="MultiLine" Width="772px" ></asp:TextBox>
 </form>
发表评论 (356人查看0条评论)
