您现在的位置: 365建站网 > 365文章 > PHP缓存应用:PHP MEMCACHE 详解
文章来源:365jz.com     点击数:371    更新时间:2010-04-14 23:45   参与评论
Memcache函数库是在PECL(PHP Extension Community Library)中,主要作用是搭建大容量的内存数据的临时存放区域,在分布式的时候作用体现的非常明显,否则不建议使用。在ubuntu上安装完运行的时候报错:
/usr/local/memcached/bin/memcached: error while loading shared libraries: libevent-1.4.so.2:
cannot open shared object file: No such file or directory
按照:《libeven、memcached、libmemcache安装》中的方法,使用:
sudo ln -s /usr/local/lib/libevent-1.4.so.2 /usr/lib/libevent-1.4.so.2
可以修正这个BUG
通过新得立安装php的memcached模块,注销/etc/php5/conf.d/memcached.ini里面的“;”,重启apache,调用phpinfo()出现memcached的信息。
<?php
$memcache = new Memcache;
$memcache->connect('localhost', 11211) or die ("Could not connect");
$version = $memcache->getVersion();
echo "Server's version: ".$version."\n";
<?php
print_r($memcache->getStats());
* Array
*     [pid] => 8052
*     [uptime] => 9205
*     [time] => 1205898428
*     [version] => 1.2.5
*     [pointer_size] => 32
*     [rusage_user] => 0.008000
*     [rusage_system] => 0.000000
*     [curr_items] => 1
*     [total_items] => 17
*     [bytes] => 57
*     [curr_connections] => 2
*     [total_connections] => 15
*     [connection_structures] => 3
*     [cmd_get] => 9
*     [cmd_set] => 23
*     [get_hits] => 5
*     [get_misses] => 4
*     [evictions] => 0
*     [bytes_read] => 671
*     [bytes_written] => 850
*     [limit_maxbytes] => 10485760
*     [threads] => 1
01.<?php
02.$memcache = new Memcache;
03.$memcache->connect('localhost', 11211) or die ("Could not connect");
04.$memcache->set( 'name', 'leo', 0, 30);
05.if(!$memcache->add( 'name', 'susan', 0, 30))
06.{
07. echo 'susan is exist';
08.};
09.$memcache->replace( 'name', 'lion', 0, 300);
10.echo $memcache->get( 'name');
11.$memcache->delete( 'name', 5);
12.?>
01.<?php
02.function _callback_memcache_failure($host, $port) {
03. print "memcache '$host:$port' failed";
04.}
05.$memcache = new Memcache;
06.$memcache->addServer('192.168.1.116', 11211);
07.$memcache->setServerParams('192.168.1.116', 11211, 1, 15, true,
08.
09.'_callback_memcache_failure');
10.echo $memcache->getServerStatus('192.168.1.116', 11211);
11.?>
01.<?php
03.$memcache->connect('localhost', 11211);
04.$memcache->set('test_item', 8);
05.$memcache->increment('test_item', 4);
06.echo $memcache->decrement('test_item', 7);
07.// 显示 5
08.?>
/usr/local/bin/memcached -d -m 10 -u root -l 127.0.0.1 -p 11211 -c 256 -P
/tmp/memcached.pid
memcached的服务正式启动
01.Memcache::add — 添加一个值,如果已经存在,则返回false
02.Memcache::addServer — 添加一个可供使用的服务器地址
03.Memcache::close — 关闭一个Memcache对象
04.Memcache::connect — 创建一个Memcache对象
05.memcache_debug — 控制调试功能
06.Memcache::decrement — 对保存的某个key中的值进行减法操作
07.Memcache::delete — 删除一个key值
08.Memcache::flush — 清除所有缓存的数据
09.Memcache::get — 获取一个key值
10.Memcache::getExtendedStats — 获取进程池中所有进程的运行系统统计
11.Memcache::getServerStatus — 获取运行服务器的参数
12.Memcache::getStats — 返回服务器的一些运行统计信息
13.Memcache::getVersion — 返回运行的Memcache的版本信息
14.Memcache::increment — 对保存的某个key中的值进行加法操作
15.Memcache::pconnect — 创建一个Memcache的持久连接对象
16.Memcache::replace — R对一个已有的key进行覆写操作
17.Memcache::set — 添加一个值,如果已经存在,则覆写
18.Memcache::setCompressThreshold — 对大于某一大小的数据进行压缩
19.Memcache::setServerParams — 在运行时修改服务器的参数
建议用面向对象的方式来测试这个库:
Memcache::getVersion方法的作用是返回运行的Memcache的版本信息。
Memcache::getStats 方法的作用是返回服务器的一些运行统计信息。Memcache::getStats方法有三个参数,第一个参数表示要求返回的类型:reset, malloc, maps, cachedump, slabs, items, sizes;第二个参数和第三个参数是在第一个参数设置“cachedump”时使用的。Memcache::getExtendedStats方法的作用是获取进程池中所有进程的运行系统统计。
memcache_debug()函数的作用是控制调试功能,前提是php在编译的时候使用了–enable-debug选项,否则这个函数不会有作用。
Memcache::addServer 方法的作用是添加一个可供使用的服务器地址,Memcache::addServer方法有8个参数,除了第一个参数意外,其他都是可选的,第一个参数表示服务器的地址,第二个参数表示端口,第三个参数表示是否是一个持久连接,第四个参数表示这台服务器在所有服务器中所占的权重,第五个参数表示连接的持续时间,第六个参数表示连接重试的间隔时间,默认为15,设置为-1表示不进行重试,第七个参数用来控制服务器的在线状态,第8个参数允许设置一个回掉函数来处理错误信息。
Memcache::setServerParams方法的作用是在运行时修改服务器的参数,Memcache::setServerParams方法有六个参数,Memcache::addServer方法少了第三和第四个参数。 Memcache::getServerStatus方法的作用是获取运行服务器的参数,两个参数分别表示的地址和端口。
Memcache::flush方法的作用是清除所有缓存的数据,但是不会削去使用的内存空间。
Memcache::increment方法的作用是对保存的某个key中的值进行加法操作,Memcache::decremen方法的作用是对保存的某个key中的值进行减法操作
本文作者:未知
发表评论 (371人查看0条评论)
