您现在的位置: 365建站网 > 365文章 > 购物车(Datatable、Hashtable两种实现方式)
文章来源:365jz.com     点击数:319    更新时间:2011-03-24 14:48   参与评论
 1:第一种方式:用Datatable
BuyPro(1, Request.QueryString["id"].ToString());
 public string BuyPro(int number, string ProductCode)
             if (Session["Cart"] == null)
                this.BuildCart(number, ProductCode);
            else
                DataTable cart = Session["Cart"] as DataTable;
                if (this.Existproduct(cart, number, ProductCode))
                    this.BuildSession(cart, number, ProductCode);
            return GetCartPro();
private void BuildCart(int number, string ProductCode)
            DataTable cart = new DataTable();
            cart.Columns.Add("ProductCode");
            cart.Columns.Add("ProductName");
            cart.Columns.Add("ProductDes");
            cart.Columns.Add("Number");
            cart.Columns.Add("UnitPrice");
        /// <summary>
        /// 添加新产品
        /// </summary>
        /// <param name="cart"></param>
             private void BuildSession(DataTable cart, int number, string ProductCode)
            DataRow dr = cart.NewRow();
            model_pro = dal_pro.GetModel(Convert.ToInt32(ProductCode));
            dr["ProductCode"] = model_pro.id;// ViewState["ProductCode"].ToString();
            dr["ProductName"] = model_pro.ProName;
            dr["Number"] = number;
            dr["UnitPrice"] = model_pro.Mallprice;
            dr["ProductDes"] = "";// model_pro.ProductDes;
            cart.Rows.Add(dr);
            Session["Cart"] = cart;
        /// <summary>
        /// 产品已经存在
        /// </summary>
        /// <returns></returns>
        public bool Existproduct(DataTable cart, int number, string ProductCode)
            Boolean bo = false;
            foreach (DataRow dr in cart.Rows)
                if (dr["ProductCode"].ToString().Equals(ProductCode))
                    dr["Number"] = Convert.ToInt32(dr["Number"]) + number;
                    dr["Number"] = Convert.ToInt32(dr["Number"]) > 100 ? 100 : dr["Number"];
                    //Response.Redirect("Cart.aspx");
                    bo = false;
                    return bo;
                else
                    bo = true;
            return bo;
        protected string GetCartPro()
            DataTable cart = (DataTable)Session["Cart"];
            double Total = 0;
            if (cart != null)
                    Total += Convert.ToDouble(dr["UnitPrice"].ToString()) * Convert.ToDouble(dr["Number"].ToString());
                return "购物车已有宝贝<font style='color:red;font-weight:bold'> " + cart.Rows.Count + "</font>种,总价:¥<font style='color:red;font-weight:bold'>" + Total + "</font>";
            // Maunite.Common.MessageBox.Show(this, Total.ToString());
            return "购物车目前为空,总价:0";
取出购物车信息
 private void BindGridView()
            DataTable cart = Session["cart"] as DataTable;
            Mycart.DataSource = cart;
            Mycart.DataBind();
            if (Session["cart"] != null)
                Label5.Text = "您以选购的商品";
                TotalPrice(cart);
                BindTuijian();
            else
                Label5.Text = "<font style='color:red'>您的购物车没有商品</font>";
                TuijianDiv.Visible = false;
                this.ltrSalary.Text = "0";
                this.labIntegral.Text = "0";
2:第二种实现方式:用Hashtable
Hashtable hash;
            if (Session["Car"] == null)
                //如果用户没有分配购物车
                hash = new Hashtable();         //新生成一个
                //  hash.Add(e.CommandArgument, 1); //添加一个商品
                // Session["Cart"] = hash;     //分配给用户
            else
                //用户已经有购物车
                hash = (Hashtable)Session["Car"];//得到购物车的hash表
            if (!hash.Contains(e.CommandArgument))//购物车中已有此商品,商品数量加1
                hash.Add(e.CommandArgument, 1);//如果没有此商品,则新添加一个项
            else
                int count = Convert.ToInt32(hash[e.CommandArgument].ToString());//得到该商品的数量
                hash[e.CommandArgument] = (count + 1);//商品数量加1
            Session["Car"] = hash;
取出购物车信息
 protected void shoplist()
        Hashtable Hash;
        if (Session["car"] == null)
            Hash = new Hashtable();
        else
            Hash = (Hashtable)Session["car"];
        if (Hash.Count == 0)
                      Msg.Text = "您还没有购物呢?赶快购物吧!";
        string[] ArrKey = new string[Hash.Count];
        int[] ArrVal = new int[Hash.Count];
        string Products = "('";
        Hash.Keys.CopyTo(ArrKey, 0);
        Hash.Values.CopyTo(ArrVal, 0);
        int k = 0;
        for (int j = 0; j < ArrKey.Length; j++)
            if (k > 0) Products += "','"; k++;
            Products += ArrKey.GetValue(j).ToString();
        Products += "')";
        SqlConnection conn = new SqlConnection(Class1.lianjie());
        conn.Open();
        string mysql = "select * from product where pid in" + Products;
        SqlCommand cmd = new SqlCommand(mysql,conn);
        SqlDataAdapter da = new SqlDataAdapter(cmd);
        DataSet ds = new DataSet();
        da.Fill(ds, "product");
        DataTable Table1 = new DataTable();
        Table1 = ds.Tables["product"];
        Table1.Columns.Add(new DataColumn("shuliang", System.Type.GetType("System.Int32")));
        DataColumn[] Keys ={ Table1.Columns["pid"] };
        Table1.PrimaryKey = Keys;
        foreach (string X in Hash.Keys)
            Table1.Rows.Find(X)["shuliang"] = Hash[X];
        Table1.Columns.Add(new DataColumn("zongjia", System.Type.GetType("System.Double"), "hotprice*shuliang"));
        for (int I = 0; I < Table1.Rows.Count; I++)
            TtlPrice += Convert.ToDouble(Table1.Rows[I]["zongjia"]);
        Label1.Text = TtlPrice.ToString();
        Session["total"] = Label1.Text.ToString();
        MyGrid.DataSource = Table1.DefaultView;
        MyGrid.DataBind();
发表评论 (319人查看0条评论)
