您现在的位置: 365建站网 > 365文章 > Asp.Net 加密解密
Asp.Net 加密解密
文章来源:365jz.com     点击数:270    更新时间:2011-03-24 14:50   参与评论
#region DES加密解密
/// <summary>
/// DES加密
/// </summary>
/// <param name="strSource">待加密字串</param>
/// <param name="key">32位Key值</param>
/// <returns>加密后的字符串</returns>
public string DESEncrypt(string strSource)
return DESEncrypt(strSource, DESKey);
public string DESEncrypt(string strSource, byte[] key)
SymmetricAlgorithm sa
= Rijndael.Create();
sa.Key
= key;
sa.Mode
= CipherMode.ECB;
sa.Padding
= PaddingMode.Zeros;
MemoryStream ms
= new MemoryStream();
CryptoStream cs
= new CryptoStream(ms, sa.CreateEncryptor(), CryptoStreamMode.Write);
byte[] byt = Encoding.Unicode.GetBytes(strSource);
cs.Write(byt,
0, byt.Length);
cs.FlushFinalBlock();
cs.Close();
return Convert.ToBase64String(ms.ToArray());
/// <summary>
/// DES解密
/// </summary>
/// <param name="strSource">待解密的字串</param>
/// <returns>解密后的字符串</returns>
public string DESDecrypt(string strSource)
return DESDecrypt(strSource, DESKey);
public string DESDecrypt(string strSource, byte[] key)
sa.Key
= key;
sa.Mode
= CipherMode.ECB;
sa.Padding
ICryptoTransform ct
= sa.CreateDecryptor();
byte[] byt = Convert.FromBase64String(strSource);
MemoryStream ms
= new MemoryStream(byt);
CryptoStream cs
= new CryptoStream(ms, ct, CryptoStreamMode.Read);
StreamReader sr
= new StreamReader(cs, Encoding.Unicode);
return sr.ReadToEnd();
#endregion
#region 一个用hash实现的加密解密方法
/// <summary>
/// 加密
/// </summary>
/// <param name="src"></param>
/// <returns></returns>
public static string EncryptStrByHash(string src)
if (src.Length == 0)
return "";
byte[] HaKey = System.Text.Encoding.ASCII.GetBytes((src + "Test").ToCharArray());
byte[] HaData = new byte[20];
HMACSHA1 Hmac
= new HMACSHA1(HaKey);
CryptoStream cs
= new CryptoStream(Stream.Null, Hmac, CryptoStreamMode.Write);
try
cs.Write(HaData,
0, HaData.Length);
finally
cs.Close();
string HaResult = System.Convert.ToBase64String(Hmac.Hash).Substring(0, 16);
byte[] RiKey = System.Text.Encoding.ASCII.GetBytes(HaResult.ToCharArray());
byte[] RiDataBuf = System.Text.Encoding.ASCII.GetBytes(src.ToCharArray());
byte[] EncodedBytes = { };
MemoryStream ms
RijndaelManaged rv
= new RijndaelManaged();
cs
= new CryptoStream(ms, rv.CreateEncryptor(RiKey, RiKey), CryptoStreamMode.Write);
try
cs.Write(RiDataBuf,
0, RiDataBuf.Length);
EncodedBytes
= ms.ToArray();
finally
ms.Close();
cs.Close();
return HaResult + System.Convert.ToBase64String(EncodedBytes);
/// <summary>
/// 解密
/// </summary>
public static string DecrypStrByHash(string src)
if (src.Length < 40) return "";
byte[] SrcBytes = System.Convert.FromBase64String(src.Substring(16));
byte[] RiKey = System.Text.Encoding.ASCII.GetBytes(src.Substring(0, 16).ToCharArray());
byte[] InitialText = new byte[SrcBytes.Length];
RijndaelManaged rv
MemoryStream ms
= new MemoryStream(SrcBytes);
CryptoStream cs
= new CryptoStream(ms, rv.CreateDecryptor(RiKey, RiKey), CryptoStreamMode.Read);
try
cs.Read(InitialText,
0, InitialText.Length);
finally
ms.Close();
cs.Close();
System.Text.StringBuilder Result
= new System.Text.StringBuilder();
for (int i = 0; i < InitialText.Length; ++i) if (InitialText[i] > 0) Result.Append((char)InitialText[i]);
return Result.ToString();
/// <summary>
/// 对加密后的密文重新编码,如果密文长>16,则去掉前16个字符,如果长度小于16,返回空字符串
/// </summary>
/// <param name="s"></param>
public string ReEncryptStrByHash(string s)
string e = Encrypt.EncryptStrByHash(s);
return ((e.Length > 16) ? e.Substring(16) : "");
#endregion
#region Md5加密,生成16位或32位,生成的密文都是大写
public static string Md5To16(string str)
MD5CryptoServiceProvider md5
= new MD5CryptoServiceProvider();
string t2 = BitConverter.ToString(md5.ComputeHash(UTF8Encoding.Default.GetBytes(str)), 4, 8);
t2
= t2.Replace("-", "");
return t2;
//// <summary>
/// MD5 32位加密
/// </summary>
/// <param name="str"></param>
public static string Md5To32(string str)
string pwd = "";
MD5 md5
= MD5.Create();
byte[] s = md5.ComputeHash(Encoding.UTF8.GetBytes(str));
for (int i = 0; i < s.Length; i++)
pwd
= pwd + s[i].ToString("X");
return pwd;
#endregion
#region 3DES加密解密
public string Encrypt3DES(string str)
//密钥
string sKey = "wyw308";
// //矢量,可为空
string sIV = "scf521";
// //构造对称算法
SymmetricAlgorithm mCSP = new TripleDESCryptoServiceProvider();
ICryptoTransform ct;
MemoryStream ms;
CryptoStream cs;
byte[] byt;
mCSP.Key
= Convert.FromBase64String(sKey);
mCSP.IV
= Convert.FromBase64String(sIV);
mCSP.Mode
= System.Security.Cryptography.CipherMode.ECB;
mCSP.Padding
= System.Security.Cryptography.PaddingMode.PKCS7;
ct
= mCSP.CreateEncryptor(mCSP.Key, mCSP.IV);
byt
= Encoding.UTF8.GetBytes(str);
ms
cs
= new CryptoStream(ms, ct, CryptoStreamMode.Write);
cs.Write(byt,
0, byt.Length);
cs.Close();
/// <summary>
/// 带指定密钥和矢量的3DES加密
/// </summary>
/// <param name="sKey"></param>
/// <param name="sIV"></param>
public string Encrypt3DES(string str, string sKey, string sIV)
MemoryStream ms;
CryptoStream cs;
byte[] byt;
mCSP.Key
mCSP.IV
mCSP.Mode
mCSP.Padding
ct
byt
ms
cs
cs.Write(byt,
0, byt.Length);
cs.Close();
//解密
public string Decrypt3DES(string Value)
MemoryStream ms;
CryptoStream cs;
byte[] byt;
mCSP.Key
mCSP.IV
mCSP.Mode
mCSP.Padding
ct
= mCSP.CreateDecryptor(mCSP.Key, mCSP.IV);
byt
= Convert.FromBase64String(Value);
ms
cs
cs.Write(byt,
0, byt.Length);
cs.Close();
return Encoding.UTF8.GetString(ms.ToArray());
/// <summary>
/// 带指定密钥和矢量的3DES解密
/// </summary>
/// <param name="Value"></param>
public string Decrypt3DES(string str, string sKey, string sIV)
MemoryStream ms;
CryptoStream cs;
byte[] byt;
mCSP.Key
mCSP.IV
mCSP.Mode
mCSP.Padding
ct
byt
= Convert.FromBase64String(str);
ms
cs
cs.Write(byt,
0, byt.Length);
cs.Close();
#endregion
#region 一个简单的加密解密方法,只支持英文
public static string EnCryptEnStr(string str) //倒序加1加密
byte[] by = new byte[str.Length];
for (int i = 0;
i
<= str.Length - 1;
i
by[i]
= (byte)((byte)str[i] + 1);
str
for (int i = by.Length - 1;
i
>= 0;
i
str
+= ((char)by[i]).ToString();
return str;
public static string DeCryptEnStr(string str) //顺序减1解码
for (int i = 0;
i
<= str.Length - 1;
i
by[i]
= (byte)((byte)str[i] - 1);
str
i
>= 0;
i
str
return str;
#endregion
#region 一个简单的加密解密方法,在上一个的基础上支持中文
public static string EnCryptCnStr(string str)
string htext = ""; // blank text
for (int i = 0; i < str.Length; i++)
htext
= htext + (char)(str[i] + 10 - 1 * 2);
return htext;
public static string DeCryptCnStr(string str)
string dtext = "";
dtext
= dtext + (char)(str[i] - 10 + 1 * 2);
return dtext;
#endregion
#region Url地址编码解码
/// <summary>
/// 编码Url地址
/// </summary>
/// <param name="url"></param>
public static string UrlEncode(string url)
byte[] mByte = null;
mByte
= System.Text.Encoding.GetEncoding("GB2312").GetBytes(url);
return System.Web.HttpUtility.UrlEncode(mByte);
/// <summary>
/// 解码Url地址
/// </summary>
public static string UrlDecode(string url)
return HttpUtility.UrlDecode(url, System.Text.Encoding.GetEncoding("GB2312"));
#endregion
发表评论 (270人查看0条评论)
