您现在的位置: 365建站网 > 365文章 > 获取gridview前台特定行label绑定的值
文章来源:365jz.com     点击数:335    更新时间:2011-05-09 09:55   参与评论
如前台绑定的是label和linkbutton按钮
</>code
  1. protected void LinkBtnDelete_Click(object sender, EventArgs e)
    //取得当前点击的LinkButton按钮
    LinkButton btn = (LinkButton)sender;
    //取得当前点击linkbutton按钮的所在行
    GridViewRow irow = (GridViewRow)btn.NamingContainer;
    //在当前点击linkbutton按钮的行找到label
    Label lbltag = (Label)irow.Cells[0].FindControl("Label1");
    //将label的值赋值于变量tbtag
    string tbtag = lbltag.Text.Trim();
    Conndb.Conndb conn
    = new Conndb.Conndb();
    conn.Open();
    string[] Sql = new string[1];
    Sql[
    0] = string.Format("delete from News where NewsId={0}", tbtag);
    int i = conn.ExeSql(Sql);
    if (i == 1)
    Response.Write(
    "<script>alert('删除成功');</script>");
    this.GridTitle.DataSource = Methed.datasetNew();
    this.GridTitle.DataBind();
    else
    Response.Write(
    "<script>alert('删除失败');</script>");
发表评论 (335人查看0条评论)
