您现在的位置: 365建站网 > 365文章 > Dotfuscator进行混淆出现This assembly was originally built with .NET Framework v2.0.50727
文章来源:365jz.com     点击数:1314    更新时间:2016-09-14 12:52   参与评论
用Dotfuscator进行Unity3D代码混淆时报异常:
Could not find a compatible version of ildasm to run on assembly (valid path to solution output exe). This assembly was originally built with .NET Framework v2.0.50727
找不到.NET Framework v2.0.50727,在Dotfuscator工程配置文件project.xml中添加路径映射解决
<dotfuscator version="2.3">
   <propertylist>
      <property name="ILDASM_v2.0.50727" value="C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Bin\ildasm.exe" />
      <property name="ILDASM_v4.0.30319" value="C:\Program Files (x86)\Microsoft SDKs\Windows\v8.0A\bin\NETFX 4.0 Tools\ildasm.exe" />
   </propertylist>
发表评论 (1314人查看0条评论)
