html/js/javascript/jquery跑马灯代码特效滚动效果
页面html:
<div> <div id="imgShows" runat="server" style="padding-bottom: 10px;"> <div id="demo" style="overflow: hidden; width: 100%; height: 190px"> <table cellspacing="0" cellpadding="0" align="left" border="0" cellspace="0"> <tr> <td id="demo1" valign="top" runat="server"> </td> <td id="demo2" valign="top"> </td> </tr> </table> </div> <script type="text/javascript"> var speed = 10 var demo = document.getElementById("demo"); var demo1 = document.getElementById("demo1"); var demo2 = document.getElementById("demo2"); demo2.innerHTML = demo1.innerHTML function Marquee() { if (demo2.offsetWidth - demo.scrollLeft <= 0) demo.scrollLeft -= demo1.offsetWidth else { demo.scrollLeft++ } } var MyMar = setInterval(Marquee, speed) demo.onmouseover = function () { clearInterval(MyMar) } demo.onmouseout = function () { MyMar = setInterval(Marquee, speed) } </script> </div> </div>
cs后台代码:
private void BindPics(int comId) { List<Model.Pic> pic = DAO.PicDao.GetPics(comId); StringBuilder sb = new StringBuilder(); if (pic == null || pic.Count < 1) { imgShows.InnerHtml = string.Empty; return; } sb.Append("<table width=\"100%\" border=\"0\" align=\"center\" cellpadding=\"0\"cellspacing=\"10px\"><tr>"); for (int i = 0; i < pic.Count; i++) { Model.Pic p = pic[i]; sb.Append(" <td width=\"200\"><a href=\"" + p.Href + "\"><img src=\"../" + p.Src + "\" border='0' title=\"" + p.Title + "\" alt=\"" + p.Title + "\"></a></td>"); } sb.Append("</tr></table>"); demo1.InnerHtml = sb.ToString(); }
数据库表:
USE [Enterprise] GO /****** 对象: Table [dbo].[Pics] 脚本日期: 03/17/2011 19:26:27 ******/ SET ANSI_NULLS ON GO SET QUOTED_IDENTIFIER ON GO SET ANSI_PADDING ON GO CREATE TABLE [dbo].[Pics]( [Id] [int] IDENTITY(1,1) NOT NULL, [ComId] [int] NOT NULL, [Title] [varchar](50) COLLATE Chinese_PRC_CI_AS NULL, [Href] [varchar](255) COLLATE Chinese_PRC_CI_AS NULL, [Src] [varchar](255) COLLATE Chinese_PRC_CI_AS NOT NULL, PRIMARY KEY CLUSTERED ( [Id] ASC )WITH (IGNORE_DUP_KEY = OFF) ON [PRIMARY] ) ON [PRIMARY] GO SET ANSI_PADDING OFF
实体类:
public class Pic { public int Id { set; get; } public int ComId { set; get; } public Model.CompanyModel CompanyModel { set; get; } public string Title { set; get; } public string Src { set; get; } public string Href { set; get; } }
很多项目中都会遇到有类似跑马灯效果的消息轮播展示,做了一个简单的消息轮播展示。
主要代码如下:
html
<!DOCTYPE html>
<head lang="en">
<meta charset="UTF-8">
<title>跑马灯效果</title>
<meta name="viewport" content="initial-scale=1.0, maximum-scale=1.0, minimum-scale=1.0, user-scalable=no, width=device-width">
<link href="css/index.css" type="text/css" rel="stylesheet">
<div class="g-winner-roll">
<img src="img/tongzhi.png">
<div class="m-countdown">
</div>
</div>
<script src="js/jquery.min.js"></script>
<script src="js/index.js"></script>
css
.g-winner-roll{
height: 30px;
border-bottom: 1px solid #d3d3d3;
background-color: #ffffff;
.g-winner-roll img{
float: left;
margin-left: 10px;
margin-top: 7px;
display: block;
width: 15px;
height: 15px;
.m-countdown{
margin-left: 25px;
width: 100%;
height: 30px;
.m-countdown > a{
text-align: left;
margin-left: 10px;
height: 30px;
line-height: 30px;
font-size: 12px;
position:absolute;
display: none;
.m-countdown > a:first-child{
display: block;
.m-countdown > a >span{
color: rgb(128,128,128);
height: 30px;
index.js
* Created by rayootech on 16/8/6.
$(function(){
var list = ["跑马灯效果数据1","跑马灯效果数据2","跑马灯效果数据3","跑马灯效果数据4","跑马灯效果数据5","跑马灯效果数据6"];
var htmlString ="";
for(var i=0;i<list.length;i++){
htmlString += '<a href="#"><span>'+list[i]+'</span></a>';
$(".m-countdown").html(htmlString);
showRollling();
function showRollling(){
var height = 40; //这个数字是轮播图片的高度
var animationTime = 600; //这个数字是动画时间
var marginTime = 2000; //这个数字是间隔时间
var nowimg = 0; //信号量
var mytimer = null;
//将图片列表中的第一个节点复制,然后追加到队列的最后。
//$(".m-countdown a:first-child").clone().appendTo(".m-countdown");
var mytimer = window.setInterval(
function(){
youanniu();
,marginTime
<!--计时器暂停方法-->
// window.clearInterval(mytimer);
// mytimer = window.setInterval(
function youanniu(){
if(!$(".m-countdown a").is(":animated")){
//折腾信号量
if(nowimg < $(".m-countdown a").length - 1){
nowimg = nowimg + 1;
showAnimate(nowimg);
}else{
nowimg = 0;
$(".m-countdown a").each(function(index){
if(index==0){
$(this).css("display","block");
else {
$(this).css("display","none");
}).css("top","7px");
function showAnimate(index) {
$(".m-countdown a").eq(index).css("display","block");
$(".m-countdown a").eq(index-1).animate(
"top": -height * nowimg
, animationTime
效果:
