您现在的位置: 365建站网 > 365文章 > PHP函数method_exists检查类是否存在和与is_callable()的区别
文章来源:365jz.com     点击数:1438    更新时间:2018-08-26 08:45   参与评论
PHP method_exists 检查类的方法是否存在
method_exists
method_exists — 检查类的方法是否存在
说明
bool method_exists ( object $object , string $method_name )
如果 method_name 所指的方法在 object 所指的对象类中已定义,则返回 TRUE,否则返回 FALSE
Example #1 method_exists() 例子
<?php
$directory
= new Directory('.');
var_dump(method_exists($directory,'read'));
以上例程会输出:
bool(true)
PHP method_exists note #1
Just to mention it: both method_exists() and is_callable() return true for inherited methods:
<?php
class ParentClass {
   function
doParent() { }
class
ChildClass extends ParentClass { }
$p = new ParentClass();
$c = new ChildClass();
// all return true
var_dump(method_exists($p'doParent'));
var_dump(method_exists($c'doParent'));
var_dump(is_callable(array($p'doParent')));
var_dump(is_callable(array($c'doParent')));
PHP method_exists note #2
Using method_exists inside an object's __call() method can be very usefull if you want to avoid to get a fatal error because of a limit in function nesting or if you are calling methods that dont exist but need to continue in your application:
<?php
class Something
     * Call a method dynamically
     * @param string $method
     * @param array $args
     * @return mixed
public function __call($method$args
        if(
method_exists($this$method)) {
          return
call_user_func_array(array($this$method), $args);
        }else{
          throw new
Exception(sprintf('The required method "%s" does not exist for %s'$methodget_class($this)));
PHP method_exists note #3
As noted [elsewhere] method_exists() does not care about the existence of __call(), whereas is_callable() does:
<?php
class Test
  public function
explicit(  ) {
  public function
__call$meth$args ) {
$Tester = new Test();
var_export(method_exists($Tester'anything')); // false
var_export(is_callable(array($Tester'anything'))); // true
PHP method_exists note #4
Be warned that the class must exist before calling method exists from an eval statement otherwise you will get a Signal Bus error.
PHP method_exists note #5
It wasn't spelled out but could be inferred: method_exists() also works on interfaces.
<?php
var_dump
(method_exists("Iterator""current"));
// bool(true)
PHP method_exists note #6
If you want to check in a class itself if a method is known you may do so with magic variable __CLASS__
<?php
class A{
__construct($method){
      return
method_exists(__CLASS__,$method);
  private function
foo(){
$test = new A('foo');
//should return true
You might also use the method describe below with <?php in_array() ?>trick but I consider this one here easier and more readable and well, the way it is intended toi be done ;)
PHP method_exists note #7
Hi,
Here is a useful function that  you can use to check classes methods access e.g whether it is public, private or static or both..
here it goes:
<?php
// Example class
class myClass
    private
$private1
    static
$static1
    public
$public1
    public function
publ() {
    private function
priv() {
    private static function
privstatic() {
    public static function
publstatic() {
    static function
mytest() {
// The function uses the reflection class that is built into PHP!!!
// The purpose is to determine the type of a certain method that exi
function is_class_method($type="public"$method$class) {
// $type = mb_strtolower($type);
$refl = new ReflectionMethod($class$method);
    switch(
$type) {
        case
"static"
        return
$refl->isStatic();
        break;
        case
"public"
        return
$refl->isPublic();
        break;
        case
"private"
        return
$refl->isPrivate();
        break;
var_dump(is_class_method("static""privstatic""myClass")); // true - the method is  private and also static..
var_dump(is_class_method("private""privstatic""myClass")); // true - the method is  private and also static..
var_dump(is_class_method("private""publstatic""myClass")); // False the methos is public and also static not private
 // you get the idea.. I hope this helps someone..
PHP method_exists note #8
This function is case-insensitive (as is PHP) and here is the proof:
<?php
class {
    public function
FUNC() { echo '*****'; }
$a = new A();
$a->func(); // *****
var_dump(method_exists($a'func')); // bool(true)
PHP method_exists note #9
As mentioned before, is_callable and method_exists report all methods callable even if they are private/protected and thus actually not callable. So instead of those functions you may use following work-around which reports methods as supposed to.
<?php
class Foo1 {
  public function
bar() {
    echo
"I'm private Foo1::bar()";
class
Foo2 {
  private function
bar() {
    echo
"I'm public Foo2::bar()";
$f1=new Foo1;
$f2=new Foo2;
if(
is_callable(array($f1,"bar"))) {
    echo
"Foo1::bar() is callable";
} else {
    echo
"Foo1::bar() isn't callable";
if(
is_callable(array($f2,"bar"))) {
    echo
"Foo2::bar() is callable";
} else {
    echo
"Foo2::bar() isn't callable";
if(
in_array("bar",get_class_methods($f1))) {
    echo
} else {
    echo
if(
in_array("bar",get_class_methods($f2))) {
    echo
} else {
    echo
output
Foo1::bar() is callable (correct)
Foo2::bar() is callable (incorrect)
Foo2::bar() isn't callable (correct)
在编程中,我们有的时候需要判断某个类中是否包含某个方法,除了使用反射机制,PHP还提供了method_exists()和is_callable()方法进行判断。那么两则区别是什么呢?
已知类文件如下:
class Student{
    private $alias=null;    private $name='';    public function __construct($name){
        $this->name=$name;
    }    private function setAlias($alias){
        $this->alias=$alias;
    }    public function getName(){
        return $this->name;
}12345678910111213
当方法是private,protected类型的,method_exists会报错,is_callable会返回false。
下面是判断某一对象中是否存在方法getName
通过method_exists实现
$xiaoming=new Student('xiaoming');if (method_exists($xiaoming, 'getName')) {
    echo 'exist';
}else{    echo 'not exist';
}exit();1234567
输出exist
通过is_callable实现
$xiaoming=new Student('xiaoming');if (is_callable(array($xiaoming, 'getName'))) {
    echo 'exist';
}exit();1234567
输出exist
下面是判断某一对象中是否存在方法setAlias
当使用method_exists的时候报错如下
当使用is_callable的时候,输出not exist
发表评论 (1438人查看0条评论)
