您现在的位置: 365建站网 > 365文章 > js/jquery中input 绑定回车enter事件的代码
文章来源:365jz.com     点击数:7945    更新时间:2019-08-04 17:18   参与评论
方法一:jquery监听input回车键实现点击回车进行查询
<script type="text/javascript" src="Scripts/jquery-1.6.2.js"></script>
$(".input-cname").keypress(function (e) {
                if (e.which == 13) {
                    ReloadData();
方法二:js中input 绑定回车事件
html
<input type="text" id="message" οnkeypress="return onKeyPress(event)" >
script
function onKeyPress(e) {
var keyCode = null;
if(e.which)
keyCode = e.which;
else if(e.keyCode)
keyCode = e.keyCode;
if(keyCode == 13) {
SendMessage();
return false;
return true;
function SendMessage() {
console.log(1)
方法三:jquery监听input回车键实现点击回车事件
 $('#dataInput').bind('keypress',function(event){
            if(event.keyCode == "13")
                alert('你输入的内容为:' + $('#dataInput').val());
方法四:jquery监听input回车键实现点击回车事件
$(document).keydown(function(e) {
          if (e.keyCode == 13) {
                 //dologin();
下面是搜集到的keyCode:
  1 js 里面的键盘事件经常用到,所以收集了键盘事件对应的键码来分享下:
  2 keyCode 8 = BackSpace BackSpace
  3 keyCode 9 = Tab Tab
  4 keyCode 12 = Clear
  5 keyCode 13 = Enter
  6 keyCode 16 = Shift_L
  7 keyCode 17 = Control_L
  8 keyCode 18 = Alt_L
  9 keyCode 19 = Pause
 10 keyCode 20 = Caps_Lock
 11 keyCode 27 = Escape Escape
 12 keyCode 32 = space
 13 keyCode 33 = Prior
 14 keyCode 34 = Next
 15 keyCode 35 = End
 16 keyCode 36 = Home
 17 keyCode 37 = Left
 18 keyCode 38 = Up
 19 keyCode 39 = Right
 20 keyCode 40 = Down
 21 keyCode 41 = Select
 22 keyCode 42 = Print
 23 keyCode 43 = Execute
 24 keyCode 45 = Insert
 25 keyCode 46 = Delete
 26 keyCode 47 = Help
 27 keyCode 48 = 0 equal braceright
 28 keyCode 49 = 1 exclam onesuperior
 29 keyCode 50 = 2 quotedbl twosuperior
 30 keyCode 51 = 3 section threesuperior
 31 keyCode 52 = 4 dollar
 32 keyCode 53 = 5 percent
 33 keyCode 54 = 6 ampersand
 34 keyCode 55 = 7 slash braceleft
 35 keyCode 56 = 8 parenleft bracketleft
 36 keyCode 57 = 9 parenright bracketright
 37 keyCode 65 = a A
 38 keyCode 66 = b B
 39 keyCode 67 = c C
 40 keyCode 68 = d D
 41 keyCode 69 = e E EuroSign
 42 keyCode 70 = f F
 43 keyCode 71 = g G
 44 keyCode 72 = h H
 45 keyCode 73 = i I
 46 keyCode 74 = j J
 47 keyCode 75 = k K
 48 keyCode 76 = l L
 49 keyCode 77 = m M mu
 50 keyCode 78 = n N
 51 keyCode 79 = o O
 52 keyCode 80 = p P
 53 keyCode 81 = q Q at
 54 keyCode 82 = r R
 55 keyCode 83 = s S
 56 keyCode 84 = t T
 57 keyCode 85 = u U
 58 keyCode 86 = v V
 59 keyCode 87 = w W
 60 keyCode 88 = x X
 61 keyCode 89 = y Y
 62 keyCode 90 = z Z
 63 keyCode 96 = KP_0 KP_0
 64 keyCode 97 = KP_1 KP_1
 65 keyCode 98 = KP_2 KP_2
 66 keyCode 99 = KP_3 KP_3
 67 keyCode 100 = KP_4 KP_4
 68 keyCode 101 = KP_5 KP_5
 69 keyCode 102 = KP_6 KP_6
 70 keyCode 103 = KP_7 KP_7
 71 keyCode 104 = KP_8 KP_8
 72 keyCode 105 = KP_9 KP_9
 73 keyCode 106 = KP_Multiply KP_Multiply
 74 keyCode 107 = KP_Add KP_Add
 75 keyCode 108 = KP_Separator KP_Separator
 76 keyCode 109 = KP_Subtract KP_Subtract
 77 keyCode 110 = KP_Decimal KP_Decimal
 78 keyCode 111 = KP_Divide KP_Divide
 79 keyCode 112 = F1
 80 keyCode 113 = F2
 81 keyCode 114 = F3
 82 keyCode 115 = F4
 83 keyCode 116 = F5
 84 keyCode 117 = F6
 85 keyCode 118 = F7
 86 keyCode 119 = F8
 87 keyCode 120 = F9
 88 keyCode 121 = F10
 89 keyCode 122 = F11
 90 keyCode 123 = F12
 91 keyCode 124 = F13
 92 keyCode 125 = F14
 93 keyCode 126 = F15
 94 keyCode 127 = F16
 95 keyCode 128 = F17
 96 keyCode 129 = F18
 97 keyCode 130 = F19
 98 keyCode 131 = F20
 99 keyCode 132 = F21
100 keyCode 133 = F22
101 keyCode 134 = F23
102 keyCode 135 = F24
103 keyCode 136 = Num_Lock
104 keyCode 137 = Scroll_Lock
105 keyCode 187 = acute grave
发表评论 (7945人查看0条评论)
