您现在的位置: 365建站网 > 365文章 > HttpWebRequest读取网页源码转字符串不完整的解决办法
文章来源:365jz.com     点击数:539    更新时间:2020-06-28 00:45   参与评论
在读取网站源码时发现部分页面读到的内容不完整,浏览器打开正常
1 说明不是人家服务器问题
2 fiddler里打开发现也不完整,而且乱码,但在transformer里设置成 no compression 后也正常。说明读取的东西是完整的,是后续处理的问题
3 c#里调试发现读取的字符串被截断,copy字符串到notepad++里发现被截断的地方有\0\0,原来如此,\0表示字符串结su呢
4.处理程序使用的自动解压缩方法的设置
</>code
  1. request.AutomaticDecompression = DecompressionMethods.Deflate | DecompressionMethods.GZip |
  2.                                                  DecompressionMethods.None;
处理的方法如下:
</>code
  1. try
  2. {
  3. strUrl = "http://www.xxx.com";
  4.
  5.                 CookieContainer cc = new CookieContainer();
  6.                 HttpWebRequest request = (HttpWebRequest)WebRequest.Create(strUrl);
  7.
  8.                 request.Method = "Get";
  9.                 request.CookieContainer = cc;
  10.                 request.KeepAlive = true;
  11.                 request.ContentType = "text/html";
  12.                 request.UserAgent = "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/39.0.2171.95 Safari/537.36";
  13.                 request.Headers.Add("x-requested-with:XMLHttpRequest");
  14.                 request.Headers.Add(HttpRequestHeader.AcceptLanguage, "zh-CN,zh;q=0.8,en;q=0.6,nl;q=0.4,zh-TW;q=0.2");
  15.                 request.Accept = "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8";
  16.                 request.AutomaticDecompression = DecompressionMethods.Deflate | DecompressionMethods.GZip |
  17.                                                  DecompressionMethods.None;
  18.                 request.Headers.Add("Accept-Encoding", "gzip, deflate");
  19.                 if (request.Method == "POST")
  20.                 {
  21.                     (request as HttpWebRequest).ContentType = "application/x-www-form-urlencoded";
  22.                 }
  23.
  24.                 HttpWebResponse response = (HttpWebResponse)request.GetResponse();
  25.
  26.                 //StreamReader reader = new StreamReader(response.GetResponseStream(), Encoding.GetEncoding("gb2312"));
  27.                 StreamReader reader = new StreamReader(response.GetResponseStream(), encoder);
  28.
  29.                 strMsg = reader.ReadToEnd();
  30.                 // .\0为null,空字符,也是字符串结束标志
  31.                 strMsg = strMsg.Replace("\0", "");
  32.
  33.                 reader.Close();
  34.                 reader.Dispose();
  35.                 response.Close();
  36.
  37.
  38.             }
  39.             catch
  40.             { }
发表评论 (539人查看0条评论)
