您现在的位置: 365建站网 > 365文章 > 实现一个基于Ajax的调查程序
实现一个基于Ajax的调查程序
文章来源:365jz.com     点击数:626    更新时间:2008-05-08 22:05   参与评论
<title>投票</title>
<META http-equiv=Content-Language content=zh-cn>
<META http-equiv=Content-Type content="text/html; charset=gb2312">
<style type="text/css">
.poll {font-size: 10pt;display:block}
.pollresult {font-size: 12pt;display:none}
</style>
<?php
 include_once("server1.server.php"); #servidor para XAJAX
 $xajax->printJavascript();
<script language=javascript>
    function back() {
      document.getElementById('poll').style.display = 'block';
      document.getElementById('pollresult').style.display = 'none';
      document.getElementById('pollresult').innerHTML = '';
<div id=pollresult class=pollresult>
</div>
<?php
global $db;
$poll = $db->getRow("select * from TBL_POLL order by poll_id desc limit 1");
$poll_id = $poll["poll_id"];
$pollitems = $db->getAll("select * from TBL_POLLITEM where poll_id=$poll_id");
<div id=poll class=poll>
<form id="pollForm" action="javascript:void(null);" onsubmit="onSubmit();">
   <?php echo $poll["title"]; ?><br>
   <?php for ($i = 0, $count = count($pollitems); $i < $count; $i++) { ?>
  <input type="radio" style="background-color : #CCCCCC;" name="pollitem" value="<?php echo $pollitems[$i]['pollitem_id'] ?>"><?php echo $pollitems[$i]['content'] ?><br>
  <?php } ?>
  <input type="hidden" name="poll_id" value="<?php echo $poll_id; ?>">
  <input type="submit" value="enter">
</form>
    function onSubmit() {
      xajax_poll(xajax.getFormValues("pollForm"));
      document.getElementById('poll').style.display = 'none';
      document.getElementById('pollresult').style.display = 'block';
</div>
服务器端
function poll($formData){
  global $db;
  $tmp="";
  $objResponse = new xajaxResponse();
  $poll_id = $formData['poll_id'];
  $pollitem_id = $formData['pollitem'];
  if($pollitem_id > 0 && $poll_id > 0) {
   $db->query("update ".TBL_POLLITEM." set count=count+1 where pollitem_id = $pollitem_id");
  $poll = $db->getRow("select * from TBL_POLL where poll_id = $poll_id");
  $tmp .="<div align=center>".$poll["title"]."</div><br>";
      $tmp .="<div align=left>".$pollitems[$i]['content'].": ".$pollitems[$i]['count']."</div>";
  $tmp .="<div align=center>"."<input type=\"button\"  value=\"返回\" onclick=\"back();\">"."</div>";
  $objResponse->addAssign("pollresult","innerHTML",$tmp);
  return $objResponse->getXML();
数据库的表如下
CREATE TABLE TBL_POLL (
  poll_id int(11) unsigned NOT NULL default '0',
  title varchar(100) NOT NULL default '',
  created_date bigint(20) unsigned NOT NULL default '0',
  user_id int(11) unsigned NOT NULL default '0',
  PRIMARY KEY  (poll_id)
) TYPE=MyISAM;
CREATE TABLE TBL_POLLITEM (
  pollitem_id int(11) unsigned NOT NULL default '0',
  content varchar(100) NOT NULL default '',
  count int(11) unsigned NOT NULL default '0',
  PRIMARY KEY  (pollitem_id)
) TYPE=MyISAM;
这个例子中,调查的选项只在页面装载时读出,投票后在原地显示最新的投票信息。不需要弹出窗口
发表评论 (626人查看0条评论)
