您现在的位置: 365建站网 > 365文章 > HTML to XHTML Converter
文章来源:365jz.com     点击数:268    更新时间:2008-07-26 19:56   参与评论
if (!empty($type)) {
    if ($type == "path") {
        if (!empty($path)) {
            if (file_exists($path) && is_file($path)) {
                $file = file($path);
                if (substr($file[0],0,9) != "<!DOCTYPE") $doctype=0;
                    $file = join('', $file);
                } else {
                    die ("No such file.");
            } else {
                die ("No file specified.");
        } elseif ($type == "file") {
            if (!empty($file)) {
            } else {
    } else {
# specify html file, check for doctype
//$file = file("file.html");
//if (substr($file[0],0,9) != "<!DOCTYPE") $doctype=1;
//$file = join('', $file);
# make tags and properties lower case, close empty elements, quote all properties
$search  = array ("'(<\/?)(\w+)([^>]*>)'e",
                   "'(<\/?)(br|input|meta|link|img)([^>]*)( />)'ie",
                   "'(<\/?)(br|input|meta|link|img)([^>]*)(/>)'ie",
                   "'(<\/?)(br|input|meta|link|img)([^>]*)(>)'ie",
                   "'(\w+=)(\w+)'ie",
                   "'(\w+=)(.+?)'ie");
$replace = array ("'\\1'.strtolower('\\2').'\\3'",
                   "'\\1\\2\\3>'",
                   "'\\1\\2\\3>'",
                   "'\\1\\2\\3 /\\4'",
                   "strtolower('\\1').'\"\\2\"'",
                   "strtolower('\\1').'\\2'");
$file = preg_replace($search, $replace, $file);
# return xhtml-compliant document
echo "<textarea cols=\"100\" rows=\"20\">";
if (isset($doctype)) echo '<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "DTD/xhtml1-transitional.dtd">'."\n";
echo stripslashes(stripslashes(stripslashes($file)));
echo "</textarea>";
} else {
<head><title>HTML -> XHTML Convertor</title></head>
<!-- WARNING: this input method is a security risk on open servers //-->
<form action="<?=$PHP_SELF?>" method="get">
<input type="hidden" name="type" value="path" />
<font face="verdana">File path:</font> <input type="text" name="path" size="50" />
<input type="submit" value="Submit" />
</form>
<b><font face="verdana">OR</font></b><br /><br />
<input type="hidden" name="type" value="file" />
<font face="verdana">File contents:</font><br />
<textarea name="file" rows="10" cols="50"></textarea><br />
</form>
发表评论 (268人查看0条评论)
