您现在的位置: 365建站网 > 365文章 > mootools实现搜索提示文本框 (转)
文章来源:365jz.com     点击数:372    更新时间:2009-09-12 15:02   参与评论
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="NewAjaxTextBox.aspx.cs" Inherits="NewAjaxTextBox" %>
<head id="Head1" runat="server">
    <title>无标题页</title>
    <link href="AjaxText.css" rel="stylesheet" type="text/css" />
    <script type="text/javascript" src="mootools-release-1.11.js"></script>
        function getMsg(obj){
            $("ajaxtextbox").value=obj.innerHTML;
            $("msgdiv").innerHTML="";
            $("msgdiv").className="display1";
        window.addEvent('domready',function(){
                $('ajaxtextbox').addEvent('keyup',function(e){
                    if($('ajaxtextbox').value==''){
                        return;
                    var url="NewAjaxTextBox.aspx?value="+ escape($('ajaxtextbox').value);
                    new Ajax(url,{method:'post',
                        onComplete:function(){
                            $("msgdiv").innerHTML=this.response.text;
                            if(this.response.text!=''){
                                $("msgdiv").className="display2";
                    }).request();
    <input type="text" id="ajaxtextbox" class="text" runat="server" /><br />
    <div id="msgdiv" class="display1" >
    </div>
CS
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Text;
public partial class NewAjaxTextBox : System.Web.UI.Page
    public static DataTable dt = new DataTable();
        if (dt.Rows.Count < 1)
            dt.Columns.Add("content");
            for (int i = 0; i < 3; i++)
                DataRow dr = dt.NewRow();
                dr["content"] = "呵呵" + i.ToString();
                dt.Rows.Add(dr);
                dr["content"] = "哈哈" + i.ToString();
                dt.Rows.Add(dr);
        if (!String.IsNullOrEmpty(Request["value"]))
            Seach(Request["value"]);
    protected void Seach(string value)
        StringBuilder sb = new StringBuilder();
        for (int i = 0; i < dt.Rows.Count; i++)
            string content = dt.Rows[i]["content"].ToString();
            if (content.IndexOf(value.Trim())>0||content.StartsWith(value.Trim())||content.EndsWith(value.Trim()))
                string id = "dv" + i.ToString();
                sb.AppendFormat("<div id=""{0}"" style=""width:170px; cursor:pointer;""  ><a href=""javascript:void(null);"" onclick=""getMsg(this)"" >{1}</a></div>", id, dt.Rows[i]["content"].ToString());
        Response.Clear();
        Response.Write(sb);
        Response.End();
AjaxText.css
.text{ width:200px; font-size:12px; left:0px;}
.display1{ width:200px; left:1px;}
.display2{ width:200px; border: solid 1px blackleft:1px;}
a:link
     color: #000000;
     text-decoration: none;
a:visited
     color: #0000FF;
a:hover
     color: #FF0000;
     text-decoration: underline;
发表评论 (372人查看0条评论)
