您现在的位置: 365建站网 > 365文章 > NET四种文件下载方式
NET四种文件下载方式
文章来源:365jz.com     点击数:258    更新时间:2009-09-12 17:00   参与评论
 protected void Button1_Click(object sender, EventArgs e)
        //TransmitFile实现下载
         微软为Response对象提供了一个新的方法TransmitFile来解决使用Response.BinaryWrite
         下载超过400mb的文件时导致Aspnet_wp.exe进程回收而无法成功下载的问题。
         代码如下:
        Response.ContentType = "application/x-zip-compressed";
        Response.AddHeader("Content-Disposition", "attachment;filename=keji.rar");
        string filename = Server.MapPath("keji.rar");
        Response.TransmitFile(filename);
        Response.Write("<script language=\"javascript\" type=\"text/javascript\">");
        Response.Write("alert(\"下载成功\");");
        Response.Write("window.location.href=\"C_SC.aspx\";");
        Response.Write("</script>");
    protected void Button2_Click(object sender, EventArgs e)
        //WriteFile实现下载
        string fileName = "ceshi.rar";//客户端保存的文件名
        string filePath = Server.MapPath("keji.rar");//路径
        FileInfo fileInfo = new FileInfo(filePath);
        Response.Clear();
        Response.ClearContent();
        Response.ClearHeaders();
        Response.AddHeader("Content-Disposition", "attachment;filename=" + fileName);
        Response.AddHeader("Content-Length", fileInfo.Length.ToString());
        Response.AddHeader("Content-Transfer-Encoding", "binary");
        Response.ContentType = "application/octet-stream";
        Response.ContentEncoding = System.Text.Encoding.GetEncoding("gb2312");
        Response.WriteFile(fileInfo.FullName);
        Response.Flush();
        Response.End();
    protected void Button3_Click(object sender, EventArgs e)
        //WriteFile分块下载
        string fileName = "GhostXP.iso";//客户端保存的文件名
        string filePath = Server.MapPath("GhostXP7.7.iso");//路径
         System.IO.FileInfo fileInfo = new System.IO.FileInfo(filePath);
        if (fileInfo.Exists == true)
            const long ChunkSize = 409600;//100K 每次读取文件,只读取100K,这样可以缓解服务器的压力
            byte[] buffer = new byte[ChunkSize];
             Response.Clear();
             System.IO.FileStream iStream = System.IO.File.OpenRead(filePath);
            long dataLengthToRead = iStream.Length;//获取下载的文件总大小
             Response.AddHeader("Content-Disposition", "attachment; filename=" + HttpUtility.UrlEncode(fileName));
            while (dataLengthToRead > 0 && Response.IsClientConnected)
                int lengthRead = iStream.Read(buffer, 0, Convert.ToInt32(ChunkSize));//读取的大小
                 Response.OutputStream.Write(buffer, 0, lengthRead);
                 Response.Flush();
                 dataLengthToRead = dataLengthToRead - lengthRead;
             Response.Close();
    //字符流方式下载文件
    protected void Button4_Click(object sender, EventArgs e)
        string fileName = "ce2.rar";//客户端保存的文件名
        //以字符流的形式下载文件
        FileStream fs = new FileStream(filePath, FileMode.Open);
        byte[] bytes = new byte[(int)fs.Length];
        fs.Read(bytes, 0, bytes.Length);
        fs.Close();
        //通知浏览器下载文件而不是打开
        Response.AddHeader("Content-Disposition", "attachment;   filename=" + HttpUtility.UrlEncode(fileName, System.Text.Encoding.UTF8));
        Response.BinaryWrite(bytes);
        Response.Flush();
        Response.End();
发表评论 (258人查看0条评论)
