您现在的位置: 365建站网 > 365文章 > 序列化类,将类转为二进制
序列化类,将类转为二进制
文章来源:365jz.com     点击数:202    更新时间:2009-09-13 10:53   参与评论
因为需要把复杂事物组合放进数据库,因此采用了将类转成二进制,直接插入到一个字段
public static class Serializer
        public static byte[] ToBinary<T>(this T o) where T : class, new()
            byte[] bytes = null;
            DataContractSerializer dc = new DataContractSerializer(typeof(T));
            using (MemoryStream ms = new MemoryStream())
                //formatter.Serialize(ms, value);
                dc.WriteObject(ms, o);
                ms.Seek(0, 0);
                bytes = ms.ToArray();
            return bytes;
        public static TResult FromBinary<TResult>(this TResult input, byte[] bits) where TResult : class, new()
            TResult result = default(TResult);
            DataContractSerializer dc = new DataContractSerializer(typeof(TResult));
            //IFormatter formatter = new BinaryFormatter();
            using (MemoryStream ms = new MemoryStream(bits))
                result = (TResult)dc.ReadObject(ms);
            return result;
发表评论 (202人查看0条评论)
