XML常用类(淘宝API)
文章来源:365jz.com 点击数:
499 更新时间:2009-09-13 10:53
参与评论
Code
1
using System;
2
3
using System.Linq;
4
using System.Text;
5
using System.Xml;
6
using System.Xml.Serialization;
7
using System.IO;
8
9
namespace TaoBao.API.Common
10
11
/**//// <summary>
12
/// 操作XML常用方法集合
13
/// </summary>
14
public class XMLCommon
15
16
17
/**//// <summary>
18
/// 将XML文档转换成实例对象
19
/// </summary>
20
/// <typeparam name="T">对象类型</typeparam>
21
/// <param name="pmFileName">文件名</param>
22
/// <returns>实例对象</returns>
23
public static T DeserializeFile<T>(string pmFileName)
24
25
FileStream fs = new FileStream(pmFileName, FileMode.Open);
26
XmlSerializer xs = new XmlSerializer(typeof(T));
27
T tObjext = (T)xs.Deserialize(fs);
28
fs.Close();
29
fs.Dispose();
30
return tObjext;
31
32
33
/**//// <summary>
34
/// 将实例对象写入XML文档
35
/// </summary>
36
37
38
/// <param name="pmT">实例对象</param>
39
public static void SerializeFile<T>(string pmFileName, T pmT)
40
41
42
XmlSerializer serializer = new XmlSerializer(pmT.GetType());
43
TextWriter writer = new StreamWriter(pmFileName);
44
serializer.Serialize(writer, pmT);
45
writer.Close();
46
47
48
49
/**//// <summary>
50
/// 将XML字符串转换成对象
51
/// </summary>
52
53
/// <param name="pmXMLString">XML字符串</param>
54
55
public static T DeserializeXML<T>(string pmXMLString)
56
57
58
T tObjext = (T)xs.Deserialize(new StringReader(pmXMLString));
59
return tObjext;
60
61
62
/**//// <summary>
63
/// 将Josn字符串转换成对象
64
/// </summary>
65
66
/// <param name="pmXMLString">Josn字符串</param>
67
68
public static T DeserializeJSON<T>(string pmXMLString)
69
70
71
72
return tObjext;
73
74
75
76
/**//// <summary>
77
/// 将实例对象转换成键值对集合
78
/// </summary>
79
80
81
/// <returns>键值对集合</returns>
82
public static Dictionary<string,string> DeserializeClass<T>(T pmT)
83
84
UTF8Encoding utf8 = new UTF8Encoding();
85
Dictionary<string, string> reValue = new Dictionary<string, string>();
86
string filename = DateTime.Now.ToString("yyyyMMddHHmmssfff")+"xmlfile.xml";
87
SerializeFile(filename, pmT);
88
FileStream fs = new FileStream(filename, FileMode.Open);
89
XmlDocument document = new XmlDocument();
90
document.Load(fs);
91
foreach(XmlNode child in document.DocumentElement.ChildNodes)
92
93
reValue.Add(child.Name, utf8.GetString(utf8.GetBytes(child.InnerText)));
94
95
fs.Close();
96
fs.Dispose();
97
//File.Delete(filename);
98
return reValue;
99
100
101
/**//// <summary>
102
/// 将键值对集合转成字符串
103
/// </summary>
104
/// <param name="pmDictionary">键值对集合</param>
105
/// <returns>字符串</returns>
106
public static string GetParams(IDictionary<string, string> pmDictionary)
107
108
System.Collections.IEnumerator iter = pmDictionary.Keys.GetEnumerator();
109
System.Text.StringBuilder orgin = new System.Text.StringBuilder();
110
int i = 0;
111
while (iter.MoveNext())
112
113
string name = (string)iter.Current;
114
string value =System.Web.HttpUtility.UrlEncode(pmDictionary[name], System.Text.Encoding.UTF8);
115
orgin.Append(name).Append("=").Append(value);
116
if (i != pmDictionary.Keys.Count - 1) orgin.Append("&");
117
i++;
118
119
return orgin.ToString();
120
121
122
123
124
Tag标签: xml,XML常用类
