您现在的位置: 365建站网 > 365文章 > 方法的调用链
方法的调用链
文章来源:365jz.com     点击数:194    更新时间:2009-09-14 10:29   参与评论
/* 方法的调用链 */
(function(){
    function _$(els){
        this.elements = [];
        for(var i=0,len = els.length ;i<len; ++i){
            var element = els[i];
            if (typeof element === 'string') {
                element = document.getElementById(element);
            this.elements.push(element);
    _$.prototype = {
        each: function(){
            for( var i=0, len=this.elements.length;i<len; ++i;){
                fn.call(this, this.elements[i]);
            return this;
        setStyle: function(prop, val){
            this.each(function(el){
                el.style[prop] = val;
            return this;
        show: function(){
            var that = this;
                that.setStyle('display','block');
            return this;
        addEvent: function(){
            var add = function(el){
                if (window.addEventListtener) {
                    el.addEventListtener(type, fn, false);
                else if (window.attachEvent) {
                    el.attachEvent('on'+type, fn);
                add(el);
            return this;
    window.$ = function(){
        return new _$(arguments);
$(window).addEvent('load',function(){
    $('test-1','test-2').show().setStyle('color','red').addEvent('click',function(e){
        $(this).setStyle('color','green');
发表评论 (194人查看0条评论)
