您现在的位置: 365建站网 > 365文章 > javascript 工厂模式
javascript 工厂模式
文章来源:365jz.com     点击数:235    更新时间:2009-09-14 10:29   参与评论
/* 简单工厂 */
/* BicycleShop class */
var BicycleShop = function() {};
BicycleShop.prototype = {
    sellBicycle: function(model) {
        var bicycle;
        switch(model) {
            case 'The SpeedSter':
                bicycle = new SpeedSter();
             break;
            case 'The Lowrider':
                bicycle = new Lowrider();
             break;
         case 'The Comfort Cruiser':
            default:
                bicycle = new ComfortCruiser();
        Interface.ensureImplements(bicycle, Bicycle);
        bicycle.assemble();
        bicycle.wash();
        return bicycle;
/* The Bicycle interface. */
var Bicycle = new Interface('Bicycle', ['assemble','wash','ride','repaid']);
/* Speedster class. */
var Speedster = function() {//implements Bicycle
Speedster.prototype = {
    accemble: function() {
    wash: function() {
    ride: function() {
    repaid: function() {
var californiaCruisers = new BicycleShop();
var yourNewBike = californiaCruisers.sellBicyCle('The Speedster');
/* BicycleFactory namespace. */
var BicycleFactory ={
    createBicycle: function(model) {
        var bicycle;
        switch(model) {
             break;
             break;
            default:
        return bicycle;
/* BicycleShop class, improved */
    var bicycle = BicycleFactory.createBicycle(model);
    bicycle.assemble();
    bicycle.wash();
    return bicycle;
/* 真正的工厂模式 */
/* BicycleShop class(abstract). */
        var bicycle = this.createBicycle(model);
        bicycle.assemble();
        bicycle.wash();
        return bicycle;
        throw new Error('Unsupported operation on an abstract class.');
/* AcmeBicycleShop class. */
var AcmeBicycleShop = function() {};
extend(AcmeBicycleShop, BicycleShop);//类式继承
AcmeBicycleShop.prototype.createBicycle = function(model) {
    var bicycle;
    switch(model) {
            break;
            break;
        default:
    return bicycle;
发表评论 (235人查看0条评论)
